Greensystemsgo's Build Thread
Old 01-30-2012, 11:03 AM   #41
Self Proclaimed first gen expert :doh:
Greensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shed
Greensystemsgo's Avatar
Greensystemsgo's Tacoma Gallery
Originally Posted by G scott04 View Post
The new driveshaft of course
your just happy cause i said shaft.
no new news as of late, another cel, but its the stupid coil, and only pops every 1000 miles or so. still roughly 16mpg. ugh. stupid 4.10's
Old 02-07-2012, 10:40 PM   #42
Ordered front and rear master rebuilds, along with front and rear 4.56 nitro gears. Wooo!
Also picked up a widow maker jack and a decent tow strap. About to send ltr ucas in for a rebuild. Still need to get a bumper. Also, lca bushings are meh. And cvs are torn. Again. Imma get diff drop before I change them out. Holly bananas.
Old 03-10-2012, 09:53 AM   #43
wow where to begin.
Light racing ucas are on they're way in from CO.
Master rebuilds and 4.56's are waiting to be picked up. ZUK will do the rear, the front by just diffs OR az diff. probably flip a coin.
while the front is out, the ucas will be installed, along with new lower bushings. and new steering rack bushings. and probably body bushings. cv's are torn, so also a diff drop.
got supplies to do a satoshi
and my personal favorite, ordered an elite plate front bumper!
Old 03-18-2012, 11:43 PM   #44
new stereo and speakers!
head unit KENWOOD KDC-BT948HD http://www.crutchfield.com/S-5ZxjNKK...C-BT948HD.html paid 120
speakers, x4, Polk-Audio-db651s http://www.crutchfield.com/p_107DB65...ml#details-tab paid 50 a set of 2
what a fucking mess.
asshat before me wired it like this,
Pioneer unit, plug with 6 inches of wire, 2 inches of misc wire, 6 inches of stock wire, x ammount of custom wiring, three different kinds, then last 6 inches were stock wire, and then speakers. ALL of these connections were simply electrical taped. and not even alot.
wired mine up like this, kenwood unit, plug with 6 inches of wire, lg speakerwire, speaker.
omfg what a different, surprisingly the asshat before me had 60w rms 200w peak pioneers in before, but they appear to be a walmart only model. im sure all the electrical tape was NOT helping.
After install we couldnt get hot line to be hot, after 2 hours of triple checking shit, realized the fuse and popped. awesome.
also, redid bottom of seat while i was at it, the wires had failed so i rewired em and boom. better.
also, did the satoshi!
http://www.tacomaworld.com/gallery/d...live2xrlnh.jpg
headlights need to be washed out again, and maybe better sealed. i want clears but $$$$
Old 03-26-2012, 01:50 PM   #45
Changed alt and charge wire from fuse block to alt itself. Woot.
Old 04-02-2012, 10:09 AM   #46
what a busy day off! washed out headlights, secured adjusters, cleaned up driving lights/turn signal wiring into a single wrap to the corner marker. Fixed the horn, loose relay.... also washed out headlights and corner markers again. good stuff. oh and this morning, cleaned the door switch on the driver side, it actually works! so now to order some key fobs!
Old 05-17-2012, 01:00 AM   #47
this week in pictures....
final notes. new wheels and elite bumpers. elites are nice, not worth their price though, even though i got on the group by. for the rear, it was advertised hardware and license plate bracket, neither of which i got. the bracket was bent, but when tightened was pulled straight.
as for the front, between my minor accident, no directions/measurements for cutting, and needing to bend and weld shit, took roughly 9 hours to install the front. the top hoop is cool, but blocks the hipoint lift points.....
new wheels!
Old 05-21-2012, 05:30 AM   #49
Unfortunatly the pdf Id reviewed neglected to mention how much to cut.
As for the accident, this was pre badass bumper. Bent the bracket just enough to suck.
Old 05-30-2012, 04:05 AM   #50
replaced the cv's.
again. this is really getting old. fuck.
Old 06-06-2012, 11:30 PM   #51
Old 07-03-2012, 08:06 PM   #52
193k miles.
pcv, fuel, oil/filter, topped off coolant, soaked up clutch fluid and put in fresh dot3/4 combo fluid. also currently scrubbing air filter. pos spectre.
Old 07-03-2012, 08:24 PM   #53
D SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of light
D SPAID's Tacoma Gallery
This thread sucks...
Old 07-03-2012, 08:50 PM   #54
meh, i think the difference between a good thread, and a boring thread is whats being done to the truck.
In erics case, hes doing a lt setup. thats taken almost a year so far. with very little known progress.
in my case i do upkeep, with big plans to come. solid axle swap anyone?
how about some sexy ladies?
Old 07-03-2012, 09:21 PM   #55
Xbox GT: Yodaman8806
Underdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shedUnderdog777 is one of the sharper tools in the shed
Underdog777's Avatar
Army: Ground Support Shop Foreman/HAZMAT NCO, 1916 SPT BTN, 699th Maintenance Co.
Underdog777's Tacoma Gallery
Nick,
I was drunk yesterday. It was mostly Moose's fault. But to answer your question I am bailing on the 88 because I still want to hump my Tacoma before bed every night and should have gotten a car instead of the 88. If I cant sell the truck and axles as a package deal then we will negotiate a price for the 85's.
Old 07-03-2012, 09:29 PM   #56
Sexy ladies veddy nice
Old 07-18-2012, 02:12 PM   #57
I need to go return some videotapes...
Seabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shedSeabass is one of the sharper tools in the shed
Seabass's Avatar
Seabass's Tacoma Gallery
Old 07-25-2012, 10:16 PM   #59
Once he replaces his cv's 4 more times
Old 07-25-2012, 10:42 PM   #60
Originally Posted by superswamper003 View Post
So when do you plan on doing the sas?
bahahahah
once it stops raining, and i can get out and make some money.
d44 or d60, leaning towards full width d60, front and rear.
still indending on overland expo rig, not so much as an extreme crawler.
Jsmarine's Build Thread jsmarine 2nd Gen. Builds 77 01-24-2015 11:25 AM
Mike686 Build Thread mike686 2nd Gen. Builds 46 01-17-2013 03:34 AM
My Build Thread CAN8EN 2nd Gen. Builds 11 07-29-2011 05:20 AM
My Build Thread rberumen2 2nd Gen. Tacomas 4 02-12-2011 02:19 PM
build thread help 98fourbangertaco New Members 0 06-23-2010 06:31 PM
