mjbtaco's 95.5 boosted build thread
Discussion in '1st Gen. Builds (1995-2004)' started by mjbtaco, May 14, 2012.
  1. May 14, 2012 at 3:24 PM
    mjbtaco
    mjbtaco [OP] low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    1995.5 xtra cab slammed and boosted Current Modificationsuserfield_edit_07fe54ebee8b007c278317657542c52de67684e3.gif PERFORMANCE
    Garret GT3576 Turbo
    Turbosmart 45mm wastegate
    Pink top injectors
    Walbro 190lph fuel pump
    Custom Intake and Exhaust Manifolds by the ShedKing out of Australia
    Custom Charge Piping made by myself
    Recirculated Turbosmart BOV
    Custom 3" Down Pipe and exhaust made by myself
    -4 AN Steel braided Oil Feed line
    -10 AN Steel Braided Oil Return Line
    -10 AN fitting welded to oil pan
    FRONT SUSPENSION
    Lower Ball Joint flip
    Custom Upper Control arms by KANE
    Custom Brembo 4 pot Big Brake Kit
    Custom modified lower balljoints to fix bumpsteer
    REAR SUSPENSION
    QA1 adjustable Shocks
    Weld in mini drop notch
    3" angled blocks
    WHEELS AND TIRES
    Enkei RPF1
    17x9 +35 front
    17x9 +45 rear
    Front- 235-45-17
    Rear-245-45-17
    Much more if you have any questions just PM me
    c
  2. May 14, 2012 at 3:28 PM
    mjbtaco
    Michael
    Montclair , so cal
    c
    Fernando likes this.
  3. May 14, 2012 at 3:31 PM
    mjbtaco
    Michael
    Montclair , so cal
    thats pretty much it for now!
  4. May 14, 2012 at 9:29 PM
    pinktaco808
    pinktaco808 Hot Steppa
    what the current drop as of now? front/back
  5. May 18, 2012 at 12:41 AM
    mjbtaco
    Michael
    Montclair , so cal
    its in the first post. about a 9/8 drop
  6. May 18, 2012 at 12:44 AM
    mjbtaco
    Michael
    Montclair , so cal
  7. Feb 24, 2014 at 10:12 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    96' X-Cab 4x4 TRD Off Road Clusterfuck
    JVC Deck, 10" sub mountd in rear seat cubby, 2 LED off road lights mounted in grille, amber raptor style grille lights, LED rock lights, square led bed light, custom made fuse block tray, 12 blade Blue Sea fuse block, 100a marine circuit breaker, black plasti dipped full grille, tinted tail lights + third, Uniden 520 with 4' firestik, Bilstein 5100s with 620lb Eibach coils, Diff drop, Chevy 63 leaf swap, TG creeper joints, 14" triangulated biletein 5125s, 8" extended steel braided brake line, TG Rock Sliders, CBI Moab 1.0 front bumper, custom fabbed bed rack, full TRD E-Locker axle swap and matching re-gear with custom stand alone wiring circuit, 29 spline pinion flange from an 06 wishbone runner, tubbed for 35x12.5" general grabbers on Ultra type 181 wheels, crush sleeve eliminator, Mini ARB compressor, front ARB locker, garage fab aluminum front skid plate, custom built high clearence rear bumper, removable mothafuckin doors
    so god damn dumped
    so god damn beautiful
  8. May 28, 2014 at 3:46 PM
    taco terror
    taco terror 1st gen = best gen
    North Carolina
    1996 Black Tacoma, 3.4L
    4.56 ECGS regear, Wheelers 6 leaf pack, Eibach coils, Bilstein 5100s, AR Baja wheels, 33 BFG ATs, Line-x
    Subbed, wow I want a street truck
  9. Dec 28, 2015 at 8:27 PM
    mjbtaco
    Michael
    Montclair , so cal
    So it's been just about 2 years since I've touched the truck. I let it sit after I posted this video and went back a few months later cuz the battery died so I bought a new one. Threw it in and the truck had no power whatsoever. So im thinking the wiring to the battery may be bad. Fast forward to today I finally ordered new wire to get the truck back up and running. Hopefully I get it back on the rode soon. Oh yeah and I sold the turbo kit cuz I blew the head lol. So it's na right now.
    https://youtu.be/RqShr2qr4AE
  10. Dec 29, 2015 at 5:06 PM
    mjbtaco
    Michael
    Montclair , so cal
    Just ordered some more wiring and should be here tomorrow. The plan is to slowly piece together another turbo kit then run it boosted for a while. Then there's a possibility of a engine swap :)
  11. Dec 30, 2015 at 5:21 PM
    mjbtaco
    Michael
    Montclair , so cal
    Got what I hope is the last of the wiring that I'll need to get the truck running again. Hope to bring it back to life before the end of January.
  12. Jan 9, 2016 at 6:33 PM
    mjbtaco
    Michael
    Montclair , so cal
    Brought the truck home!
    Flare side Taco Lover likes this.
  13. Jan 14, 2016 at 7:19 PM
    mjbtaco
    Michael
    Montclair , so cal
  14. Jan 19, 2016 at 9:49 PM
    mjbtaco
    Michael
    Montclair , so cal
  15. Jan 20, 2016 at 3:41 PM
    mjbtaco
    Michael
    Montclair , so cal
    Need to build the lower half of my pacesetter header since the eBay seller I got it from didn't send it to me. Just waiting for a flex pipe to finish the connection to the 2.5" piping already on the truck. Gonna drive the truck around na for a few months to see if there are any other gremlins I need to take care of before the turbo goes back on.
  16. Jan 20, 2016 at 3:44 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  17. Feb 10, 2016 at 8:43 PM
    mjbtaco
    Michael
    Montclair , so cal
    Even though I've made a ton of progress on the truck I haven't been recording much lol. The last thing I need to do before registering it is finishing up the exhaust. Here's part 1 of the build.
    https://youtu.be/ELzDXLQAx2o
  18. Feb 15, 2016 at 8:29 PM
    mjbtaco
    Michael
    Montclair , so cal
  19. Feb 15, 2016 at 8:31 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    John
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    Mini taco? Interesting
  20. Feb 15, 2016 at 8:32 PM
    mjbtaco
    Michael
    Montclair , so cal
    1995 back when Tacomas were still considered mini trucks lol. Don't worry I have a 2013 double cab too :p
