45acp’s DIVORCED build!
Old 01-15-2012, 04:36 PM   #1
45acp [OP] 45acp is offline
Paint me back in Wyoming again...
45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed45acp is one of the sharper tools in the shed
45acp's Avatar
45acp's Tacoma Gallery
As of 03/15/15
3link adventure-2.jpg by Monte Nickles Photos, on Flickr
3link adventure-26.jpg by Monte Nickles Photos, on Flickr
The basic direction I'm currently taking the build (subject to change based on ADD or a whim... or both... or f#$k-ups... )
CHASSIS
- 122"-123" Wheelbase
- Fully tubed/caged front to back
------ 2" x .120" wall DOM main cage
------ Various other sizes used throughout, primarily 1.625" and 1.75" x .120" wall DOM
- Building to Ultra4 4500 Modified Stock class specifications
------ U4 Rulebook
- Removable bedsides
- Corbeau Baja XP suspension seats
DRIVETRAIN
- Original 2.7L 3RZ-FE engine
------ Fully rebuilt and upgraded by LC Engineering
------ Forged rods/pistons with 9:1 compression
------ Stage 2 turbo cams
------ Stage 5 master valve train kit
------ Intake port/polish job by yours truly
------ Borg Warner EFR 6758 turbocharger
------ Paradise Racing intake manifold
------ Injector Dynamics 1000cc injectors
- Haltech Sprint 500 ECU w/ E85 sensor
- Original Toyota W59 5-Speed transmission
- Inchworm fully clockable 2.28 reduction crawlbox
- Original Tacoma driver drop, chain-driven transfer case with dual 67mm output flanges to accept modified Toyota double cardan joint driveshafts
- Triple-stick setup
- Jaz 32-gallon fuel cell
- Mishimoto J-line intercooler
- Mishimoto Race-ready aluminum radiator
- Dual 12" Derale puller fans
- Derale remote oil cooler
SUSPENSION
- 3-Link front suspension
------ 2" x .25" wall DOM lower links (47.75" long)
------ Barnes 1.25" Enduro joints
------ 1.50" x .25" wall DOM upper link (50" long)
------ Ruffstuff 7/8" heims
------ 1.50" x .25" wall DOM panhard (43.5" long)
------ Toyota IFS steering box drilled/tapped for hydro assist
------ 1.50" x .25" wall DOM drag link (43.5" long)
------ 1.50" x .25" wall DOM tie rod sleeved with 1" solid round 1144 stressproof steel
- 1978 Ford F-350 Dana 60 front axle
------ Modified/reinforced knuckles w/ double shear high steer setup
------ 5.38 gear ratio
------ ARB locker
------ Yukon 4340 30-spline axle shafts
------ Nitro Excalibur 300m u-joints
------ Yukon Hardcore locking hubs
- 4-Link rear suspension
------ 2.25" x .375" wall DOM lower links (56" long)
------ 1.50" x .25" wall DOM upper links (46.5" long)
- 2001 Chevy 2500HD AAM 1050 (14 Bolt) rear axle
------ ARB locker
------ e-brake removed and substituted with cutting brake system
- King racing shocks
------ 2.5" body
------ 14" travel (all 4 corners)
------ Remote reservoirs
------ 200/250 front spring rate
------ 150/200 rear spring rate
------ 2.5" Triple bypasses on all 4 corners at a later point
- 40" Goodyear Wrangler MTR Kevlar tires (for general use)
------ 37" tars on 17" Trail Ready beadlocks (If by some miracle the truck is raced)
Old 01-15-2012, 04:37 PM   #2
45acp's Avatar
Turned around and immediately bought a set of 5 Wheeler’s Offroad 15x8 Type B wheels and 33x12.50x15 KM2s!
Some before & after pics…
Soon after that I picked up a Craftsman toolbox off a buddy’s S-10 (it was free!) and refinished it. Also installed a CBI tire carrier and did the deck plate mod.
Found out there was a recall on my truck for the lower ball joints so I wasted no time getting it to a dealer for some free ball joints and an alignment.
In May 2011 right before heading down to Greeley, CO for some goodies from Addicted Offroad.
While in Greeley, I had an Addicted Offroad bumper and Trail-Gear sliders installed, and a Trail-Gear Hi-Lift mount welded to the CBI tire carrier. Scotty does fantastic work!
http://www.youtube.com/watch?v=Jsk_uwSyhzM
Old 01-15-2012, 04:39 PM   #3
45acp's Avatar
Over the next two months I had several other mods completed.
My brake pads were shot, so I picked up some new ones from Wheeler’s Offroad and decided to get some drilled/slotted rotors while I was at it.
I relocated the rear diff breather. SO easy.
Installed a Uniden 510. PERFECT fit in the ashtray location.
And Budbuilts!
I bent the belly pan on my first trail run with them. Belly pan definitely needs to be reinforced before any serious wheeling.
The front skid holds up great though.
Sustained some hail damage so I replaced the windshield. The hail hit hard enough that it cracked the paint on the hood. Between the hail and wind damage, I figured it was time to refinish the hood, but expecting it to happen again… I decided to herculine it FTW.
I then installed a Smittybilt XRC8 winch with a 5/16” synthetic line from Viking Offroad. (Best pic I have, sorry.)
I decided to get a Trail-Gear rear bumper next. I didn’t want the license plate to get caught on anything, so I relocated it to the tailgate with some LEDs. I bought the LEDs off Amazon without realizing they were for motorcycle plates but I modified it to make it work.
Picked up the Trail-Gear rear bumper from Addicted Offroad.
