Mike's 5lug Long Travel rear build
Old 01-27-2011, 10:32 AM   #1
MadTaco461 [OP] MadTaco461 is online now
MadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shedMadTaco461 is one of the sharper tools in the shed
MadTaco461's Avatar
MadTaco461's Tacoma Gallery
Well, got an early start than intended with a long travel rear since breaking my axle before new years. So currently I am stripping the whole rear down. I took off my J59's and Fox 2.0"x14" shocks. I'm planning to do this build to just do the stuff I need to make this work. I'm going to be boxing the frame, keeping the stock gas tank, running the allpro 50T pack, and king 2.5"x 16" smoothies. The bedcage is going to be very basic straight bars. Future upgrades will be hydro bumps up front and rear and a U-bolt eliminator.
here is how she is sitting
fully trussed axle
before, and yes the bed cage is bent from breaking at the weld back in may 2010
Old 01-28-2011, 10:57 AM   #2
wo ai ni bao bei ^_^
blackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shed
blackhawke88's Avatar
blackhawke88's Tacoma Gallery
BAMF!
Old 01-28-2011, 11:05 AM   #3
First I derp.. then I herp
mntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shed
mntbiker2008's Avatar
Firefighter:
mntbiker2008's Tacoma Gallery
Sub'ed!!!! Your front is already LT'ed right? Looks like it from the pics in your sig.
Old 01-28-2011, 11:07 AM   #4
MadTaco461's Avatar
Up front is already a JD fab LT. It needs some upgrades once the rear is done. Hoping to keep a good balance there.
Old 01-28-2011, 11:09 AM   #5
Firefighter:
nice! good luck with the build! I love all the LT tacos.
Old 02-01-2011, 11:43 PM   #6
Trifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shed
Trifenix's Avatar
Trifenix's Tacoma Gallery
Nice 5 lug long travel truck! Is that a trussed 7.5 rear end? What size tires are you running @ what gears?
Old 02-02-2011, 08:48 AM   #7
MadTaco461's Avatar
Forgot in your PM. I really like the JD kit up front. It is strong, huge 10" shock. I have a fabtech spindle to clear 32" tires. Weakest points are those fabtech spindles and the lower ball joint. I carry an extra set for when i go out to the desert. The rear is a trussed 7.5" with 4.56. I'm doing 60 when the speedo says 70 and about 5mph off at slower speeds.
Old 02-02-2011, 10:47 AM   #8
Firefighter:
make any head-way with the build?
Old 02-02-2011, 03:24 PM   #10
MadTaco461's Avatar
It wasn't too impressive of a break. I stopped where you guys saw me to take a break and looked underneath and saw a broken axle. I didn't try to move so I can save my third member.
So the build again.
Got the hangers on and is pulling out 22" travel and is being held up at 20" in the pic. There is no drive shaft binding at any height. Right now on the list is shock position and bedcage building. Using a King 2.5"x16" hoping to get a smooth 18". Having a shock tab issue. The stock gas tank is in the way so I'm working on cutting up some shock tabs to mount behind the axle over the truss.
Old 02-06-2011, 11:02 PM   #11
87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of87xjmike has much to be proud of
87xjmike's Avatar
87xjmike's Tacoma Gallery
very nice, how long are you shackles? tc 12 inchers?
Old 02-06-2011, 11:23 PM   #12
MadTaco461's Avatar
I used 12" engage shackles and hangers. Very similar to TC in looks.
Old 02-07-2011, 11:05 AM   #13
87xjmike's Avatar
i tried googling engage toyota shackles and engage shackles and nothing came up. Are they cheaper than tc? 300 for those tc shackles seem like a rip off. I'm about to get ruff stuff to cut me some 10-12"ers but i'm open to options.
Old 02-08-2011, 08:20 AM   #14
Trifenix's Avatar
Maybe you can try to mount the shocks outside the frame rail? and use spacers?
Old 02-08-2011, 09:39 AM   #15
MadTaco461's Avatar
I tested to see if 2 inch spacers work and it didn't look too safe when I'd wheel slow. My old 2.0's would fit. So I'm running the shocks inboard. I can get 16" to work over 19" of travel and building the bed cage off of this and strapping it at 18" Today is tacking the bedcage and finally start boxing the frame tomorrow.
Old 02-08-2011, 09:51 AM   #16
nelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shednelson18matt is one of the sharper tools in the shed
nelson18matt's Avatar
Air Force: Ex-Cone
nelson18matt's Tacoma Gallery
coming along... slowly but surely
you gonna take out any leafs from the 50T?
Old 02-17-2011, 03:02 PM   #17
Air Force: Ex-Cone
any progress???
Old 02-18-2011, 10:56 AM   #19
MadTaco461's Avatar
It's almost alive! Just need to slap in the battery, rear electrical, weld on new spare tire tabs, more cage work to hold the resi, and bolt the brake proportioning valve to the bottom of the bed. Sorry about the wait there guys. So she sits stupid tall right now. 13" before I even touch the bump stop and about 4" of down travel before the straps kick in. I'm going to jump on it some to hope it comes down. Depends on how it rides will make me decide what other leaves I want to pull out. Right now I have the 5th leaf out.
Old 02-18-2011, 08:57 PM   #20
Toyota Its Like A Jeep Thing Only Better
Socalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shedSocalrunner is one of the sharper tools in the shed
Socalrunner's Avatar
Socalrunner's Tacoma Gallery
looks good awesome work. Im debating if i want to spend 3k plus on the my truck. if i could find a deal like you i would jump on it
Alex's Long Travel Build amaes 1st Gen. Builds 276 10-24-2014 08:56 AM
Rondog's Long Travel Build rondog 2nd Gen. Builds 527 01-15-2014 12:49 PM
Long travel build advice! GRatt 2nd Gen. Tacomas 1 12-21-2011 09:16 PM
09 Tacoma Long Travel build Dezert Rat Off-Roading & Trails 7 10-04-2011 11:56 AM
Rear Long travel build atvlifestyle Suspension 10 09-14-2011 05:32 PM
