1998triton Tacoma Build
Old 06-13-2013, 06:29 PM   #45
1998triton [OP] 1998triton is online now
1998triton is on a distinguished road
1998triton's Avatar
1998triton's Tacoma Gallery
first you need to set the parking brake and put the transmission in neutral. remove the shifter knob and transfercase knob.
then you remove the 5 phillips head screws holding the console in place. then you remove the 4 black phillips head screws that holds your boots into place.
then you remove the 4 12mm bolts holding the shifter tower into place
next you want to take 2 flat head screw drivers and turn the shifter collar counterclockwise while pushing down.
after it looks when it comes out
then you pull the shifter socket out. make sure you get the rubber gasket too.
out with the old seats in with the new seats
next you can replace the socket. pull it off off and push the new one on
then you can put it back together in reverse
Old 06-14-2013, 04:06 PM   #47
Dorthy left Kansas for a reason
somethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shedsomethinboutayota is one of the sharper tools in the shed
somethinboutayota's Avatar
somethinboutayota's Tacoma Gallery
Originally Posted by 1998triton View Post
did some custom work to the door panels
What kinda fabric? i want to do mine in the max4 camo
Old 06-14-2013, 09:49 PM   #48
1998triton's Avatar
Its just clothing fabric. I got it at a fabric store. I was looking for max4 but not any luck. Just make sure you use good adhesive. I used the locktite brand
Old 07-03-2013, 03:39 PM   #50
1998triton's Avatar
finally got my 20 inch LED light bar. it is double row.
also went and picked up my winch. it is a rugged ridge 8500 with synthetic rope
Old 07-03-2013, 03:46 PM   #51
bonafide
sk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shedsk8rjess is one of the sharper tools in the shed
sk8rjess's Avatar
sk8rjess's Tacoma Gallery
i'm expecting to see you at the upcoming TN meet in OCT!
Old 07-04-2013, 07:26 PM   #52
1998triton's Avatar
What day and Where at? I will be there. looking forward to seeing your tank
Old 07-28-2013, 02:39 PM   #56
1998triton's Avatar
got some new tires. 285/75/16 Nitto Trail Grapplers. put them on some 16 inch Oem wheels with 1.25 inch Spidertrax wheel spacers
Old 07-28-2013, 04:53 PM   #57
Your truck is looking really good man, the bumper looks awesome on your truck
Old 11-23-2013, 08:29 AM   #58
1998triton's Avatar
picked up a soft topper for cheap
since I got a soft topper had to figure out another way to mount the jack. so I cam up with this
Old 11-23-2013, 08:31 AM   #59
1998triton's Avatar
was looking over the Tacoma the other day and found this. looks like rear springs and contacting the rear shocks when flexing. anyone else ran into this?
My first Tacoma build maxpower29 2nd Gen. Builds 24 03-31-2013 03:30 PM
First Tacoma Build tmbrwlf730 2nd Gen. Builds 3 06-16-2010 09:08 AM
tacoma build lakerlax 2nd Gen. Tacomas 3 04-11-2010 05:52 PM
My Tacoma Build duke598 2nd Gen. Tacomas 18 05-31-2009 07:35 PM
