Paranoids 03 Double Cab build (low buckish)
Old 07-31-2013, 07:34 PM   #61
paranoid56 [OP] paranoid56 is offline
paranoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shedparanoid56 is one of the sharper tools in the shed
paranoid56's Avatar
paranoid56's Tacoma Gallery
man, after almost a month after i ordered it, it arrived
Old 08-02-2013, 08:30 PM   #62
paranoid56's Avatar
god damn, i think a wizard makes the ARB bumper. who needs this much hardware? i installed it and still have 90% of the hardware :lol:
sure i will use a few more for the skid plate and license plate.
Old 02-02-2014, 09:42 PM   #63
paranoid56's Avatar
more updates.
got my snorkel installed
Old 02-02-2014, 09:44 PM   #64
paranoid56's Avatar
Bought one of these a bit ago and realized there wasn't a great spot to mount it. even with the brackets it didn't fit where i wanted it.
so made up a quick plate to hold the bussmann.
damn phone died before i could take pics in the truck. but it goes next to the master cyl and bolts to a stock bolt hole. easy install.
will get pics tomorrow.
freshly cut.
and with the bussmann panel in. fits perfect
then bent up.
Old 02-02-2014, 09:45 PM   #65
paranoid56's Avatar
and installed.
plan on running some LED lights and air comp off the relays and CB, seat heaters and inverter off the fused side.
Old 02-23-2014, 10:02 PM   #66
paranoid56's Avatar
almost finished up with the switch panel.
Old 02-23-2014, 10:05 PM   #67
paranoid56's Avatar
also worked on getting my air compressor hooked up. needed to make a plate to hold it. bolts to factory holes.
top side.
and how it bolts to the one spot.
and compressor installed. woot.
Old 02-25-2014, 08:38 AM   #69
PhdNPrerunners will become famous soon enoughPhdNPrerunners will become famous soon enough
PhdNPrerunners's Avatar
PhdNPrerunners's Tacoma Gallery
What are you running up front now that you are selling your coilovers?
Old 02-26-2014, 07:25 AM   #70
paranoid56's Avatar
Running Icon 2.5 coilovers now.
Old 02-26-2014, 08:42 AM   #71
PcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shed
PcBuilder14's Avatar
Air Force: A1C
PcBuilder14's Tacoma Gallery
Old 06-24-2014, 09:18 AM   #72
paranoid56's Avatar
finally got around to install my 1" body lift. (wanted a bit more tire clearance and didn't feel like tubbing the firewall.)
also added a bed rack for a future RTT. but not sure if i am liking it or not lol.
with the new rack
and body lift installed. so nice to not hear the tires hitting the firewall anymore lol
Old 06-26-2014, 08:30 PM   #73
paranoid56's Avatar
started on the rear relentless DIY bumper. some welding and grinding
quick tig welds
then ground up.
and the new spindle for the tire carrier. should be enough strength :lol: beef.
Old 06-29-2014, 08:34 PM   #74
paranoid56's Avatar
finished up swapping in some 10" shocks, (should have went with 12" as i could have fit them.
welded up some lower shock mounts (did a ubolt flip also)
upper mount is a bolt on mount and upper mounts are almost touching the bottom of the bed. i have a 1" body lift to help get them as high as possible. also mounted the reservoirs to the upper mount.
overall shot
Old 08-18-2014, 03:02 PM   #75
paranoid56's Avatar
added some diff armor over the weekend.
Old 09-15-2014, 06:54 AM   #76
cynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shedcynicalrider is one of the sharper tools in the shed
cynicalrider's Avatar
cynicalrider's Tacoma Gallery
Subbing. Awesome welds man.
03 Double cab 4x4 build Tacomagirl64 1st Gen. Builds 217 06-18-2014 07:38 PM
2005 Toyota Tacoma TRD sport double cab LOW LOW MILES ToyComa92 2nd Gen Tacoma Marketplace 9 06-01-2012 03:19 PM
03 double cab sub help Kolar Audio & Video 1 10-21-2010 08:44 PM
New 2010 Access cab to replace 03 Double Cab mainelytacoma 2nd Gen. Tacomas 2 03-14-2010 10:47 AM
Step bar for '03 Double Cab fit Access Cab? Ronald Morrow New Members 0 02-10-2010 01:24 AM
