Cynicalriders "J0hnny5 is ALIVE!" 01 build thread.
Discussion in '1st Gen. Builds (1995-2004)' started by cynicalrider, Aug 8, 2013.
  1. Aug 8, 2013 at 12:05 PM
    cynicalrider
    cynicalrider [OP] #NFG
    Jersey
    01 SR5 TRD 4x4, '23 Bronco Wildtrak, 2017 HSQV FE350
    Drop bracket lift and booger welds
    Update 08/15/2018:
    Current state:
    [​IMG]Moab1015_003 by Michael Halat, on Flickr
    [​IMG]R by Michael Halat, on Flickr
    [​IMG]IMG_0047 by Michael Halat, on Flickr
    [​IMG]IMG_0039 by Michael Halat, on Flickr
    [​IMG]IMG_0382 by Michael Halat, on Flickr
    [​IMG]IMG_0267 by Michael Halat, on Flickr
    [​IMG]IMG_0218 by Michael Halat, on Flickr
    Mod list:
    Engine and Drivetrain:
    5.29 Nitro gears built by ECGS
    Arb Front Locker
    TRD E-locker rear
    Stock 3.4L V6 Manual Transmission
    GM CS 144 Alternator - Part No. 8112-5A (Carquest reman brand)
    Custom made big 3 wiring harness upgrade
    Military spec top post terminals
    Northstar AGM 24F
    Suspension:
    Front:
    ADS Remote Resi 2.5's on 700lb Eibach springs
    Icon Delta Joint UCA's
    Old:Bilstein 5100's with 625lb Eibach Springs
    @Plastics Guy Front bump stops
    Cam tab gussets
    Spindle gussets
    Eimkeith LCA gussets
    Eimkeith shock tower top plate gussets
    Total Chaos UCA gussets
    Rear:
    OME Dakar's with AAL
    OME greasable shackles
    Greasable main eye bolts
    Firestone airbags
    Daystar cradles
    Ruff stuff spring under u bolt mounts run in a spring over configuration
    ADS Remote Resi 2.5's with 10" of travel and welded rod ends
    U bolt flip and shock relocation
    Wheels and Tires:
    315/75r16 Cooper S/T Maxx
    1.25" spidertrax wheel spacers
    OEM 5 Star Wheels
    Old: 265/75r16 Treadwright Guard Dogs on stock wheels
    Armor:
    Skid Row IFS skid
    Skid Row T-case skid beefed up
    Custom built Transmission skid
    4xInnovations DOM sliders w/ kickout
    4xInnovations Rear class 3 hitch bumper
    Low Range Offroad e-locker actuator guard
    Addicted Offroad front tube bumper
    Marlin Crawler weld on rear diff guard
    Low Range Offroad Gas tank skid - Gas tank raised 2" as well
    Boxed frame from front hanger back
    Exterior Accessories:
    Shovel and axe's mounted to bed
    60" hi-lift mounted to bed
    CB antenna mounted to custom CBI bracket
    AM/FM whip mounted to custom CBI bracket
    Cali raised LED side projecting ditch lights mounted to custom CBI brackets
    5/8" shackles on rear bumper
    3/4" shackles on front bumper
    Spare tire vertically mounted in bed
    Outback Air 10lb C02 tank mounted to custom built water jerry can holder in bed
    ARB CKMA-12 mounted in engine bay
    Toywerx Grill
    Smittybuilt X20 10k and relocated solenoid
    Custom made dual jerry can holder/cv axle holder mounted under the bed
    Interior Accessories:
    Molded Vinyl Floor
    LED Mag light mounted near passenger foot well
    Uniden Pro 520xl CB
    External CB speaker mounted on cab wall
    Voltmeter in 12V plug location
    Dual USB Ports in 12V plug location
    Kenwood Double Din DDX372 BT
    Custom inflator holder
    Dometic CFX65-DZ Fridge
    Exterior Lighting:
    Hella 700FF's upconverted to HID and mounted behind grill - broke on trail and removed
    2 rear facing Blitzpro 6D's mounted on tool box
    Clear corners with LED corner lights
    Front turnsignals moved to side markers and converted to LED's
    Syvania ZXE headlamps
    LED reverse lights
    2 Blitzpro 6LZ's mounted to rear bumper, tied into reverse lights
    6 All4Offroad rock lights
    Interior Lighting:
    LED interior lights and map lights
    Blue LED dash lights with painted blue needles
    Blue LED Lighted Key ring
    Blue LED HVAC controls
    Custom Lighting:
    LED toolbox lights
    OTRATTW Switches mounted to Paranoid Fab switch panel controlled by pinswitch
    LED bedlights mounted under rails
    Camp lights mounted to extendable pole
    Future plans:
    Uniball UCA's
    ADS RR front's
    air bags
    custom leaves
    swing out?
