dezert mobbin, Budget Ballin Build!
Old 03-09-2013, 11:18 AM   #441
FBGW01 [OP] FBGW01 is offline
FBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shedFBGW01 is one of the sharper tools in the shed
FBGW01's Avatar
FBGW01's Tacoma Gallery
Im running quite a bit of preload thats why i wanna step up like +100lbs.
Running like 2 1/4 inches or so of preload
Old 03-09-2013, 11:36 AM   #442
nofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shednofords08 is one of the sharper tools in the shed
nofords08's Tacoma Gallery
Yeah thats a lot of pre-load lol
Old 03-11-2013, 04:53 PM   #444
Banned
prerantaco has much to be proud ofprerantaco has much to be proud ofprerantaco has much to be proud ofprerantaco has much to be proud ofprerantaco has much to be proud ofprerantaco has much to be proud ofprerantaco has much to be proud ofprerantaco has much to be proud ofprerantaco has much to be proud of
prerantaco's Tacoma Gallery
yep lol. i think the 700s will be too much for you IMO.
650s would be what id go with
im 4 cylinder, 4wd, caged and i have 650s. i think they are perfect. i bet our front ends weigh close to the same.
Old 03-11-2013, 04:56 PM   #445
BMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shedBMOC is one of the sharper tools in the shed
BMOC's Avatar
BMOC's Tacoma Gallery
is that ride height? looks like your uniball is almost maxed out on down travel lol
Old 03-11-2013, 10:51 PM   #446
FBGW01's Avatar
Originally Posted by PcBuilder14 View Post
Subbed...
thanks!
hehe ya veryy little down travel hahah its cause i dont wanna sit stink bug! rear end sits to high! need to SUA! haha
Old 03-12-2013, 12:47 PM   #447
FBGW01's Avatar
Going to Glamis on Thursday-Sunday. Been doing some prepping/ going over stuff on the truck before i take it out there. Solid mounted tranny (since engine mounts are), replaced both lower ball-joints and the passenger tie rod because they are pretty worn out (the driver side is still new). Also put the cold air intake on it not to long ago. To top it off, detailed it inside and out. Looks/runs great cant wait for the dunes!
Old 03-13-2013, 10:17 PM   #448
FBGW01's Avatar
Glamis tomorow
Old 03-20-2013, 07:14 AM   #449
FBGW01's Avatar
So the yesterday when i was driving home, i noticed my fuel gage was lower than it was when i had parked it. I made sure i was on level ground too so if it was just cause the angle i was at, but nope, the gage stayed so when i got home last night i started to just look and smell around the gas tank for gas. I smelt some gas at the bottom of the tank right around the area i smashed with a rock a while back.
(this spot, the dent has been pulled out and straghtened since the picture)
I remember it not having any leaks when i pulled the skid off of it. I figured i would pull the skid off real quick and just check, and there was a small leak right at the bottom!!
I JB welded it overnight and hopefully it will hold now
This also explains why my check engine light keeps popping up with a P0446 code (EVAP) because theres a leak in the tank. If the JB weld dont fix it, guess it's time for a fuel cell anyway?
Old 03-20-2013, 04:41 PM   #450
05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed05Aztacoma is one of the sharper tools in the shed
05Aztacoma's Avatar
05Aztacoma's Tacoma Gallery
Sucks that your gas tank is leaking, but at least now you have an excuse for a fuel cell.
How was your trip to Glamis?
Old 03-20-2013, 10:26 PM   #451
FBGW01's Avatar
ya hopefully the JB weld does the job for now hah and Glamis was insane!!! As always! freakin loveee it! best trip ive ever had at glamis for sure. well offroading in general! was soo fun! FBGW !!!
Old 03-30-2013, 04:00 PM   #452
FBGW01's Avatar
Relocated my battery to the bed! should take a ton of weight/strain off the core support and keep it from crushing/cracking more. Used the trail gear optima battery box, came out super clean
Old 04-03-2013, 09:36 PM   #453
05Aztacoma's Avatar
When do you plan on going out to Sycamore again? If it's a Sunday I might roll out with you.
Old 04-06-2013, 10:01 AM   #454
FBGW01's Avatar
so yesterday I did some wheelin and I was cruisin fast and hitting these flat slick dirt roads and driftin completely sideways at like 50-60mph and on like the last turn i slid it out to wide and my rear end clipped a tree then the bumper grabbed it and ripped it out the ground!! blew my tire off the bead too. sad day for the tacoma
Also while i was out there, i noticed my tank isnt holding gas at all and leaking very bad from the spot were its dented in. so this is a list of the parts im in search for:
-Either stock fuel tank and skid, or a fuel cell but i dont know if im better off stickin with a stock one or diggin into a fuel cell project.
-fiberglass bedsides 4.5" flare nothing to wide
-front fiberglass fenders 3.5" or 4.5" flare (I have 4.5" flare hannemans im willing to sell or trade)
If anyone can help me find links or suggest places to buy this stuff from for a good price, it will be greatly appreciated.
Old 04-06-2013, 10:03 AM   #455
D SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of lightD SPAID is a glorious beacon of light
D SPAID's Tacoma Gallery
http://phoenix.craigslist.org/evl/pts/3697828481.html
http://phoenix.craigslist.org/nph/pts/3697468918.html
Old 04-06-2013, 10:19 AM   #456
FBGW01's Avatar
saw those front fenders on craigs, know what brand those are? and those bedsides, idk how beat they are, but ill defineately check them out! thanks man!
EDIT: just texted the guy on the bedsides... sold em already hahah
Old 04-06-2013, 10:22 AM   #457
They look like glassworks. You could probably score those bedsides cheap. Fiberglass work isn't too hard
Old 04-06-2013, 10:25 AM   #458
FBGW01's Avatar
ya bedsides are sold, and ya im leanin towards the look of glassworks, so those could be pretty sweeet.
Old 04-06-2013, 12:21 PM   #459
Because fuck you that's why...
Trigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shedTrigo is one of the sharper tools in the shed
Trigo's Avatar
Trigo's Tacoma Gallery
How come you wanna trade the hannemans? Are the flat or round tops? And damn bro you need to slow down or get a cage lol
Old 04-07-2013, 12:53 PM   #460
Mr Nigel the 1st is on a distinguished road
Mr Nigel the 1st's Avatar
Mr Nigel the 1st's Tacoma Gallery
Man you wheel hard. I like it!
Kcbmx's Long Travel Build kcbmx 2nd Gen. Builds 169 03-10-2015 07:52 AM
4WD's budget build 4WD 1st Gen. Builds 543 03-21-2014 12:28 PM
5lugger build on a budget! 05RedTaco 2nd Gen. Builds 145 06-27-2012 07:22 AM
Ballin on a Budget! PapisChocoTaco New Members 10 09-06-2011 10:07 AM
Budget build help w/ idctx65cs Amo-cat3 Audio & Video 0 12-17-2010 01:02 PM
