Eric's Supercharged Shit-box
Discussion in '1st Gen. Builds (1995-2004)' started by Supra TT, Dec 30, 2011.
  1. Dec 30, 2011 at 8:08 PM
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    List of shit after swap
    OIL PAN
    12101-75060 Pan, Toyota Dealer, $100.00
    15104-75020 Strainer, Toyota Dealer, $80.00
    15147-75020 Gasket, Oil Strainer, Toyota Dealer, $30.00
    11494-75010 Plate, Oil Hole, Toyota Dealer, $30.00
    91651-60614 Bolts (Oil Hole plate) (QTY: 4), Toyota Dealer, $15.00
    00295-00103 FIPG (Form in Place Gasket material), Toyota Dealer, $15.00
    STEERING
    Reid Racing Ford Knuckles, Parts Mike, $460.00
    Hi Steer Arms w/ studs, Parts Mike, $220.00
    Tie Rod and Draglink, Sidco 4x4, $155.00
    IFS Steering Box 1989-1995 4x4, Ebay, $125.00
    Borgeson Steering Shaft 450036, Summit Racing, $75.00
    Borgeson 013452 and 014909, Summit Racing, $160.00
    Pitman Arm, Parts Mike, $50.00
    Kartek 11/32" 29 Spline U-joint, Kartek, $110.00
    SUSPENSION
    Front Leaf Springs 5", Marlin Crawler,$342.00
    FOA Emulsion Shocks (4), FOA Shocks,$552.00
    FOA Shocks Charged, Sidco 4x4, $100.00
    F/R Ubolt Flip Kits, Parts Mike,$100.00
    9/16" Spring Hanger (2), Parts Mike, $34.00
    9/16" Shackle Bracket, Parts Mike, $42.00
    Shock Bracket Pair (2), Parts Mike,$36.00
    Shackle Hanger Kit Front, Parts Mike, $50.00
    Shackle Hanger Kit Rear, Parts Mike, $35.00
    Spring Perch Set (2), Parts Mike, $30.00
    Shock Tower Set, Parts Mike, $36.00
    AXLE
    Chromoly Right Side Axles, Superior Axle and Gear, $296.00
    Chromoly Left Side Axles, Superior Axle and Gear, $267.00
    Warn Premium Locking Hubs, Ebay, $80.00
    CTM U-Joints, Longfield, $315.00
    Front Gears 5.38, Superior Axle and Gear, $176.00
    Powertrax No-Slip Front, Just Differentials, $450.00
    Powertrax No-Slip Rear, Just Differentials, $450.00
    Rear Gears 5.43, Superior Axle and Gear, $208.00
    Frame Plating, Ballistic Fabrication, $112.00
    Front Bearing Kit, Superior Axle and Gear, $122.00
    Rear Bearing Kit, Superior Axle and Gear, $90.00
    Rear Frame Plates, Domello Offroad, $120.00
    D44 4:10 Carrier, Sidco 4x4, $50.00
    Toy Flange, Sidco 4x4, $50.00
    BRAKES
    Front Rotors, O'Reillys, $70.00
    Front Pads, O'Reillys, $25.00
    Front Calipers, O'Reillys, $25.00
    F/R Steel Braided Hoses, Summit Racing, $50.00
    Brake Adapters, Sidco 4x4, $50.00
    Brake Fittings, Sidco 4x4, $50.00
    MISCELLANIOUS
    4.5" 9/16 Bolts (20), Sidco 4x4, $50.00
    Stuff, Sidco 4x4, $100.00
    Toyota Long Slip Drive Shaft Custom, Sidco 4x4, $100.00
    WHEELS
    Goodyear MT/R 37/12.5/15R, Craigslist, $700.00
    Tire balancing, Sidco 4x4, $50.00
    New 5 on 5.5" RimsSidco 4x4, $125.00
    FABRICATION
    Sidco 4x4 fabrication work, $2,200.00
    TOTAL $9,363.00
    No first day pictures, but close enough.. Home made snorkel, and some Cooper STT's 31x10.5x15
    Had some small mods, spacer lift, wheelers leaf springs... Nothing special really.
  2. Dec 30, 2011 at 8:09 PM
    Supra TT
    Eric
    Indiana
    After another year or so I realized I hated IFS so much I decided to SAS cuz it's what the cool kids were doing at the time.
    Ford 9" and a Ford D44 HP reverse cut, full width axles from a 1976 F-150.
    Did some cleaning up on a warmer day.
    New tires? :D Practically new 37x12.5x15 Goodyear MT/r old styles.
    Not many pictures of the swap... Long story, shop owner was a cock sucker.
    I brought the truck to SidCo 4x4 in Glencoe, Mn. Last year right around this time. We worked out a decent deal, which I believe is right, but we'll see for when it turns out complete.
    Specs: Simple leaf sprung swap,
    Front Axle-
    -1976 Ford F-150 Dana 44 HP RS.
