Nathan's Long Travel Build
Old 07-11-2012, 09:00 AM   #41
The Mad Scientist
jberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shedjberry813 is one of the sharper tools in the shed
jberry813's Avatar
jberry813's Tacoma Gallery
Originally Posted by Conman117 View Post
Ok, about the motor mounts. First off, are solid mounts any good for a DD? What do they do exactly?
Because if I go solid then I may as well just cut mine off and make new ones that go from the frame right to the motor.
And my grand plans for off-roading are inspired by you guys. Anything and everything. Though not for a year or two, still have to pay for school too.
Why is 5-speed (which I have) different? And again pros/cons of solid mounts?
It would be fun to plate more but I really want to drive my truck this year too
My truck is a DD. It vibrates like hell at idle, but once you start moving you don't notice. They definitely keep the engine from flopping around when you're hauling ass. The transmission mount is different for the 5 speed and the automatic. Don't know why...it just is.
Factory vs 4x innovation:
Originally Posted by Anthony250 View Post
Like Jberry and Nelson said gusset those motor mounts. Also good idea to make some coilbucket gussets, such as secondary shock mounts so your coil bucket doesnt bend up. I should have pics soon in my build thread on some that i made.
He has coil bucket gussets
Old 07-11-2012, 09:31 AM   #42
04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed04LTtacoma is one of the sharper tools in the shed
04LTtacoma's Avatar
04LTtacoma's Tacoma Gallery
Update time.
I pulled everything off my frame and am starting from there because there are some rusty parts, so I figured I may as well go through and replace/refinish everything that is rusty.
I have the TC coil bucket gussets, cam tab gussets and am making rear frame gussets. I want to weld on everything I need before I re-coat my frame so that I don't have to grind off my new finish.
If anyone thinks of anything I should be welding onto my frame let me know. Maybe limit strap tabs?
You might as well gusset the crap out of the frame while you have the cab and bed off the truck.
Old 07-11-2012, 01:44 PM   #43
Conman117 [OP] Conman117 is offline
AWESOME MEMBER
Conman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shedConman117 is one of the sharper tools in the shed
Conman117's Avatar
Conman117's Tacoma Gallery
I put gussets on the coil buckets and the cam tabs, boxed the rear frame, made new crossmembers, gusseted the outside rear frame and gusseting engine mounts today. Where else would I gusset?
And I think I'll keep the stock motor and tranny mounts for now. I'll be DD'ing more than off-roading for a while, so I can wait on those.
Old 07-11-2012, 01:59 PM   #44
The Mad Scientist
jberry813's Avatar
Don't mind him, he just likes to quote random things and stir shit shit up. In fact I recommend you ignore him altogether cause he doesn't know his asshole from his earhole.
You gusseted pretty much everything you should have. The only other thing I might recommend is to add additional plating to the front of the frame, similar to the plates you did in the rear on the outside of the frame rail. However, even though you are keeping the stock motor/tranny mounts, you should still reinforce the motor mount perches on the frame. They are weak as shit and break under normal conditions. And since your truck is down to the frame its a lot easier to add material now.
As an example, here's what JD did:
Old 07-11-2012, 02:12 PM   #45
AWESOME MEMBER
Conman117's Avatar
Yeah thats pretty much what I'm going to do right there. Do you know if that plate goes over the top too? I'll probably just put a plate on either side, like the picture.
Old 07-11-2012, 02:17 PM   #46
The Mad Scientist
jberry813's Avatar
Not sure...but better to have too much than too little! You might wanna pm JD (cr250jumper) about it. He's a good guy and very helpful...until he gets a pitcher of PBR in him then he's a completely hysterical asshole.
Here's the relevant link from his build thread.
http://www.tacomaworld.com/forum/1st...ml#post5286162
Old 07-11-2012, 02:29 PM   #47
AWESOME MEMBER
Conman117's Avatar
K thanks. I started a thread in the long travel section for help with my leafs and he was more than helpful, giving advice and posting pics.
I'll post some pics of the mounts when I'm done today, so you can check em out.
Old 07-11-2012, 09:09 PM   #48
AWESOME MEMBER
Conman117's Avatar
Aight, its not the best pic. 1/8" steel. It also comes up behind the bolt hole, but you can't really see. One on each side of the mount.
Old 07-11-2012, 10:46 PM   #49
AWESOME MEMBER
Conman117's Avatar
Now for the goods.
Top coat is on.
Old 07-11-2012, 10:54 PM   #50
bjasper is a splendid one to beholdbjasper is a splendid one to beholdbjasper is a splendid one to beholdbjasper is a splendid one to beholdbjasper is a splendid one to beholdbjasper is a splendid one to beholdbjasper is a splendid one to behold
bjasper's Avatar
bjasper's Tacoma Gallery
I like were this is going. Subed
Old 07-11-2012, 11:00 PM   #51
TACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shed
Firefighter:
TACOMABOSS's Tacoma Gallery
this is going to be badass i can already tell. subbed
Old 07-11-2012, 11:41 PM   #52
1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future1stacoma has a brilliant future
1stacoma's Avatar
1stacoma's Tacoma Gallery
Subbed!
Old 07-21-2012, 10:49 PM   #53
AWESOME MEMBER
Conman117's Avatar
So I finally made some progress after banging my head against a wall with my front wheel bearing. Couldn't get it out, so I took it to some shops and finally the third shop got it out with their 50 ton press. Anyway, its all painted and pretty now. WITH GUSSETS!
mmmmm... shiny goodness
Old 07-21-2012, 10:57 PM   #54
rab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shedrab89 is one of the sharper tools in the shed
rab89's Avatar
rab89's Tacoma Gallery
coooool!
Old 07-22-2012, 01:39 PM   #56
AWESOME MEMBER
Conman117's Avatar
I sandblasted them and painted them with POR 15 and then top coated with a gloss black acrylic enamel while the POR 15 was still tacky. Same with my frame.
Old 07-28-2012, 10:24 PM   #58
AWESOME MEMBER
Conman117's Avatar
So I've made some progress. Put my front diff back in and installed my tundra axles, mounted my lower control arms and I put one side together with the spindle and UCA. If anything looks off, let me know
And I installed the limit strap to keep everything up, but ran into some problems.
It looks like its in a good spot but I need to move the mounting bracket up on the frame since the adjustment nut is maxed out and the uniball is still touching the collar.
So its coming along, slowly. Thoughts? Opinions?
Old 07-28-2012, 10:28 PM   #59
04LTtacoma's Avatar
Should have beefed up the frame more...
EDIT:Is your rig 4x4 or 2wd?
Old 07-28-2012, 10:29 PM   #60
The Mad Scientist
jberry813's Avatar
I think getting a strap 1" shorter would be easier than moving the bracket.
Where did you get the axles, and did you do the 930 boot mod?
Also, what vendor did you get your coilovers from and did they put the low profile resi elbow in.
You want a elbow that looks like this:
If you have one that looks like this:
Be careful cause it may end up like this:
Alex's Long Travel Build amaes 1st Gen. Builds 276 10-24-2014 09:56 AM
Rondog's Long Travel Build rondog 2nd Gen. Builds 527 01-15-2014 01:49 PM
Long travel build advice! GRatt 2nd Gen. Tacomas 1 12-21-2011 10:16 PM
09 Tacoma Long Travel build Dezert Rat Off-Roading & Trails 7 10-04-2011 12:56 PM
Rear Long travel build atvlifestyle Suspension 10 09-14-2011 06:32 PM
