Greensystemsgo's Build Thread
Old 09-14-2011, 06:53 PM   #21
Self Proclaimed first gen expert :doh:
Greensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shed
Greensystemsgo's Avatar
Greensystemsgo's Tacoma Gallery
Originally Posted by TheGloryFades View Post
They look much better than they did that night at Walmart
Hell yeah they do! I need to make a new adjuster but that's a different day.
Old 09-15-2011, 05:27 PM   #22
TACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shed
Firefighter:
TACOMABOSS's Tacoma Gallery
no Loctite? why not? btw. head lights look way better. you cleaned the inside?
Old 09-17-2011, 09:52 AM   #23
Wasnt aware i needed any. i used red, the strongest.
Yup, took em out, threw some water and shook em around.
Poured it all out, shoved a papertowell inside and used the airhose to blow water all around, changed out papertowels, that got all the water out in a few minutes, now their awesome
Old 09-18-2011, 06:50 PM   #24
got into a little wreck. smooshed my, and her bumper. my fault. but id like to claim outside sources.
info here http://www.tacomaworld.com/forum/ari...c-etc-etc.html
depending on how it goes, I may get enough for both bumpers, and maybe even sliders. Id be building them with brian and robert, so labors a decent price
Old 09-23-2011, 10:09 PM   #25
so, as im cruising around without a bumper, i decided to put turn signals into my corner markers. followed this guide, which wasn't really necessary. http://www.lieblweb.com/blinkerconversion.html i just paired up either ground wire on the ground tab, and put the brighter filament for the turn signals, weaker for driving lights.
On a side note the breaks are holding up great, all solid lines
imma take off my badges here soon to put on the second gen badges i got.
Old 10-03-2011, 09:29 PM   #26
Badges are off.
And bumper is in the process. Got my old man all excited for it which is great, hes great with attention to detail and is the perfect mentor through this, as neither one of us have ever done a bumper. hes given me a 2 1/2" thick tube hitch, which were gonna use as a cross member from frame rail to frame rail, also on board are 1/4" brackets, which were gonna use as, well brackets to the bumper mounting points. The hitch part will stay, will be sunken in, but available as an attachment point in the event of recover, or trailer maneuvering.
Also, my rear diff cover is spitting oil bad. i need to apply some rtv, anyone whos done this, how hard is it?
Old 10-09-2011, 09:12 PM   #27
put on second gen badges, and plasti dipped them.
Also did the locker anytime mod.
This week imma redo the seal on the rear diff cover/third member cover thing, its leaking, bad.
Old 11-13-2011, 11:53 AM   #28
head a rear bearing crumble on me. pulled it and got it changed relatively quickly for three guys whom have never done a toyota rear end.
had to cut off the abs speed sensor cuffs, (like the fsm states), and then pounded axle on the ground to pop the hub outta the bearing. had some pipe layin aroudn that fit perfectly to pound on the new cuffs and bearing. just need to bleed brakes after work and all is well
Old 11-13-2011, 12:11 PM   #29
Senior member
Fiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shedFiolo is one of the sharper tools in the shed
Fiolo's Avatar
Fiolo's Tacoma Gallery
Looks good man, keep up the good work, One thing I would do is put the Toyota emblem back on the grille
Old 11-14-2011, 11:50 AM   #30
yeah, soon. unfortunately aesthetics is so far down the list.
here in a few weeks imma rebuild the rear end
also, got axle back in, brakes bled, all is well. all in all a 4 hour job if you have never done it before. I did NOT take it to a shop to be pressed. i had perfect fitting pipe, and slammed it down on ground.
Old 11-15-2011, 08:56 PM   #31
scalfee90 is on a distinguished road
scalfee90's Avatar
scalfee90's Tacoma Gallery
Originally Posted by Greensystemsgo View Post
Little update, this happened.
backing out of a slot at frys food. Had to call for help, jacked her up, put in 4 bolts and drove her home. It busted the cv boots, and break lines.
Had to retorque the damn bolts, but this time with loctite. That side was easy.
The otherside was also lose, busted a head off of number three bolt. After a failed extraction i drilled it larger and put in a 16mm grade 8+ bolt. Then changed break lines, put in stainless woven lines. All in all helluva a oops.
This happened to me about a month ago, and what do ya know we have to same truck lol
Old 11-15-2011, 10:27 PM   #32
haha ha yeah. use stock hardware, or new grade 8 hardware. NOT the shit that came with the duralcrap ball joints.
Old 11-17-2011, 10:28 AM   #33
did the ujoint and carrier bearing on that piece of drive shaft. decent little job.
Old 12-01-2011, 09:30 PM   #34
Scored an awesome job, be prepared to see this truck really start to shine
Old 12-01-2011, 09:34 PM   #35
Firefighter:
cant wait
Old 12-01-2011, 09:51 PM   #36
just got to play with locker anytime mod. pulled off road to jot down some information as i was talking to a client. I only planned on pulling half way off the road, but as soon as i did i sunk and hit the burm of dirt, But that atleast straightened me out. so i took the information i needed and when i gassed it i didnt move at all, but one wheel spun. so i locked it, crawled out at 3000rpm going 2mph, and technically played in mud
Old 01-12-2012, 10:57 AM   #37
Gas day is the worse day...
my optima, with wood shim.
slim cubby hid!
stainless break line, and stock uca, for now
5125 and all pro expo
the coveted diff lock
custom radiator mounts, and no toyota badge
2nd gen blacked badges
TRD OFFROAD FOTHAMUCKER!
rear end
22lr casings on my straight rear bumper even after getting rearended
trailer wire mess that ill clean one day, aaaand the license plate light dangling, i have one working
leaky rear diff, and stupid ebrake rise bracket.
aero turbine at2525
this is normal right, to have holes in your bed
front half of driveshaft, and disgusting scraped clean t-case
back view
torn passenger side cv boot
torn driver side cv boot
currently how she looks with the bug in the background
fresh driveshaft from az driveshaft. 490 bucks for new back half, and complete rebuild/balance
broken double-cardan
in back of truck ready to go
Old 01-12-2012, 11:18 AM   #38
G scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shed
G scott04's Tacoma Gallery
Ah yes very good
Old 01-12-2012, 12:10 PM   #39
Originally Posted by G scott04 View Post
Ah yes very good
ummm which part?
Old 01-12-2012, 12:14 PM   #40
The new driveshaft of course
Jsmarine's Build Thread jsmarine 2nd Gen. Builds 77 01-24-2015 12:25 PM
Mike686 Build Thread mike686 2nd Gen. Builds 46 01-17-2013 04:34 AM
My Build Thread CAN8EN 2nd Gen. Builds 11 07-29-2011 06:20 AM
My Build Thread rberumen2 2nd Gen. Tacomas 4 02-12-2011 03:19 PM
build thread help 98fourbangertaco New Members 0 06-23-2010 07:31 PM
