LSC15's 95 Tacoma 4x4
Clint's 1997 Reg Cab Build
Old 06-01-2013, 05:11 PM   #1
cdj1 [OP] cdj1 is offline
cdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant futurecdj1 has a brilliant future
cdj1's Avatar
cdj1's Tacoma Gallery
I figured it was time to set this up. I am transforming the truck to make it off road worthy after being a commuter vehicle for 16 years. Here it goes:
Currently Equipped:
King Extended travel coilovers with 700# springs
Front Diff Drop
OME 60062 rear shocks
SPC LR UCA's
Stainless Brake Lines (front and rear)
RAT Skids (full length) (3-piece)
New 32 tooth speedo gear
Modified front turn signals
4.56 gears (front and rear of course), LSD in rear
BFG Mud Terrain 255/85/16 KM2
Mini header
199mm Tundra calipers/rotors/pads
Warn m8000 winch
Elite Offroad front bumper
Trail Gear rear bumper (being modified by Bash-Fab with a Swing-out Tire Carrier)
Rigid D2's
Elite Offroad sliders
Dakar leaf springs
Old 06-01-2013, 05:14 PM   #2
cdj1's Avatar
Clint's 1997 Reg Cab Build-before1.jpgPictures of the truck pre-build
Old 06-01-2013, 05:18 PM   #3
cdj1's Avatar
Suspension work. Installed lift, replaced bushings (steering rack, LCA bushings, sway bar bushings), replaced brake lines, replaced UCA's, replaced lower ball joints.
Old 06-01-2013, 05:20 PM   #4
cdj1's Avatar
Some after shots.
Old 06-01-2013, 05:24 PM   #5
cdj1's Avatar
Ordered a new speedo gear from Toyota, 32 tooth. Did the mod from the TTORA post and swapped the 28 tooth gear out. Well it wasn't the smoothest install. The new gear was about 1/16" larger in diameter. So after searching the forums a bit more, I found a post that said just tap it in with a dowel/hammer. I was leary, but it worked perfectly. The speedo is dead on again. First time since 1998 when I originally put 31's on it. The speedo was off by 13% after I regeared to 4.56 and put the 33's on it.
Old 06-01-2013, 05:25 PM   #6
cdj1's Avatar
Cleaned the old Toyota decal off today. It looks much better than the ugly chipped orange sticker.
Old 06-01-2013, 05:28 PM   #7
cdj1's Avatar
Spending too much time reading on this forum. But it is saving my truck. I found this last week.
So I ordered the mini header for it. I will post more after it arrives next week. I am also going to plasti-dip the grille tomorrow.
Old 06-01-2013, 05:34 PM   #8
cdj1's Avatar
Forgot to put the pics of the RAT skids.
The paint job is streaky, but I used rustoleum etching primer (3 coats), then rustoleum flat black (2 coats).
Old 06-01-2013, 08:08 PM   #9
'MERICA
TacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shedTacoSkeet is one of the sharper tools in the shed
TacoSkeet's Avatar
Coast Guard: PO2
TacoSkeet's Tacoma Gallery
Looking good man!
Old 06-02-2013, 04:44 PM   #10
cdj1's Avatar
So this was my work from today. Plasti-Dip'd the grille and side marker lights. I preordered clips before I started so when I broke most of the originals, it was no big deal. I sanded the grille and edges of the marker lights with 220 grit, then sprayed them. I sanded the metal inserts with 180, re-primed and then painted with white paint. I like the improvement.
Before
After
In Process:
Good shot of the turn signal mod. I used a dremel to cut the holes, and run amber bulbs.
Old 06-07-2013, 10:31 AM   #11
cdj1's Avatar
New exhaust manifold is in! No issues except I had to buy a set of inverted torx bits to deal with the studs. Painted the new mini header with high temperature primer and paint. Scrapped the heat shield.
Painted
Disassembled
InstalledClint's 1997 Reg Cab Build-uploadfromtaptalk1370626279627.jpgClint's 1997 Reg Cab Build-uploadfromtaptalk1370626305945.jpg
Old 06-11-2013, 04:20 PM   #12
cdj1's Avatar
Mmmm new (er used) tundra 199mm calipers. Going on next week.
Old 06-19-2013, 03:22 PM   #13
cdj1's Avatar
So I got impatient and did the brake upgrade in between rain storms. No in progress pics. I got the calipers from eBay for $90 and heavy duty rotors and pads from rockauto.com for $110. 2001 tundra 199mm stuff.
Clint's 1997 Reg Cab Build-uploadfromtaptalk1371680516184.jpg   Clint's 1997 Reg Cab Build-uploadfromtaptalk1371680536445.jpg
Old 06-19-2013, 03:23 PM   #14
cdj1's Avatar
Braking system is better than stock. A much needed upgrade after the 33's.
Old 07-05-2013, 09:27 AM   #15
cdj1's Avatar
New rear bumper arrived today :sly:
Old 07-09-2013, 02:19 PM   #16
cdj1's Avatar
Primer coats on. 1 coat satin black prior to the rain. Tomorrow I'll wetsand and recoat.
Old 07-09-2013, 02:22 PM   #17
cdj1's Avatar
The pic
Old 07-09-2013, 03:57 PM   #19
I deal with dead animals
meatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shedmeatman is one of the sharper tools in the shed
meatman's Avatar
meatman's Tacoma Gallery
Looking good Clint!
Old 07-09-2013, 04:05 PM   #20
cdj1's Avatar
Thanks. Hoping my sliders and front bumper will arrive in the next week or so. I ordered the wiring and stuff to mount my winch solenoid under the hood to so I'll post pics as it progresses.
Display Modes
Ortlie09's Reg Cab Build ortlie09 2nd Gen. Builds 63 01-04-2014 02:42 PM
justinhw's reg cab 4x4 2.7 build justinhw 2nd Gen. Builds 29 01-01-2013 12:19 PM
GARYRED REG CAB 4X4 BUILD GARYRED 2nd Gen. Builds 10 09-14-2011 06:13 AM
((( JAZZYSTOY69 MY REG CAB BUILD ))) jazzystoy69 1st Gen. Builds 0 09-10-2011 02:42 PM
Triumph843's reg cab build Triumph843 2nd Gen. Builds 20 09-25-2010 07:43 AM