    hood struts
    bed rack/rtt setup
    Fiberglass flares and bedsides
    Ray 10's
    Half doors
    Tundra brakes
    Far future plans:
    Full long travel. :burnrubber: Or maybe 3-link? Currently confused and unsure.
    Official Trip Reports:
    Moab 2017 - Bucket List Trip - Cross Country Rock Therapy Adventure
    Pott's Mountain and surrounding VA/WV areas
    Exploring NH - Mt. Washington & Class VI Roads
    Other trips/exploration:
    Winter Bald Eagle Run - November 2018
    Favorite videos/obstacles:
    Escalator:
    https://www.youtube.com/watch?v=LAqvJgQ_MJs
    Mickey's Hot tub:
    https://www.youtube.com/watch?v=bO5gchIvGII
    Cliffhanger:
    https://www.youtube.com/watch?v=v3NmMVBoCyE&t=5s
    Kokopelli and TOTW:
    https://www.youtube.com/watch?v=KTym2EXMTgQ
    NNJ Snow Wheeling:
    https://www.youtube.com/watch?v=8Xrc1Iv8J_k
  2. Aug 8, 2013 at 12:15 PM
    cynicalrider
    Jersey
    ORIGINAL BUILD START:
    Let's face it, I'm no master mechanic, fabricator, electrician or autobody repair man. This truck is the first car/truck I have had the balls to really mod and I'm enjoying doing whatever little things I can here and there to it. I was never taught anything beyond an oil change mechanically but always had the urge to wrench on stuff.
    My first attempts started with motorcycles (since they were never my DD and easy to work on) and I surprised myself with my successes. My last car i was afraid to do anything beyond audio mods and cosmetic on (E46 BMW) because it was my DD and if I fucked something up it would probably be really expensive to fix.
    The bright side about this truck is I feel like I can comfortably work on it without feeling like I will screw it up. It's basically a toy hauler for me (motorcycles) but will be occasionally used for wheeling, camping and other outdoor adventuring.
    I'm in the middle of planning a wedding too so cash is low and budget is tight.
    Here is what it looked like the day I got it:
    Then I went at the grill with an angle grinder and installed the billet grill:
    Also installed clear and LED corners:
    Put LED's in my dome and map lights:
    Mounted HID'd Hella 700ff's behind the grill:
    Mounted a black aluminum tool box and blitzpro's:
    Tackled the wiring of my aux lights and mounting my switches yesterday:
    I wanted the switches to be in the clock location and I wanted the install to look very clean but bad ass as well. Picked up a piece of lexan from home depot and painted one side black with plastic specific spray paint:
    I then continued with the install/wiring. The blitzpro hook up was ezpz but the Hella's gave me trouble. I accidentally reversed the hook up and had my power going to the ground and the ground going to power. D'oh.
    Final products:
    Wiring inside the tool box:
    Switches:
    Rears:
    Fronts:
    Just found this list from when I first started modding:
    Future plans:
    Tube front bumper DONE
    Winch
    2.5" lift DONE
    33"s LOLOLOLOL
    Half doors
    Possibly a roof LED bar?
    Don't think I need much else after that.
  3. Aug 8, 2013 at 12:16 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Awesome reverse lights. I bet people will soon be afraid to tailgate you. Either that or they will go blind! lol
  4. Aug 8, 2013 at 12:37 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    BAMF kick out sliders, SkidRow skids,Pro Comp 7069, Kelly Safari TSR 285's, Elite front bumpa, OME 883 & Dakars w/ D6XL AAL, Nitro sport shocks, Eddie209 Soft topper, Satoshi, k&n fipk, Clarion vx400, Ultra Gauge, Debadgination mod
    Another clean 1st gen! Grill looks good.
