PcBuilder's 2003 Tacoma Build
Old 02-02-2013, 04:36 PM   #82
PcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shedPcBuilder14 is one of the sharper tools in the shed
PcBuilder14's Avatar
PcBuilder14's Tacoma Gallery
So I changed the oil and oil filter as well as plastidipped my rear bumper.
I do not understand why Toyota would put the oil filter in the hardest place possible! It also doesn't help that I spent a good 30 minutes looking for the oil filter... I was thinking about my old 2.7's location! I'm going to remove my skids at some point to remove the oil that dripped from the oil filter.
I went to plastidip my back bumper in the car wash bay like I did with my whole front end, but the crazy owner was there and flipped out on me saying this isn't my personal shop and that if I want to do that go to the garage and pay them to use their facilities... I wasn't about to go pay the shop another $5 just so I could paint my back bumper! I had already payed $5 earlier to use their lift and tools when I did my oil change.
So instead of having a good area for painting that was out of the wind and not as cold, I had to paint my back bumper in an empty parking lot... It looks like crap because the wind was making all of the paint form together and bubble up, then I was painting my emblem black instead of orange, but I didn't let the paint sit long enough when I put the emblem back on so I'll have to redo that at some point as well... Haha Plastidip just hasn't been good to me with this truck.
Old 02-02-2013, 04:43 PM   #83
Originally Posted by m3bassman View Post
didnt we say to just paint it? lol
and x3million on the oil filter location. luckily i can squeeze in and literaly sit in the wheel well with the tires turned left and reach in with a strap wrench and get r done.
tear into the steering system yet?
Eh, I might paint the bumpers with Rustoleum bedliner this summer if I get bored. I may have a plate bumper by then... As for the grill, emblem, and corner lights, I'm going to color match them eventually.
I broke one of those tabs and nearly ripped the liner in half trying to get it out of the way... But it still holds just fine.
As for the steering, I haven't messed with it yet. I'm not sure how I need to go about removing some of the fluid so I can take of the pump and clean out the filter to see if that helps.
Old 02-02-2013, 05:14 PM   #84
you can buy replacement grill and corner lights for ~$50 shipped from parts geek. itll have the black bezel and all on the corners. my front end isnt painted, it is just the black plastic replacement grill from them. just something to think about before painting your corners.
gl with the steering system.my sounds the same. always has. not worried about it.
Eh, I really want to get it color matched though. By the way why did you change from your satoshied grill to a stock one?
Well the noise while turning isn't too big of a deal, but if it can be fixed then awesome. I think I'll replace the pulley as well eventually, I think that's the noise I'm hearing when it sits at idle.
Old 02-02-2013, 05:53 PM   #85
i hit a bird i am thinking of rebuilding it though this summer. but for now it looks good
Oh okay, I remember now haha I looked at one of Homertaco's black ones, but I honestly think I like the way the look stock better for some reason? If I was going to put lights behind the grill I'd definitely get one, but since I plan to get an elite bumper and put lights on it, there is no point for me.
Old 02-04-2013, 02:52 PM   #86
Attempted to remove my sway bar. Got one bushing off and the rest of the bolts were froze up. Sprayed them with pb blaster and gonna take a shot at it again tomorrow.
Old 02-07-2013, 12:40 PM   #90
Hey Now!
w00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shedw00dy is one of the sharper tools in the shed
w00dy's Avatar
w00dy's Tacoma Gallery
Originally Posted by PcBuilder14 View Post
Going on the Tacoma this weekend!
NICE!!
Good luck! I just did full OME last Saturday. Did you get new u bolts? Are you re using your existing top plates on the fronts?
Old 02-07-2013, 12:43 PM   #92
Originally Posted by w00dy View Post
NICE!!
Thanks! Should be pretty easy because the garage I'm using has a lift so I can let the suspension drop, a wall mounted hydraulic spring compressor, and all the tools I need.
As for bolts, I'm using all the factory bolts and top plates. New stock shocks were put on the truck probably less than 5,000 miles ago so the bolts are brand new...
Old 02-09-2013, 02:44 PM   #95
Well I wasted 7 hours trying to install my lift on my truck.... Spent 3 hours trying to get the 5100's and eibachs to fit. The upper ball joints were keeping me from getting the shock/coil assembly in and I couldn't get the upper a-arm to separate from the spindle so was screwed... Didn't even get a chance to work on the rear. Looks like I get to have somebody else put my front lift on for me.... This sucks.
Old 02-09-2013, 02:53 PM   #97
no no no. go get yourself a pickle fork and a big hammer. the UCA will eventually separate from the spindle. Shit if i, the least mechanically inclined person on this sight, cant swap in new coilovers on my rig on 45 minutes, you can too. air tools help too haha
Well considering it cost me $40 to use the garage and tools to do what I did today, I really don't feel like attempting to do it again and fail and waste another $40...
Old 02-09-2013, 02:56 PM   #98
kinda dont have a choice do you?
It's either attempt it again next Saturady or pay a shop to install it Monday...
Old 02-09-2013, 02:56 PM   #99
Hey Now!
w00dy's Avatar
$40 for the day.... What time did you start? 8am..? You got plenty of time. Work on the AAL & get your confidence back. Than tackle the front.
Old 02-09-2013, 02:59 PM   #100
Yup, $35 do use the lift for 8 hours, and $5 to use their tools. I'll definitely do the add a leaf next Saturday.
My 2003 Toyota Tacoma Prerunner Build xtyharvey 1st Gen. Builds 28 02-16-2015 04:52 PM
Travis9287 2003 Tacoma Build travis9287 1st Gen. Builds 487 04-24-2014 08:32 AM
Sch0enne's 2003 Build sch0enne 1st Gen. Builds 53 10-17-2013 04:21 PM
PcBuilder's 1996 Tacoma Build PcBuilder14 1st Gen. Builds 108 05-22-2013 08:49 PM
2003 Tacoma Photothread/Build G3T LO5T 1st Gen. Tacomas 7 08-11-2011 01:39 AM
