Sluggo: The 4 banger build
Discussion in '1st Gen. Builds (1995-2004)' started by IDtrucks, Dec 17, 2011.
  1. Apr 23, 2013 at 8:45 AM
    #181
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    From what I understand, the diff drop helps with 1st gens but doesn't do crap for 2nd gens.
    Might have a difficult time fitting some aftermarket skid plates though.
    I think it's smiling at you Monte...
  2. Apr 23, 2013 at 8:51 AM
    #182
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    :rofl:
    And ya, that is what I have heard as well, that diff drops are pretty much useless for 2nd gens. Also that the earlier tacomas handle lifts and tires better than later first gens. At least that's what monte mike and I have determined. And I don't plan on adding aftermarket skid plates realistically. Got a hundred other things I would rather spend my mine on
  3. Apr 25, 2013 at 11:17 AM
    #183
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    The hunt is on for a TRD Rear axle :spy:
  4. Apr 25, 2013 at 4:37 PM
    #184
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    wait so you mean your boot tear basically sealed itself up? that's impressive!
    and so far holding up fine! No extra tearing that I can see. Will be going out to the desert on saturday to ride dirtbikes and braaap with my buddy as we try out his new baja bug so we shall see what happens to it then.
    is this now sort of a race? who ever's boot blows first buys the other a beer or something.
  5. Apr 25, 2013 at 4:40 PM
    #185
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    lol. that sucks. you can just see the clock ticking away on your poor cv boots.
  6. Apr 25, 2013 at 8:10 PM
    #186
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ROFL! That is exactly what I do!
  7. Apr 25, 2013 at 10:02 PM
    #187
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    just let it happen...
  8. May 4, 2013 at 5:20 PM
    #188
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I have officially spent money, so project mini rock crawler has begun. I got a non damaged locking third out of a bent rear axle and the full wiring harnesses front to back. Next step is buying an 8" housing for my third and abs axle shaft and im getting 4.56 R and P to match up with the front. Im going to re gear the third, swap over brake lines onto the axle housing im going to get, swap in the abs axle shafts into my hubs. Button it all back together, throw it under the truck, and the plan is to have it all done by moab!
    E locker third. Appears to be all good. No shavings in the housing, side gears spin at different directions, splines are all good, locker axtuator is nice and tight.
    [​IMG]ladies and gents, this is how you trd third.
    Next "big" hurdle is going to be figuring out wiring. Have to figure out how to get the 4 wires out of the diff RR switch to the connect to the correct wires in the jumble of wires coming out of that white harness to the left, and run power to the locker. Pretty sure the locker has 6 wires...and the switch has 4 coming out of it. So i have to pour over diagrams till I understand it haha.
    The only damage we could fine anywhere on the third. A little bit of scouring from the splines. They are only in this one spot though.
    locker wiring for future refrence. thanks ben!
    http://www.yotatech.com/f2/e-locker-wiring-help-please-247763/
  9. May 4, 2013 at 5:39 PM
    #189
    Slodgetto
    Slodgetto Über Posre
    Silas
  10. May 4, 2013 at 7:04 PM
    #190
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    of course andy comes in bringing debbie downer news...said if the carrier bearing things got tweaked even a thousnadths of an inch the bearing will wear prematurely and ill still be fucked. guess i need to get that checked. please dont screw this project by a thousandths of an third member, ok?
  11. May 4, 2013 at 7:27 PM
    #191
    BradyT88
    BradyT88 Well-Known Member
    Just realized I am not subbed to this thread...
    So subbed for the thousandth of a failure ;)
  12. May 4, 2013 at 10:03 PM
    #192
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rofl:
    that is how my failures are measured now
  13. May 6, 2013 at 12:41 AM
    #193
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    i need this... make me one :D
  14. May 8, 2013 at 9:26 PM
    #194
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    lol im surprised it turned out as well as it did. still need to get some sound deadener for it
    Got the wiring harness and my factory switch almost done, just have to tap in and run power to it and finish off wiring the switch light, then the locker will work. Then I have to cover the harness with the plastic cover and secure it to the factory and run it back to the rear end.
    Also my rear u joint is squeaking like a mother fucker, i dont want to drive it lol. Have to get it greased like tomorrow.
    my locker words flawlessly...
    :brianr:
  15. May 8, 2013 at 10:09 PM
    #195
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
  16. May 8, 2013 at 10:19 PM
    #196
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Buy a new u joint. Cheap and easy to do. I'm sure Konsta can do it.
  17. May 8, 2013 at 10:26 PM
    #197
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    ....or i can grease it lol
  18. May 8, 2013 at 10:27 PM
    #198
    Blackdawg
    Monte
    Wyoming/St. Louis
    If it's that bad now. Want help and you'll risk blowing it or tweaking the drive shaft up pretty bad too.
    It's only 30 bucks.
  19. May 8, 2013 at 11:06 PM
    #199
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    just started 4 days ago, probably needs grease. ill see
  20. May 8, 2013 at 11:09 PM
    #200
    Blackdawg
    Monte
    Wyoming/St. Louis
    What's your rear angle look like??
