Slodgetto's Green Dragon 4x4 Conversion Build
Discussion in '1st Gen. Builds (1995-2004)' started by Slodgetto, Mar 29, 2012.
  1. Apr 18, 2013 at 3:10 PM
    #1501
    Slodgetto
    Slodgetto [OP] Über Posre
    Silas
    haha Heck yeah, man. :D Do and learn!!!
  2. Apr 18, 2013 at 3:16 PM
    #1502
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    noooooooo...could SC..trubo....
    oh..might as well do a 5 speed swap while your at it :cool:
  3. Apr 18, 2013 at 3:19 PM
    #1503
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Yeah I have thought about sc, but don't think I will ever do that. For the cost I think I would benefit from the 4wd more
  4. Apr 18, 2013 at 3:21 PM
    #1504
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    Ok so my question which I'm hopping som can answer is.... if I have an 02 & the donor truck is an 01 ....everything should just be drop and rebolt on ... right...?????
  5. Apr 18, 2013 at 3:27 PM
    #1505
    Blackdawg
    Monte
    Wyoming/St. Louis
    Idk..a SC in a prerunner LT truck..bad ass. Be much lighter and supa fast :p haha
    Plus you could Link out back..then custom up front for like 16'' or more travel with no front diff..
  6. Apr 18, 2013 at 3:35 PM
    #1506
    Cr250jumper
    The moon
    50 shades of tan©
    Oh damn you :mad::p
  7. Apr 18, 2013 at 3:37 PM
    #1507
    Blackdawg
    Monte
    Wyoming/St. Louis
    :D :D :D
    just here to help :p haha
  8. Apr 18, 2013 at 5:37 PM
    #1508
    Slodgetto
    Silas
    Yes. If the engines and transmissions are the same, it should all bolt up. You also have to look at whether or not both trucks have ABS, and wheelbase for the correct rear driveshaft. (Double cabs and ext cabs are the same, but reg cabs are different.)
  9. Apr 18, 2013 at 5:41 PM
    #1509
    BradyT88
    BradyT88 Well-Known Member
    It may be a little different since they are older, but at least on the newer automatic Toyota transmissions (not just Tacomas) the E is the 2wd tranny and the F is the 4wd tranny. ie A750E and A750F. They are identical trannies except for one thing. The A750E is setup to connect a driveshaft to the rear of it. The A750F is setup to connect a Tcase to the rear of it.
  10. Apr 18, 2013 at 7:48 PM
    #1510
    jesus
    jesus
    bakersfield
    Yea I lucked out its the same truck but a year older ... I think it may have even been a trd like mine...sweet so all I need then is the mhubs & I'm set.....do ya know if it be easy to the electric or vacuums if I have everything. ..
  11. Apr 18, 2013 at 7:50 PM
    #1511
    jesus
    jesus
    bakersfield
    Well my truck is sold as 2002 but was may nov I think of 2001....
  12. Apr 18, 2013 at 7:56 PM
    #1512
    BradyT88
    I just checked out wikipedia and interestingly enough all of the 4wd vehicles that use the A340 tranny use the F version except the Tacoma. All of 2wd versions of those vehicles (4runner, Tundra, T-100, pickup) use the E version and it says the 4wd Tacoma uses the E version as well. I wonder how that works. haha
  13. Apr 18, 2013 at 11:54 PM
    #1513
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    sell this pile yet
    :D :D :D
  14. Apr 19, 2013 at 6:57 AM
    #1514
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    4wd uses A340F got mine off of a 4runner
  15. Apr 19, 2013 at 7:08 AM
    #1515
    BradyT88
    Yeah, it says the 4wd 4runner uses the A340F. Says the 4wd Taco uses the A340E, although I wouldn't be surprised if that is wrong. haha Plus this is enough proof for me to say play it safe and get the A340F.
  16. Apr 19, 2013 at 8:21 PM
    #1516
    Slodgetto
    Silas
    You may be right... I always thought my 4x4 transmission was an A340E like my PreRunner trans because the ID tag on the side says "30-40LE." I'm now thinking this is actually the AISIN code and is the same on A340E and A340Fs, whereas the Toyota code is the A340E or F (E being the 2wd version and F being the 4wd version.) After all, the only differences between the two transmissions is the tail housing, the output shaft and the location of the speedo sensor. And the 03/04 versions have the fly-by-wire speedo sensors...
    I think the grimmjeeper gear calculator threw me off since it lists the A340Es as used in 98-01 tacomas and the A340Fs as used in 02-present....... (lol) Pretty sure that's incorrect :anonymous: I wish I had a copy of the FSM to see if I can get more clarification on this.
    Nice, man. All you need is manual hubs? Did the donor truck have manual hubs? Just a heads up, but if the donor truck does not have manual hubs, you will also have to source some different spindles, and CV axles. And you won't need the electric/vacuum solenoids for the ADD (auto differential disconnect) actuator.
    EDIT: Just remembered your donor truck is an 01, so that means it definitely doesn't have manual hubs. If you want them you will need to find some spindles that came off a 95.5-00 Tacoma that had manual hubs (these spindles have 6 extra little studs to mount the manual hub body) and some CV axles meant for manual hubs (the outer stub shaft is different than the ADD version--splined all the way vs. threaded end). Ideally, you want to find a diff half tube without an ADD actuator as well (since it's not needed and just more little parts to deal with) but the ADD half tube off the donor truck will work with a simple hose clamp conversion to lock the actuator shifting fork in 'lock' position. :)
  17. Apr 22, 2013 at 9:51 AM
    #1517
    Slodgetto
    Silas
    Welp, the skid plates pass inspection! :woot:
  18. Apr 22, 2013 at 9:53 AM
    #1518
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Silas, when you sell this pig promise us that in the near future when you get back into 4x4 land you buy another taco (preferably for cheap) and just jump right to building a solid axle crawler?
  19. Apr 22, 2013 at 9:59 AM
    #1519
    Slodgetto
    Silas
    That's the plan!! :) Maybe even find a taco with a blown engine for a few hundred bucks, and do an ls conversion at the same time.
  20. Apr 22, 2013 at 11:04 AM
    #1520
    Blackdawg
    Monte
    Wyoming/St. Louis
    At this rate..no one will buy this thing for the price he want...so I'm thinking the dragon is just gonna get sac...
