'99 problems, but a build ain't one
Old 03-22-2013, 11:35 AM   #21
1stgenpre has much to be proud of1stgenpre has much to be proud of1stgenpre has much to be proud of1stgenpre has much to be proud of1stgenpre has much to be proud of1stgenpre has much to be proud of1stgenpre has much to be proud of1stgenpre has much to be proud of
Law Enforcement:
Gender: Chick
1stgenpre's Tacoma Gallery
Sub'd for the final product
Old 03-22-2013, 11:51 AM   #22
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
Originally Posted by Jtacoma99 View Post
Haha the engine was blown, and everything was sh!t. When I post more pics, you'll see why I got it so cheap.
but this is how it currently looks:
This is really bugging the shit out of me. I turned it "CW" in settings, but the pic still appears like that. Help???
It's been quite a while since I've posted anything.. I've been trying to concentrate on getting my truck finished more than trying to show it off.
Good News: I got it started for the first time!
Question: What RPM should your 1999 2.7l 5speed idle at? Mine is currently at about 1.5k and it sounds a little too wound up
Thanks!
Rotella detergent to clean out my rebuilt engine. Only going to run that through for a very short time.
Minor but cool "fab" work
I was missing an essential piece for my mirror to hang from the headboard mount, so I made my own.
I was missing a beveled washer-spacer for my idler pulley and so I also made that too. Worked perfect!
Nice project you have there. If you can get a 99 Tacoma for $800, it is usually well worth the investment. As for Idle, it should be idling at around 750-800 RPM after it warms up. If it idles higher look for things like vacuum leaks, incorrectly adjusted throttle, and check for codes. Codes can set without turning on the CEL.
QUESTION: How much fluid does my rear differential hold? (1999 Tacoma 2.7 4x4) I have read that it takes 3qts of 75-90 but it will only hold 2qts before it starts to drip out of the fill hole?
My specs show 2.2 quarts for the rear diff.
Old 04-23-2013, 01:40 PM   #23
Jtacoma99 [OP] Jtacoma99 is offline
Jtacoma99 is on a distinguished road
Jtacoma99's Avatar
Jtacoma99's Tacoma Gallery
Originally Posted by oldblue1968chevy View Post
fill it till it runs out the fill hole/or till you can just touch it bystickin your finger in the hole and feel oil
Thanks man! It's been a while since I've been on here, but I am about to upload all the latest pics soon. Project is almost finished!
Old 04-23-2013, 01:43 PM   #24
Jtacoma99's Avatar
Thanks BamaToy. The truck will finally be headed to the shop this Friday for an alignment and inspection. Time to get her on the road for the first time
Old 04-30-2013, 02:02 PM   #25
Jtacoma99's Avatar
Alright guys, almost finished with this build, but I have couple of obstacles to get past first.
1) my "male" end plug that plugs into my LH side front blinker, has been completely cut off from the wiring harness. Any suggestions as to try and hardwire the bulb, or keep on searching salvage yards?
2) My aftermarket park & side lights, or my aftermarket front fenders were manufactured terribly! My fenders have been painted, and now I'm trying to assemble my headlights and grille, but the park & side lights don't fit on the fender very well. There is a huge gap around where the black bezel is supposed to sit on the fender. Anyone else have this problem?
ps. The truck is looking way rad.. just sprayed in the bed liner this past weekend (Scorpion brand)
Old 08-03-2013, 10:57 AM   #26
Jtacoma99's Avatar
HELP
Alright guys, I moved down here to ATL and I'm without my shop or tools...
I have this annoying squeal every time I start my truck (when the engine is cold). I believe it to be a power steering issue because I keep on having to refill my cannister and I also have whining in my steering from time to time. I have put both "stop leak" and "conditioner" from Lucas Oil and the problem continues..
Any suggestions?
Old 06-01-2014, 01:34 PM   #28
JArroyo is on a distinguished road
JArroyo's Tacoma Gallery
Sub'd for the 3rz haha
Old 06-01-2014, 01:41 PM   #29
grrillA has a spectacular aura aboutgrrillA has a spectacular aura aboutgrrillA has a spectacular aura about
grrillA's Avatar
grrillA's Tacoma Gallery
what color did you paint it ?
Old 07-13-2014, 12:35 PM   #30
TrumanTacoma is on a distinguished road
TrumanTacoma's Tacoma Gallery
Where in Missouri are you? I live south of Kansas City and go to school in Kirksville.
Make sure to check out the Mo4WD Club, from what I've seen it's growing pretty good.
Trigo's stockish 4 banger 4x4 Trigo 1st Gen. Builds 68 12-13-2013 04:15 PM
99 trd sr5 build tanner56 1st Gen. Builds 8 03-25-2013 08:57 PM
New here 99 taco build Kennedyjohn127 New Members 3 05-29-2012 06:39 AM
99 Tacoma Lug Nut Problems Anthony250 Wheels & Tires 14 02-28-2011 06:39 AM
99 Slow Build caliKxracer 1st Gen. Builds 21 07-23-2010 04:56 PM
