The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Aug 13, 2014 at 7:11 AM
    #8221
    Blackdawg
    Blackdawg [OP] Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea me too. Coulda been bad.
  2. Aug 13, 2014 at 7:29 AM
    #8222
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    Fuck haha. Ok, it's settled. I'll knock that one out before I go.
  3. Aug 13, 2014 at 7:31 AM
    #8223
    Blackdawg
    Monte
    Wyoming/St. Louis
    Good
  4. Aug 13, 2014 at 7:53 AM
    #8224
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Monte, So Imlooking to do my LBJ's to and was talking to an old friend (Toyota tech) whosaid the 1st gen Tundra's used the same LBJ assembly but he thought theball joint itself was a bit stronger after the TSB/Recall (he said initiallythey had the same issues and recall as the Tacoma's did).
    I searchedall over and haven’t found anything on this except the Tundra's LBJ recall was about thesame time as the Tacoma’s… :notsure:
    He saidworse comes to worse, the Tundra’s are at least the same and tend to sellcheaper on ebay/etc… (but tend to be more expensive at the dealers). Im going to Toyota this week (either tomorrow or Friday) to look atgetting an alignment and plan on comparing the LBJ assemblies and verify this.
  5. Aug 13, 2014 at 7:55 AM
    #8225
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I got a pair of Moog with grease fittings (the nice ones, not the cheap version - yes there are two diff quality Moog LBJ's out there) I coated with POR-15. After reading this plan to do OEM I think. PM me if you want them :spy:
  6. Aug 13, 2014 at 1:49 PM
    #8226
    Blackdawg
    Monte
    Wyoming/St. Louis
    Interesting. I will love to hear your findings on this
  7. Aug 13, 2014 at 2:24 PM
    #8227
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Dont see much diff :notsure:
    I called the local Toyota Parts and unfortunately he didnt have any on hand. They are different part numbers which makes me wonder what's so different...
    1st Gen Tacoma LBJ:
    1st Gen Tundra LBJ:
  8. Aug 13, 2014 at 10:03 PM
    #8228
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could be tie rod ends. I know 4runnera the hole is smaller. Find out I guess.
    Frankenstein is almost done. Just finished welding the bracket back on. If I can get an alignment tomorrow I will be road worthy to finish the trip!
  9. Aug 13, 2014 at 10:08 PM
    #8229
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Dang that was fast.
  10. Aug 13, 2014 at 10:15 PM
    #8230
    Blackdawg
    Monte
    Wyoming/St. Louis
    Didnt fuck around this time. New what had to be done too and more at stake
  11. Aug 14, 2014 at 12:02 AM
    #8231
    Blackdawg
    Monte
    Wyoming/St. Louis
    Frank is alive. All appears well. Gonna try and get it aligned tomorrow hopefully
  12. Aug 14, 2014 at 1:06 AM
    #8232
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    ZINNNNGGGG
    this is where you are wrong. there are ESB kits that also use lower uniballs and their are race kits all over that use lower uniballs.
    also on another note. some times the LBJ faliure is not from the actuall ball joint dislocating but most of the time from those 4 bolts that hold the LBJ to the spindle.
    that trac performance lower uniball replacement may work good to prevent the actual ball joint to fail. but those bolts will still bite you in your ass.
    just my 2 cents.
  13. Aug 14, 2014 at 1:07 AM
    #8233
    JuansTaco
    Juan
    gilbert az
  14. Aug 14, 2014 at 5:01 AM
    #8234
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Damn that was speedy, good to hear indeed.
  15. Aug 14, 2014 at 6:47 AM
    #8235
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Damn. Work was done.
  16. Aug 14, 2014 at 7:13 AM
    #8236
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not really. Like hardly any race kits out there and most are for prerunners and they are usually 4.5-6" over. So the market is tiny for them to begin with.
  17. Aug 14, 2014 at 8:26 AM
    #8237
    johnboyTRD
    johnboyTRD Well-Known Member
    John
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Got me thinking about replacing those lower bolts... I've taken them on and off a few times. Anyone got a good source?
  18. Aug 14, 2014 at 9:26 AM
    #8238
    johnboyTRD
    John
    South SF bay
    Right on. Thx duder. I'll stick with oem
  19. Aug 14, 2014 at 9:27 AM
    #8239
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    Lol
    It says 4WD in the title ;)
  20. Aug 14, 2014 at 9:44 AM
    #8240
    BradyT88
    BradyT88 Well-Known Member
    In the fine print:
    So you have to have their spindles to use them, but it looks like their spindles only work with 1" uniball UCA's.
