The Lumpskie Build - '96 5-speed
Discussion in '1st Gen. Builds (1995-2004)' started by Lumpskie, May 17, 2013.
  1. Oct 15, 2013 at 5:56 PM
    #341
    Lumpskie
    Lumpskie [OP] Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Well... I didn't have a bit large enough for the holes on the upper side(5/8"):anonymous:
    So, tomorrow, I'll try to use a step up bit from work.:goingcrazy:
    Everything has to be complicated over here!
  2. Oct 15, 2013 at 5:58 PM
    #342
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  3. Oct 17, 2013 at 12:22 PM
    #343
    Lumpskie
    New Hampshire
    Ok. I think I'm set to complete the install tomorrow. Luckily, it is supposed to snow all night... and some of tomorrow!
  4. Oct 17, 2013 at 12:23 PM
    #344
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
  5. Oct 17, 2013 at 3:50 PM
    #345
    Lumpskie
    New Hampshire
    Shackles are done! (and they should actually fit!)
  6. Oct 17, 2013 at 5:34 PM
    #346
    Blackdawg
    Monte
    Wyoming/St. Louis
  7. Oct 18, 2013 at 11:38 AM
    #347
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    What gears you running with those Duratracs? I really want to upgrade to 33x12.50 Duratracs and would like to not have to re gear. I have 4.10s right now. Any advice is appreciated! Thanks man!
  8. Oct 18, 2013 at 11:47 AM
    #348
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Been on mine for only 1-2k but I couldn't agree more. I hope the tread life is as good as you say, from what I've read it's pretty hit or miss. I like em better than the BFG ATs though that's for sure
  9. Oct 18, 2013 at 12:06 PM
    #349
    Blackdawg
    Monte
    Wyoming/St. Louis
    You'll be okay with 4.10s. Take a hit on power on the highway and hills bad and mpgs. But it's live able.
    4.56s with your manual would be ideal.
  10. Oct 18, 2013 at 1:43 PM
    #350
    Lumpskie
    New Hampshire
    So, like Blackdawg said, my 4.10s are ok with the 33x12.5s. Going up Mtn passes, I'm floored in 4th and occasionally shifting to 3rd to maintain 65mph. It has kind of kill my gas mileage too. I'm happy to break 15mpg on the hwy anymore. But, keep in mind, I'm at almost 6000 ft elevation where I live. Near sea level, I'd bet that the power loss would be less noticeable.
    Yeah, so far the tread seems to be holding up. My buddy has 45k on his and he is probably going to keep his set through winter. I can't wait to try these things in the snow, I hear the are awesome.
  11. Oct 18, 2013 at 1:48 PM
    #351
    Lumpskie
    New Hampshire
    Well, I didn't think I could get skunked 3 times in a row on these springs BUT:
    Where is my extra 1.5" of spring after the centering pin!?!?!:mad:
    So, I'm sending them back...
    Plus, I discovered that my e-brake cable is going to interfere with the new spring setup. Is there an easy fix for this????
    Long story short... another disappointing day.
  12. Oct 18, 2013 at 2:47 PM
    #352
    Blackdawg
    Monte
    Wyoming/St. Louis
    :facepalm:
    Good god. Alcan is not doing good..haha
    My leafs do that a bit too. Not quite as that much bust still some. Think I saw a fix somewhere..
  13. Oct 18, 2013 at 3:13 PM
    #353
    yote
    Mark
    Tacoma, WA
    Mine was almost in the same boat...
  14. Oct 18, 2013 at 4:14 PM
    #354
    Lumpskie
    New Hampshire
    ^So mine look like yours on my current set, SeattleCoug.
    Is the cable rubbing no big deal, or do you guys think I should raise it up?
  15. Oct 18, 2013 at 4:37 PM
    #355
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    At this point you should drive the truck to Grand Junction and have Alcan install the springs while you watch!
  16. Oct 18, 2013 at 6:28 PM
    #356
    Lumpskie
    New Hampshire
    ^At this point, I'd be worried that they'd get installed wrong! I'm going to call this setup the nightmare pack...
  17. Oct 18, 2013 at 6:59 PM
    #357
    yote
    Mark
    Tacoma, WA
    I'd probably just leave it as long as the wire isn't touching the top leaf at full draw on the emergency brake handle. When flexing it won't matter cause that doesn't happen for very long and the brake wire has (some) slack to it
  18. Oct 19, 2013 at 12:42 AM
    #358
    Blackdawg
    Monte
    Wyoming/St. Louis
    I wouldn't worry too much. Mine is close to yours(7leafs) and no big issues
  19. Oct 19, 2013 at 7:16 AM
    #359
    Lumpskie
    New Hampshire
    Thanks for the info SeattleCoug and Blackdawg. I think I'll just install them and run the brake cable as is for a while. If something seems to be a problem, I'll deal with it from there.
    So, I talked with Bill Ford (Owner of Alcan Spring). It looks like what happened is he basically got confused when building to my spec. He took the length of a stock spec tacoma rear, added 1.5" to it and built it for a 3" lift. The problem is when you arch your spring for a 3" lift, it takes an additional 1.5" of length to get the eyes to line up. So, he's going to add that extra 1.5" per my spec and everything should be good. He felt really bad about screwing up my springs so many times. He also feels bad that all his profit is now thrown out the window. Long story short, this might be his last set of custom springs. I hope they work...
  20. Oct 19, 2013 at 10:35 AM
    #360
    Blackdawg
    Monte
    Wyoming/St. Louis
    Glad it got straightened out haha