    -5" lift springs, Marlin Crawler
    -5.38 Gears, Superior Axle and Gear
    -Powertrax No-slip locker, Just Differentials
    -300M U-joints, Longfield axle
    -Warn Premium Hubs
    -Reid Racing Knuckles
    Rear Axle-
    -1976 Ford F-150 9"
    -1.5" lift springs, WheelersOffRoad
    -2" AAL, Fabtech
    -5.43 Gears, Superior Axle and Gear
    I had purchased almost every part myself, leaving all the fabrication to the shop. Shop is providing me a driveline, and steering links.
    I am sticking with the 5 on 5.5" bolt pattern, since I had the matching ford 9" and didn't want to convert everything.
    Throughout this build I couldn't get many pictures due to the shop owners disrespectfulness and wouldn't allow me to get any pictures, not to mention ever time I showed up he never had any progression.
    jubei and ChadsPride like this.
  3. Dec 30, 2011 at 8:09 PM
    Supra TT
    Eric
    Indiana
    Well after I got it back I had to paint everything since the shop never did, even though I asked them too...
    Well after my ass got reamed on the money I just spent I figured I'd go wheel it.
    2nd trip out I found out that the guy who installed it either didn't install my ujoints correct or jesus desended down from heaven and broke my ujoints.
    And this is how is sat for 5 months, broken front end and lonely.
    ChadsPride likes this.
  4. Dec 30, 2011 at 8:09 PM
    Supra TT
    Eric
    Indiana
    Well after the truck sat for 5 months the starter was fried and it had bad fuel. Replaced the starter and through some seafoam in her with 92 clear gas.
    Well 2 or so months went by and I brought it to my brothers to fix the front axle shafts and to tie up some loose ends..
    Yup...
    This is the $175 u-joint after sitting for 6 months............
    New chromoly axles from superior axle and gear
    Now it was time to fab a new mount for the shocks since the stock mounts broke.
    SamSpade, jubei, ChadsPride and 2 others like this.
  5. Dec 30, 2011 at 8:11 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Well then. Bout fucking time.
  6. Dec 30, 2011 at 8:12 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    After seeing your SAS all the time, it's just weird to see your truck with stock size tires and a silly IFS :laugh:
    :popcorn:
  7. Dec 30, 2011 at 8:13 PM
    Supra TT
    Eric
    Indiana
    I got bored... figured I'd post some IFS pics.. I'm thinking about going back to IFS, where all the cool kids are :brianr:
  8. Dec 30, 2011 at 8:17 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    Not to bad
  9. Dec 30, 2011 at 8:21 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    my soul is bleeding
    from jealousy
  10. Dec 31, 2011 at 6:21 AM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    Truck looks good. We will have to catch up with you next time at badlands so my buddy has someone to show him what his 4runner should be able to do.
  11. Dec 31, 2011 at 7:16 PM
    Supra TT
    Eric
    Indiana
    Updated
  12. Dec 31, 2011 at 7:24 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    is there any reason you didn't triangulate your rear shocks?
  13. Dec 31, 2011 at 7:25 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    That looks like my ujoint was...but worse!
    wanna buy me chrome molly?
    lol nice build though
  14. Dec 31, 2011 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nice truck!
  15. Dec 31, 2011 at 7:33 PM
    Supra TT
    Eric
    Indiana
    More triangulation, less effective the shocks become.
  16. Dec 31, 2011 at 10:34 PM
    Mark Washington
    Mark Washington Well-Known Member
    Mark
    Bay Area
    96 Black 4x4 Tacoma V6
    Toytech front coil springs Rancho tundra 9000XL Total caos upper control arms diff drop longger red steel lines rear disc conversion Pro-Comp rear add a leaf 2'' and around 2" shackle energy suspention bushings 3" body lift. Safari snorkal,Magnaflow 2.5'' catback with highflow cat,TRD supercharger with URD 7th injector kit. NGK NGK wires Oem and Denso waterpump pullys Timing belt EBC yellow front pads EBC rotors Motul fluid. Class C Tow hitch and drop hitch sliding rear window 6x9 kickers with pioneer deck 1000watt amp 10" sub B&M shift knob URD short shifterGT Grant steering wheel occ floor Mat cammo seat cover.
    I wish I never put money into my ISF. Nice build so far.
  17. Jan 1, 2012 at 1:10 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    it is about time you made one, but nice build thread!
  18. Jan 2, 2012 at 7:33 PM
    Supra TT
    Eric
    Indiana
    No on the chromoly axles lol
    Thanks :cool:
    I agree, I wish I just went straight SAS. But people gotta start somewhere and SA is a completely different wheeling experience, better that it.
    I was Jk haha, couldn't pay me to go back to IFS. I got my 08 that is IFS, close enough :cool: My truck is kinda lacking a true build but since the SAS I've been documenting more shit... More fun really :D
    Thanks!
  19. Jan 3, 2012 at 2:42 PM
    Supra TT
    Eric
    Indiana
    Only reason I took the 44 was because my room mate's Dad who had a mechanic shop was going to scrap the axles, so I gave him $300 for them. And well it was perfect axles for what I thought I was going to get into. LITTLE DID I KNOW..............
  20. Jan 3, 2012 at 2:50 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    Nice build :cool:
