my build
Discussion in '1st Gen. Builds (1995-2004)' started by yotanation29, Jun 17, 2012.
  1. Aug 21, 2012 at 11:02 PM
    #21
    hokiruu
    hokiruu Well-Known Member
    Santa Cruz, CA
    '00 4x4 TRD V6 SR5
    +1 for under hood pics of the 4.7!
  2. Sep 27, 2012 at 7:50 PM
    #22
    cr500taco
    cr500taco Well-Known Member
    D
    Northridge
    4WD
    +2
  3. Sep 27, 2012 at 8:04 PM
    #23
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Nice build
  4. Oct 14, 2012 at 5:27 PM
    #24
    yotanation29
    yotanation29 [OP] Well-Known Member
    ADRIEL
    CHULA VISTA
    98 TRD
    all pro upper a arms, icon extended travel 3", bumper cb, clarion nav, and much more to come!!
    Finally got my axles and tires for my SAS, now I just need coilovers. I won't be using these leaf springs or perches, if anyone wants them let me know, local pick up only [​IMG]
  5. Oct 14, 2012 at 6:27 PM
    #25
    austinramsay
    austinramsay Well-Known Member
    Austin
    Yuma, Arizona
    2001 Tacoma TRD Doublecab
    0-60 video/burnout video? :D haha
  6. Oct 14, 2012 at 6:52 PM
    #26
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    Haha not yet, soon enough hopefully, I need a filmer and a road still
  7. Oct 17, 2012 at 5:08 PM
    #27
    Slodgetto
    Slodgetto Über Posre
    Silas
    Nice, man. I'm subbed! :D
    Looks like a nice Ford HP D60 right there!! That's a very nice find. :drool: :eek: What's that rear axle? It looks quite a bit narrower than the front... What size are those tires? Looks liek they're almost bald... What are the rest of your plans for the swap? Any plans for dual t-cases are will you just run the stock chain driven case? What size coilovers are you hoping to run? Going to use a kit for the links? Plans for the gas tank? Or are you kust doing COs up front....?
    Also, paweeeeeeaaase post some pics under the hood! :D
  8. Oct 17, 2012 at 5:12 PM
    #28
    Findus11
    Findus11 Well-Known Member
    Durango
    07 Taco
  9. Oct 17, 2012 at 6:01 PM
    #29
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    The rear axle is a sterling 10.25. I will be using ruff stuff 3 link kit in the front and the rear with ads coilovers, probably 14" but maybe 12" if it it will fit. The tires are 42" and they're pretty bald, only about a 1/4 of thread at best, but for right now I'm just doing the basics to get it done, and for the price I got them I figured why not.
    I do plan on getting dual cases, but like I said right now in doing the basics to make it run and ill upgrade as I go along, dual cases, new tires, chromoly shafts, 31 gallon auxiliary tank, and then full cage . But this all cost a lot of money that I don't have so it's going to take some time lol
  10. Oct 17, 2012 at 8:44 PM
    #30
    Slodgetto
    Silas
    Sweet. :cool: BUT U NO 4 LINK REAR?!?!?! :eek: If you're going to do the 31 gal aux tank, then why not go with a 4-link kit up front and eliminate the retarded panhard? A semi-triangulated 4-link w/ no panhard/trac bar is a lot better.
    If you still want to go with the 3-link rear so you can keep the stock gas tank for now, do you plan on doing any high-speed off-road stuff (ie jumping.....) If so, than you may want to consider at least replacing that panhard with a watt's link. If it's not your intention to jump your truck or go racing through the desert, then you should be fine with the ruffstuff panhard 3 link. :cool:
    Either way. This looks like it's going to be a sweet build! :D
  11. Oct 17, 2012 at 9:16 PM
    #31
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    No I don't plan on jumping or racing but maybe from time to time with that v8 I might have to lol. But I'm trying to build a rock crawler, the reason I'm doing a 3 link is cuz I've heard from my buddies that its not a huge difference between a 3 and a 4 link when it comes to off roading capabilities, and since the auxiliary tank will probably be one of my last upgrades, why spend more money now to move the gas tank. I'm trying to be as recession proof as possible without cutting corners
  12. Jun 10, 2013 at 10:39 PM
    #32
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    Started my SAS, pics of the axles cleaned up. Only thing not shown is the brake conversion on the rear axle, just waiting on the rotors to come in
  13. Jun 10, 2013 at 10:47 PM
    #33
    Slodgetto
    Silas
  14. Jul 20, 2013 at 11:19 AM
    #34
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    Finished rear axle (10.25 sterling) with artec truss and ruffstuff disk break conversion and diff cover. All it needs now is paint (going under the truck today)
  15. Jul 28, 2013 at 6:55 PM
    #35
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    So this weekend we got the frame chopped off, and made a new one using 2x4 square tubing. It's shorter than the stock frame and much high for more clearance. Also got my rci 22gal fuel cell in, and got the back half base color painted for the desert camo paint job.
  16. Oct 27, 2013 at 3:25 PM
    #36
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    I haven't updated this in a while, I've got my links in the rear finally and the truck is on it's own weight, but no coilovers yet, I'm going to have that stuff done last to make sure the ride height is the same front and rear. Decided that since I'm doing an Exo cage why not have a convertible Tacoma? Chopped the cab for some cash and am getting ready to take apart the front just need to sand and primer my rear. So much to do, but the possibilities are endless
  17. Nov 13, 2013 at 11:14 AM
    #37
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    Anyone know if that lexus 4.7 is the same 4.7 the tundras had?
  18. Nov 13, 2013 at 11:16 AM
    #38
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    How the hell did I miss this? Keep us posted! :popcorn:
  19. Nov 13, 2013 at 10:25 PM
    #39
    Spencer
    Spencer Future President
    TIGGLEBITTIES
    Upland, Chino... all of 909.
    2013 DCSB 4X4 6cyl Sex Machine
    Redline hood lift, Flyzeye cabin lights, tailgate lock, SPOD Power block, VIAR onboard air, Cobra CB radio, Firestick 4' Antenna, Hot Blonde CoPilot Mod, SIX 9" Hella 4000 HID conversion with external 55W ballasts, Six 6" LED bars, Napier Bed Tent, Mudflaps delete using rocks, Roof rack by Brute force, Rock sliders by Brute force, Bed LED lights, Underhood LED automatic lights, Constant 12V bed plug, Rugged race radio, ICON uniball UCA's, KING 2.5 700 rate coilovers, Deaver rear leaf springs, KING 2.5 resi rear shocks (Flat 0.15 stack on compression shims), Scangauge, Empty wallet Mod Bug disease, AllPro Apex front bumper, On board heat exchange shower & water pump (Heater Core intercept mod), On Board Air - Viair for now, ARB when it dies-, allpro Skids back to gas tank- Tepui RTT on the shittiest "Bed Rack" ever made.... AllPro U Bolt flip kit with timbren bumps NEXT UP- expo leafs & bed rack, hydraulic bumps in rear, Total Chaos stock LCA's w/ Bypass, Rear 12" shock hoop relocate
    Question for ya!
    Still have any blue prints from the design around? I'm working on the same 4 link setup on another rig. Why did you put the top two links angled like that to the pumpkin? At that angle rather than straight 90 degrees to the axle dont they arc out at opposing angles throughout full travel?
    Thanks!
  20. Nov 13, 2013 at 10:26 PM
    #40
    yotanation29
    ADRIEL
    CHULA VISTA
    98 TRD
    Yes it is, I'm actually using the tundra ecu
