The Frankenstein Build! LT/Expo/Trail rig..and BS
Discussion in '1st Gen. Builds (1995-2004)' started by Blackdawg, May 28, 2011.
  1. Aug 14, 2014 at 9:45 AM
    #8241
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    $1400 Spindles + $800 LBJ = Way too much damn money :D
    Without the spindle requirement, I would seriously consider the $800 ball joints though...
    Yeah, that site is pissing me off. Everything requires the other thing...
  2. Aug 14, 2014 at 11:44 AM
    #8242
    Blackdawg
    Blackdawg [OP] Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How they get ya.
    Thats a lot of money haha ill be fine with oem ones. Just change em more often. Ill do double sheer steering later
  3. Aug 14, 2014 at 11:59 AM
    #8243
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    Here is the kit i picked up. It has stock modified spindles with 4wd manual locking hubs so all I would need to do is get custom half shafts
  4. Aug 14, 2014 at 1:26 PM
    #8244
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea see thats a custom kit. Cool yes but not really helpful to anyone else.
    The reality of it is that there isn't a easy non outrageous pricey option for going uniball lowers.
    Sadly
    Also ball joints last longer then uniballs anyways. Most uniball stuff is 30-50k on average. Ball joints are more 60-100k. Depending one the abuse and treatment they get
  5. Aug 14, 2014 at 8:07 PM
    #8245
    bayareataco
    bayareataco Well-Known Member
    Jimmy
    Bay Area, California
    01 tacoma sr5 trd 4x4 5speed
    Camper Shell Thule System 3 inch lift procomp wheels km2's apex plate bumper piaa lights warn m8000-s
    How do you know when the unibals go bad? They break lol? Also what gets replaced when that happens the bearing and the bolt?
  6. Aug 15, 2014 at 5:38 AM
    #8246
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Damn, good point. Especially being located were they are; would get all crapped up really quick.
    If you have a good mechanic, he should be able to tell when doing your alignment.
    A quick check:
    Jack your truck up and put your hands on the top and bottom and try to wiggle it vertically. If there is play, its either your top or bottom ball joint.
    Put your hands on the sides and try to wiggle it horizontally. If there is play, its probably your tie rods.
    Monte, check with Toyota on the Tundra/Tacoma but they didnt have the parts on hand. One of the floor team managers told me he believes they are exactly the same ball joints but the Tundra joints had a collar on them. I think he's refering to this:
    http://www.amazon.com/Genuine-43330...ywords=Genuine+Toyota+Tundra+Lower+ball+joint
    As far as prices, they seem to be the same as the Tacoma :notsure:
  7. Aug 15, 2014 at 6:47 AM
    #8247
    Blackdawg
    Monte
    Wyoming/St. Louis
    the bearing gets play in it. They get loud and wiggle. If you don't replace them the bearing will break out of the joint and then the bolt could break :p
    that is just a rubber dust boot. OEM toyota tacoma ones should come with them. My 03 has them as does all the others that are here with me atm.
    Not too surprised. THe front suspension is so similar and Toyota is great at reusing parts across platforms.
  8. Aug 15, 2014 at 8:01 AM
    #8248
    cmj
    cmj Well-Known Member
    Oregon
    98 Tacoma 4x4
    I have to disagree. Before I replaced mine, I checked for play with a dial indicator. At full drop there was zero measured play in my ball joints (197k miles). But once I put a jack under the LCA and compressed the suspension about an inch I was able to measure 0.010" of play. So it can be very deceiving!
  9. Aug 15, 2014 at 9:08 AM
    #8249
    bayareataco
    Jimmy
    Thanks for the info all this thread is helpful.
  10. Aug 15, 2014 at 11:20 AM
    #8250
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    No good for a first gen LBJ. Frankly, assuming that generic ball joint test applies to a first gen is the main reason people push them to the point that they separate.
    I completely agree with CMJ. Here is the test procedure from the FSM. Even it is somewhat lacking in technique and totally misses a very critical diagnostic point. Lets see if anyone can figure it out before someone else risks death.
    CMJ, let someone else give it shot, I think you already know (unless you just can't stand it;)).
  11. Aug 15, 2014 at 11:24 AM
    #8251
    BradyT88
    BradyT88 Well-Known Member
    Isn't lifting your tire in the air and checking for play a wheel bearing test anyway?
  12. Aug 15, 2014 at 11:50 AM
    #8252
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Im guessing you have to make sure there is load on the lower arm :notsure:
    :notsure: Just something I've always done on my cars... Why is the Tacoma different? Is it because the LBJ is inverted?
  13. Aug 15, 2014 at 12:12 PM
    #8253
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I would imagine a maximum of .020" is almost impossible to notice by hand. If you notice play without measuring it, there would have to much more play than that, or at least that's what I would guess.
    Is that what you're getting at?
  14. Aug 22, 2014 at 10:54 PM
    #8254
    Blackdawg
    Monte
    Wyoming/St. Louis
    Photo time! First part of my trip. Lolo Motor way in ID. was nice but very smokey. And of course this is where the LBJ gave out too
    [​IMG]Frank.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet.jpg by Monte Nickles Photos, on Flickr
    [​IMG]Frank-4.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOS by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-2.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-6.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-8.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-9.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-10.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-11.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-13.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-14.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-17.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-18.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-19.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-20.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-21.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-22.jpg by Monte Nickles Photos, on Flickr
    [​IMG]SOSMeet-23.jpg by Monte Nickles Photos, on Flickr
    More photos will be trickling in here through out the next few weeks :http://www.tacomaworld.com/forum/of...09-s-o-s-meet-picture-thread.html#post9077750
  15. Aug 22, 2014 at 11:09 PM
    #8255
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Beautiful pictures man. Wish I was there.
    Dat LBJ tho...
  16. Aug 22, 2014 at 11:12 PM
    #8256
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thanks man. Your gonna need a whole different rig for trips like that :laugh:
    yea the LBJ sucked..whatever. haha all worked out. Was quiet the challenge to get it running again. But we did in a day...somehow..
  17. Aug 22, 2014 at 11:45 PM
    #8257
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    i can only imagine your reaction when that thing snapped the second time.
    ive never seen anyong mangle a wheel/front suspension quite that bad. well done!
  18. Aug 23, 2014 at 7:43 AM
    #8258
    Blackdawg
    Monte
    Wyoming/St. Louis
    I knew what had happened the millisecond it did. After I wrestled it into the ditch I was pretty calm about it. More concentrated on getting out
  19. Aug 23, 2014 at 7:57 AM
    #8259
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Did it fubar both the tire and rim? Looks like it fucked up the UCA too. Either way, glad it happened where it did and not like where we stopped to fix mine. :eek: I would've been completely fucked haha
  20. Aug 23, 2014 at 8:06 AM
    #8260
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yea a break on Shoshone like that would be the biggest pain in the ass ever... Which it almost did cuz the week before monte broke his drivers side lbj we were in shoshone :eek:
