Sander's '02 DC Build
Discussion in '1st Gen. Builds (1995-2004)' started by sander1036, Aug 23, 2011.
  1. Nov 18, 2012 at 4:42 PM
    #201
    sander1036
    sander1036 [OP] Well-Known Member
    Steve
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    did you just say flat bed :popcorn:
    I 'll probably just find the equivalent of the 5150 in a rebuildable shock then.
    If Jerry hasnt had problems with it then no one can :cool:
  2. Nov 18, 2012 at 4:45 PM
    #202
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    well thats why i said foxes :p haha cause they are rebuildable and revalvable.
    No..not really a flat bed..just..a little..trimming..
  3. Nov 18, 2012 at 4:54 PM
    #203
    sander1036
    Steve
    :spy: by little you mean..... 35's..... :cool:
  4. Jan 21, 2013 at 7:05 PM
    #204
    sander1036
    Steve
    Went wheeling a weekend ago :mudding:
    100_1206_zps0f4869fa_62ad9e06669b7a9f8e7ee9fcd5dd084d8de1b825.jpg[/QUOTE]
    Sank the truck :( :pout: :(
    Removed the carpet there was still puddles in the cab 2 days later :(
    And I replaced my lower idler pulley due to it being seized :eek:
    I still need to pull my starter and clean it, its starting to fail now after the incident.
    Considering leaving the carpet out and raptor lining the inside Im probably not gonna put the carpet back in so I might as well
    O and I also have a $250 gift card to anything CBI makes anybody have any ideas
  5. Jan 21, 2013 at 7:11 PM
    #205
    white toy taco
    white toy taco 505 Member
    Albuquerque, NM
    '06 OR and '02 OR (sold)
    ^^damn thats crazy! good thing you have a snorkel otherwise that could have been worse
  6. Jan 21, 2013 at 7:17 PM
    #206
    sander1036
    Steve
    I feel like if i didnt have the snorkel, I would not have tried to go through that and gone around it.... but im glad it wasnt worse
  7. Jan 21, 2013 at 7:23 PM
    #207
    white toy taco
    Albuquerque, NM
    haha yea true that.
  8. Feb 5, 2013 at 11:46 PM
    #208
    ToyComa84
    ToyComa84 Well-Known Member
    Matt(hew)
    "flatland"
    03 prerunner sr5
    plasti dipped wheel caps,
  9. Mar 2, 2013 at 7:11 AM
    #209
    sander1036
    Steve
    just ordered a trail gear rear frame box kit and shock relocation kit
    http://www.trail-gear.com/pdf/120165-1-k.pdf
    I guess Im gonna install my dakars and shackles, then get this kit installed, and then decide what size shocks I want to run I figure 10" travel but if I can fit 12" travel shocks then I think I want to go that route
  10. Mar 2, 2013 at 7:27 AM
    #210
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wouldn't bother with 12s unless you have 1'' lift or longer shackles.
    10'' mounted in a /\ fashion will give you the same travel as a 12'' mounted l l
    Plus really you'll need 4.5-5.5'' bump stops to keep from bottoming out 12'' shocks. 10s i think you'll be fine with the stock ones so you don't loose up travel.
  11. Mar 2, 2013 at 7:37 AM
    #211
    sander1036
    Steve
    Well I'm gonna get 3/4" of lift from the new shackle and then probably 3" from the Dakars and AAL... ahh it will be easier if I just go 10" I dont wanna lose up travel
    Im still on the ropes about angles of the shock but ill probably just end up with the angled setup versus straight up and down layed back
  12. Mar 2, 2013 at 7:42 AM
    #212
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well im at like 5'' rear lift i think with 10'' in stock location and i still droop pretty damn good and stuff well too.
    if i was /\ i would droop even better..would be nice.
    Really an 11'' shock for me would be a bit better. 12s i think are just a bit too long after seeing silas do them.
  13. Mar 2, 2013 at 7:49 AM
    #213
    sander1036
    Steve
    Yeah I'll be fine with a 10" maybe one day if I go with a flat bed I'll go bigger but that will come with a SAC :eek:
    Do it!! if you fab everything yourself it would be cheap ;)
    the trail gear kit was 120 bucks comes with two crossmembers and the plating to box the frame on either side :cool:
  14. Mar 2, 2013 at 7:54 AM
    #214
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea i would...
    but i have a new plan for the rear :spy:
    so not gonna really bother..LT all around is next for me. Just gonna run what i have till it breaks and/or i can afford the setup i really want.
    you might go SAS?
  15. Mar 2, 2013 at 7:58 AM
    #215
    sander1036
    Steve
    That should be interesting :popcorn:
    possibly but not till I have a second vehicle and plenty of money I guess in reality it all depends on weather I stay here in PA or not
  16. Mar 2, 2013 at 8:03 AM
    #216
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    this truck is
    :bananadead:
  17. Mar 2, 2013 at 8:04 AM
    #217
    Blackdawg
    Monte
    Wyoming/St. Louis
    yes it shall.
    sould would a SAS dbl cab :cool: haha
    SAS is just too tall for me and a bit too hardcore, i don't need it. LT will give me plently of wheel travel and take me many a place.
    Ill be interested in this kit though..might do it..but probably wont
    :popcorn:
  18. Mar 2, 2013 at 8:20 AM
    #218
    sander1036
    Steve
    Youz stay out of dis
    shes still kickin NY STYLZ
    :cool:
    :cool:
    If I do go SAS its gonna be as low as phisically possible
    LT should be awesome! I just cant use it over here
  19. Mar 8, 2013 at 7:15 AM
    #219
    brutalguyracing
    F.U> GUYZ
    broken mods
    This thread sucks
  20. Mar 8, 2013 at 9:12 AM
    #220
    sander1036
    Steve
    Yeah the OP in here doesn't do much around here... he just stockpiles parts on the shelf.....
    Wait a minute :spy:
