My 98 Taquito build
Old 10-06-2012, 10:20 AM   #21
nhurt [OP] nhurt is offline
nhurt is on a distinguished road
nhurt's Avatar
Coast Guard: Machinery Technician
nhurt's Tacoma Gallery
I have the 450s in the garage if you want to try them out to sorta gauge what rating your shooting for,
Old 10-06-2012, 11:13 AM   #22
jeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shed
jeffz0rz's Avatar
jeffz0rz's Tacoma Gallery
its not bad on the rough stuff, but im not always hitting it hard. im thinking about going with a 400-450# tender coil. either 4 or 6" to soften up the light running, and maybe keep the 600, possibly go down to a 550 main coil. what length coil are you running ?
Old 10-06-2012, 11:38 AM   #23
nhurt's Avatar
I'm running a 18" coil on a 8" RR fox shock. Do you have a 4banger or 6? And do you have a tube bumpr or anything?
Old 10-06-2012, 04:40 PM   #24
jeffz0rz's Avatar
That's an 18" 600lb coil.
Old 10-06-2012, 11:45 PM   #25
nhurt's Avatar
[QUOTE=jeffz0rz;5796058]That's an 18" 600lb coil.
Damn what size tubing is that 2"+?!! Looks like you have room to add a tender and even maintain that 18" main. I'd have to get a shorter main to run dual rates. Is that a custom a arm kit? How do you like the hiem ends in your upper arm? I've been thinking of converting mine to hiems- I've heard good and bad things
Old 10-07-2012, 01:29 AM   #26
uscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the sheduscg2008 is one of the sharper tools in the shed
uscg2008's Avatar
Coast Guard: AMT3 kodiak 60T jayhawks
Location: KODIAK, AK! originally from Huntington Beach, CA
uscg2008's Tacoma Gallery
damn well done bud
Old 10-07-2012, 10:22 AM   #27
jeffz0rz's Avatar
its a JD fabrication 5 lug. uppers were converted to heims before i got it. i like it alot, its just the coil situation that is killing me at the moment. i need to get it figured out before next saturday's ocotillo trip.
Old 02-01-2013, 02:28 PM   #28
nhurt's Avatar
After months of procrastinating I finally hooked my place up to support my 240v welder to continue working on my truck myself instead of shop time.
So the rear of my truck sat a tad stink bug so I pulled the truck in the garage and fabbed up some 10" shackles to replace the 12"'s I am running. I have Deaver F67's and already pulled 2 leafs so i didnt want to pull anymore out to drop it. I could have added more preload to my front suspension but that would have done two things 1) increased my spring rate and 2) reduce my droop (down) travel. neither which I wanted to do because my front seems pretty good as it sits. here is my shackles next to the 12"s.
and mounted...
I used 1.5" .120 wall DOM tubing mocking the 12" design and material but shortened. I welded everything together using .30 solid wire and 75% argon to 25% Carbon Dioxide.
they came out pretty good, it lowered my truck to the height I wanted BUT... at a neutral on its own weight the shackles angle is about 45/50% back (which is great) but are 1" from hitting the underside of my frame rail. I hit a road dip pretty hard to see if it would tap the frame and it does. Im going to throw those two leafs I pulled out back in the pack and cross my fingers this will give the leaf pack that extra spring rate and clearance I need. I built and installed these 10" shackles knowing I would go back to the 12"s once I finished the rear of my truck (boxing the frame, finishing my dual spare mount, more tube bracing, jack and mount) these things would def give me the weight I need to replace the 12"s to be at the ride height and forward to rear weight balance Im looking for. I was going to weld on my VHF antenna mount and more front skid plate braces but I figured I have a drink and veg out for the rest of the day. more updates to come....
on a side not holy crap a bottle and shielding gas is insane. $225 bucks for both and I only got a size 60!!! I remember in Washington a size 80 rental and gas was only $60 bucks.
Old 02-01-2013, 02:30 PM   #29
nhurt's Avatar
I dont know why that pic doesnt show up as vertical, I changed and saved it under my pics as such but it wont show up here normal.
Old 02-02-2013, 06:09 PM   #33
Cornfed
95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed95 taco is one of the sharper tools in the shed
95 taco's Avatar
95 taco's Tacoma Gallery
i cant believe i haven't seen this build before, nice work.
Old 02-02-2013, 06:14 PM   #34
Trifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shedTrifenix is one of the sharper tools in the shed
Trifenix's Avatar
Trifenix's Tacoma Gallery
Wow i have not seen this truck before. Another LT 5 lug 1st gen ftw!
Old 02-02-2013, 08:48 PM   #36
nhurt's Avatar
thanks!
Hahaha
Old 04-04-2013, 08:15 PM   #38
nhurt's Avatar
my bro just texted me, told me my truck was on the total chaos website under the pics section... stoked! http://www.chaosfab.com/96-04-Toyota...Kit-98000.html
also in off-road magazine-http://www.off-roadweb.com/readersrides/1203or_off_road_readers_rides_march_2012/viewall.html
Old 04-04-2013, 08:16 PM   #39
nhurt's Avatar
Originally Posted by Special_K View Post
I think Matt may be getting a revalve on his rears
are you away for work right now? havnt seen the truck there in a while...
98 Turbo Re-build dually 1st Gen. Builds 51 10-08-2012 08:01 AM
Glock's 98 Build Glock 1st Gen. Builds 15 07-26-2011 03:06 PM
TKGN1 '98 build TKGN1 1st Gen. Builds 114 03-14-2011 10:03 AM
GVY's 98 Build GVY 1st Gen. Builds 7 06-07-2010 05:30 PM
Heres the Taquito... 05 Taquito 2nd Gen. Tacomas 5 03-24-2009 11:18 AM