Installed a Tomtom OneXL
Had an 18” Magnaflow installed and dumped before the axle. The exhaust was too close to the axle and actually melted the ABS wiring. I got the wiring replaced and the Magnaflow relocated closer to the cab and dumped straight to the ground. The video was made right after it was installed, it actually sounds better after being relocated.
http://www.youtube.com/watch?v=POQy3FdtCGg
Got JLee’s BAMF BPV bracket installed.
Old 01-15-2012, 04:41 PM   #4
45acp's Avatar
Did some snow wheeling with pyroskier and he got us both stuck.
SAR got us off the mountain that night, we came back the next day with a guy that brought a snowcat all the way from Cheyenne for us.
Some random shots…
With my uncle’s ‘95.5 (original owner!) The guy that convinced me to get a Tacoma in the first place.
With WYOTAC
Got a lot of plans for it in the near future!
35x12.50x15 Wrangler MT/R Kevlars
Tub the firewall
Glassworks fiberglass front fenders w/Bushwacker rear fenders(?)
Regear to 5.29s and with luck, an ARB locker
Bobbed bed
Fabricate custom rear bumper
Relocate rear shocks and replace OMEs with Bilstien 5125s
Old 01-15-2012, 04:50 PM   #5
45acp's Avatar
Originally Posted by Bandit View Post
Great build!!
Thanks man, lots more to come!
Originally Posted by nmcqueen280 View Post
so finally the story behind the black hood comes out
Haha yeah, I figured I'd be wasting money to repaint it if the hood is just gonna most likely get damaged again.
Old 01-15-2012, 04:55 PM   #7
What do you mean I can't go up there...Watch this!
Jonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shedJonyd182 is one of the sharper tools in the shed
Jonyd182's Avatar
Jonyd182's Tacoma Gallery
Its about time you did a build ....One of my favorites.
Keep up the good work.
Old 01-15-2012, 04:56 PM   #8
45acp's Avatar
Thanks guys. Yeah this is my DD.
Old 01-15-2012, 05:21 PM   #9
45acp's Avatar
sweet thing to roll up to the office in.
I'm currently working at a daycare/preschool, so yeah it stands out haha
Old 01-15-2012, 06:30 PM   #10
Bo 159 is on a distinguished road
Bo 159's Avatar
Bo 159's Tacoma Gallery
sweet truck im diggin that front bumper, looks good. how do you plan on fitting the 35s in the future? a body lift or a hell of a lot of trimming?
Old 01-15-2012, 06:49 PM   #11
45acp's Avatar
There would be a helluva lot of trimming so I'm probably gonna end up with some fiberglass fenders so I can trim a lot and still keep the tires under the fenders (temporarily moving to WI, where it's required) and I'm going to tub the firewall. That should work I hope!
Old 01-15-2012, 08:02 PM   #12
Bash Fabriction & Off-Road
01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed01Tac0ma is one of the sharper tools in the shed
01Tac0ma's Avatar
01Tac0ma's Tacoma Gallery
Love it man, especially that front bumper
cant wait to see the "future mods"
Old 01-15-2012, 08:38 PM   #14
A country boy can survive
pyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shedpyroskier is one of the sharper tools in the shed
pyroskier's Avatar
pyroskier's Tacoma Gallery
Oh sure... ...Maybe if someones winch wouldn't have broke, we could have gotten out... . I like how we both put this event in our build threads... Haha.
Glad you finally got one of these going, I was going to ask.
Oh, and you forgot to mention the mod you did by giving me your toolbox
Old 01-15-2012, 08:45 PM   #15
I like long walks on the freeway
cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack cmack
cmack's Tacoma Gallery
Titties.
Old 01-15-2012, 08:47 PM   #16
45acp's Avatar
Originally Posted by carcharias View Post
You switch between tires, don't you?
I suppose I do. I'm running stock size Bridgestone Blizzaks as a dedicated winter set. I like to try out different tires for the 'experience'.
I was wondering when you'd show up and point that out haha!
I think there's a few things I forgot to mention... like the AFE filter and the 1 1/4" greaseable lift shackles.
Old 01-15-2012, 08:47 PM   #17
sander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shedsander1036 is one of the sharper tools in the shed
sander1036's Avatar
sander1036's Tacoma Gallery
Old 01-15-2012, 08:53 PM   #18
pyroskier's Avatar
I could post a quote of the text message you sent me at 11 pm that night saying you can't get your new shackles in and your old ones were damaged beyond repair, and you were stranded in another town
Old 01-15-2012, 08:58 PM   #19
45acp's Avatar
lmao... how could I forget I was ready to start freaking out because I had to be back for class in the morning.
12 friggin hours to get them on and as soon as I start greasing them a zerk breaks off.
Old 01-16-2012, 02:14 AM   #20
Bo 159's Avatar
well hopefully it works!! those are some big ass tires haha. definitely gonna have to tub the firewalls. ever think of the body lift? im sure it would help
A shout out to 45acp Madjik_Man 1st Gen. Tacomas 21 12-09-2011 05:00 PM
.45acp 1911 $450 TexasIslandBoy Buy / Sell / Trade - Other 18 12-01-2011 12:41 PM
Newly divorced swervin22 Off-Topic Discussion 52 01-25-2011 12:28 PM
Someone take my credit card, or I may end up divorced.. ChaseUA 2nd Gen. Tacomas 13 05-20-2010 08:53 AM
Need advice for a friend who has divorced MattN03 Off-Topic Discussion 12 01-01-2010 04:43 PM
