My Build... so Far
Old 03-19-2012, 02:26 PM   #21
WV, VA, NC places i roam in the Yota
Jsimp will become famous soon enough
Jsimp's Avatar
Jsimp's Tacoma Gallery
Originally Posted by YotaKid62 View Post
Haha, wow, that makes me feel cool. Your grandma had the same truck lol. but yea I can take some more sub pics, Its not a box though, I just built the covers.
i stand corrected she still has the truck. her second car is a porscha. i wouldnt look at it in a bad way id just say my grandma is cool for having a tacoma as sick as yours..
Old 03-19-2012, 03:47 PM   #22
YotaKid62 [OP] YotaKid62 is offline
Dirty mall crawler
YotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shedYotaKid62 is one of the sharper tools in the shed
YotaKid62's Avatar
YotaKid62's Tacoma Gallery
Hehe. Hey i built a light bar and was wondering how yours is mounted. I wanna make sure I know what I'm doing before I go drilling holes in my roof or anything.
Old 03-19-2012, 07:15 PM   #23
Jsimp's Avatar
i replied to your post on my build
Old 03-19-2012, 09:17 PM   #24
Dirty mall crawler
YotaKid62's Avatar
OOOk, so I went back in today to try and fix my rattles and shore everything up a little. I drilled a hole through the middle of the enclosure and all the way through the bottom of the truck and stuck a bolt through it to stabilize it a little. I comes out right above the gas tank so it a bit tough to get to, but do-able. Sorry I never took a pic of that. But on the driver side I've had a horrible rattle goin and being that I couldn't figure out how to get a hole in the bottom of the truck where I need it, I took a piece of all-thread and threaded a nut and washer up against the underside of the enclosure and another on top to help hold it in place.
The all-thread is just butted against the bottom of the enclosure so make sure its tight or it'll sound like a jackhammer in there when you turn your music up. then just cut the extra off with a hacksaw and put the carpet back.
It's not pretty by any means. I would recommend sanding the wood down good and at least painting it to match the interior. Also some day i plan to router the under edge of the covers to help them set in better. Oh, and there will be a bracket that holds the jack that you may have to grind out, depending on the size of your magnets. I did, and its by far the hardest part of the project.
And I used speed nut clips and machine screws to fasten them down. my biggest regret is not getting bigger ones. I can't remember what size they are, but they don't hold like I think they should, but the do the job. No serious issues so far. Just make sure you measure and get ones that fit the holes well. And make sure you take the plastic frames out when you do this so you can use the holes that are already in the enclosure!
(sorry for the crappy pics)
I just put the wires under the floor mat. If you REALLY wanted to you could cut a slit in your carpet to run your wires through. I don't have an issue with this though.
...and there is a hole in the enclosure you can run the wires through. Just pull up the carpet, run your wires, and put it back.
... and the finished product.
With the seats down you'd never notice there were subs in there (aside from the serious vibrating on your ass when they're turned on). But It's a good idea to turn them off when people are sitting there to prevent any damage.
Amp just sits under the seat (passenger side should work too if you don't like it this way, just reverse all the wiring and stuff)
some other pics of the wiring... in the firewall there's a rubber plug you can slit to run the power wire (not pictured, its under the floor mat there) through for your amp.
Old 03-19-2012, 09:31 PM   #25
Jsimp's Avatar
what size are your subs? i have a 12 i dont think it will fit. ill have to cut a lot.
Old 03-19-2012, 09:47 PM   #26
Dirty mall crawler
YotaKid62's Avatar
If you've got 12's and you want space, I would sell them and get smaller. I have 8's and i've seen it done with 10's but it would be tight. Plus 12's would be too much for that enclosure. It would rattle so much and probly sound crappy. My 8's rattle my bedliner and license plate frame, so it sounds a little retarded outside the truck, but it sounds great inside. If you want some more detail I made a tutorial thread for it. the link is in my sig. check it out.
Old 03-19-2012, 09:56 PM   #27
Jsimp's Avatar
yeah my 12 started cracking the glass in my 4runner, i put it in the truck for a week or two and it was crazy. im trying to sell it on craigslist and my birthday is in 3 weekes so im getting all new speakers im gona have my little tocoma as loud and clear as possible
Old 03-19-2012, 10:43 PM   #28
Dirty mall crawler
YotaKid62's Avatar
Yea, 8's is the way to go. I also wanna get 6x9's in my doors and some tweeters. Then you could also get like some 8x8's to go in the back sides instead of the factory speakers. That would pump out some nice bass and sound clear too. What sort of head unit do you have?
Old 03-20-2012, 10:41 AM   #29
Jsimp's Avatar
i have an alpine. there is a picture in my build thread. i want a 7" touch screen bad. pioneers are sick but are 600 ): i like the ones that the screen flips out. but my cusin had one and it broke off from off roading.. so i dont know about one of those but they are cheaper.
Old 03-20-2012, 10:51 AM   #30
Dirty mall crawler
YotaKid62's Avatar
Ha, i have a 200$ kenwood. I wanted better one like alpine or kicker, but was pinched for money, like i still am, and wanted my fried factory radio fixed on the spot. I don't mind the kenwood though, it gets the job done, and i can plug just about anything into it.
Old 03-20-2012, 10:56 AM   #31
Jsimp's Avatar
yep im the same way. i like my alpine its really nice i just want the big screen!
Old 03-20-2012, 07:22 PM   #32
Dirty mall crawler
YotaKid62's Avatar
I would too, but I LOVE the little cubby hole that was installed under my stereo since its smaller than stock.
Old 03-26-2012, 09:12 PM   #33
Dirty mall crawler
YotaKid62's Avatar
So I got an itch to do something to my pickup the other day so I picked up some black spray paint and rim clearcoat...theres always something you can do with that stuff. I was never really into my chrome door latches, so I painted those.
Hey, I finally found a good use for that ridiculous pile of walmart bags piling up in your pantry!
And my fender flares had some rock chips so I painted those too.
(its kinda hard to tell much of a difference, but they look better in person)
Before:
After
Notice how in almost every one of my pictures there's a freakin' cat somewhere. Oh well they keep the mice down, and they're friendly.
soon to come, a set of 15x10's for 150$, pretty hard to beat that i'll paint black, and then wait for some 33's to come along.
Old 04-01-2012, 10:43 AM   #34
Jsimp's Avatar
did you just paint the whole door handle? as in the picture how you just taped around it? i need to do this to mine. i just need to get paint.
Old 04-02-2012, 05:36 PM   #35
Dirty mall crawler
YotaKid62's Avatar
yea just do the whole thing so you dont have 2 different shades of black.
Old 04-02-2012, 05:53 PM   #36
Dirty mall crawler
YotaKid62's Avatar
Had another truck day this weekend. I got up and hopped on the interstate for about 30 miles to pick these up.
$150- I've been told eagle alloys, American racing outlaw series, but idfk exactly what they are. 15x10 with 3.5 BS aluminum rims.
It wasn't until after I got them that I discovered one had about a 1/2" long crack going down from the edge of the bead. I don't have a pic, but it isn't bent, just cracked (don't ask how, I have no Idea). I think a mig welder at school with an aluminum spooler should do the job, and once they get balanced they should be fine.
Cleaned 'em up with a drill wire wheel.
Got a smaller one for touch up.
Then sandpaper, and paint thinner.
Before:
After
About 3 coats primer, 4 coats paint, 3-4 coats wheel coating later:
(note: i didn't think it would pay to do the whole wheel, so I just did the outside face. Why paint anything but the part you will see?
Gonna get them mounted and balance this weekend hopefully, but i'll be waiting on tires awhile. More pics to come!
I've heard rumors about better brake performance because of a BPV (I think that's what its called) so I quick fabbed one of those. Its ugly as hell, i know, and the holes are a little crooked, but it works.
Installed
So far i haven't noticed a real difference in braking performance. Idk if everyone else on here is smokin' somethin' or its just me , but i've noticed the B.A.M.F ones move it over sideways a bit too, that might make all the difference, but i'm happy with my brakes, so whatever.
...Well thats the update, stay tuned everyone.
Next mods to come (hopefully)
-Cheapest set of 33x12.50 m/t's I can find
-Trail gear low profile bumper, or maybe the all pro.
-fabricate some rock sliders
-Pro dry air filter
-Breather extensions
-1 or 2" body lift
-Possibly some window tint
Old 04-04-2012, 10:10 PM   #37
valon5150 will become famous soon enough
valon5150's Avatar
valon5150's Tacoma Gallery
Sick sub placement man! Never thought of that
Old 04-04-2012, 11:08 PM   #39
Dirty mall crawler
YotaKid62's Avatar
Ahhh, I cant think of it off the top of my head. Its just some duplex clear coat I found at oreilly's that said it was meant to protect wheel paint.
Old 04-06-2012, 03:27 PM   #40
Dirty mall crawler
YotaKid62's Avatar
Well I FINALLY got some better (black) rims installed!Here they are, 15x10 with 31x10.50 on them.
I definitely love the wider stance and the more agressive look they gave me. Hopefully in a couple months i'll have some 33's on there too.
Future mods : 33-12.50's.
front bumper and armor
ARB front air locker(in the distant future)
light bar of some sort.
Breather extensions.
Throttle body spacer
Pro dry air filter.
doing a my build pa blaster 2nd Gen. Tacomas 3 02-08-2012 12:01 PM