  5. Aug 8, 2013 at 1:43 PM
    cynicalrider
    Jersey
    Thanks guys! I can't tell if the powder on the grill has already faded the gloss it used to have or if it's just dirty. I should try to shine them up again. And I really haven't had anyone try to tailgate me but if they do they will be in for a surprise! Usually it's me tailgating the idiots who don't get the left lane is a passing lane.
    Bahamayellow and Tatts521 like this.
  6. Aug 8, 2013 at 3:50 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Don't those LEDs hit the rear window when you open the tool box?
    Nice work. Clean looking wiring in the toolbox. Next you should add an led strip in the tool box. You could even use a mercury switch to turn them on when ever you open the lid since they turn on/off when you tilt them.
    And btw good luck with the wedding planning! My gf and I have been talking about wedding plans more and more :eek:
  7. Aug 9, 2013 at 6:55 AM
    cynicalrider
    Jersey
    They do but only when the box is fully opened. They don't really affect access to the toolbox at all. I was planning on doing the LED strip idea but to a pressure switch that turns off when the box is close. I also want to throw an LED strip under the box too because I found out the other night how much it sucks ass strapping my bike down at night from the strap points in the dark.
    And have you proposed yet Josh? That was a big hit in my wallet and then when I found out how much a good wedding would cost me my jaw dropped lol
  8. Aug 9, 2013 at 2:11 PM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
  9. Aug 10, 2013 at 4:44 AM
    porchop
    porchop Well-Known Member
    Brad
    NJ
    '15 TRD PRO S/C
    subbed, great build so far man
  10. Aug 10, 2013 at 3:03 PM
    JLink
    Josh
    Ocean, NJ
    Cool. Yea bed lighting (in the right places) is so much more convenient.
    Noooo I'm waiting a while. No need to spend money on rings and wedding until I have too lol. She moved in with me in February, so I figured we should atleast live together a couple years before we make it permanent.
    Ngneer likes this.
  11. Aug 12, 2013 at 6:04 AM
    cynicalrider
    Jersey
    Yeah I found tiny LED pods that will work great for those corners and they are cheap too. And I hear you, we have been together for a very long time so it was about time. We moved in together for the first time though in Feb of last year and we'll be together for 7 years come Sept. 1st.
    Also did the diff breather mod yesterday and aimed my rear LED's. I looked into the lights behind the grill again and it looks like I need to thin my grill surround some more to make the lights aimable.
    TacoPine159 likes this.
  12. Aug 21, 2013 at 10:50 AM
    cynicalrider
    Jersey
    Went camping and put my lights to it's first real use:
  13. Aug 21, 2013 at 4:30 PM
    cynicalrider
    Jersey
    So I learned why the stock skid never got put back on. Two bolts were sheered up front and stuck on the cross member up front and one was stuck in the back for the second half of the skid. An angle grinder got the first two off, the last one I may need a dremel.
    0BFB614B-CE2D-4232-9AF0-507A989B4BB9-460_98056395425d4e1f0049924d77a89feb6c3f7221.jpg
    Finished painting and clearing the free skid I got from Sander:
    DFA74E48-3086-465F-B57E-B853EDBA0F24-460_dc3ac98c7bffff7fb6e0e4a2390f17182d21c4d3.jpg
    Installed the front for now:
    95E0B9AA-B618-43EE-A0D5-9C75BE17E99A-460_66f293e0a7ab3a9772a8c29f041eca705594da95.jpg
  14. Aug 22, 2013 at 7:46 AM
    cynicalrider
    Jersey
    And this is the way the skid looked originally:
    534B51D9-38E0-457C-913D-749105EC2E3C-121_942441de4baa414e5f3f581e5bf9339434036350.jpg
    Still in great shape, just surface rust mostly.
  15. Aug 22, 2013 at 9:50 AM
    JLink
    Josh
    Ocean, NJ
    Looks good. Time to smash it up now!
  16. Sep 1, 2013 at 6:57 AM
    cynicalrider
    Jersey
    Ha definitely. I mounted the second half of the skid this weekend. I had to beat the fuck out of the front skid with a hammer to get one of the mounts to line up. I also had to cut the welded nut off on the one part because of the snapped nut and bolt there.
    95F7254A-37DE-4269-A2CE-A6BC2626AC93-308_421ca303a99b483aee09f2077bba6d43f4577a0a.jpg
    I also did more trimming, flipped my light mount bracket to center the lights, re-cleared my billet grill, and painted the surround.
    EB8EEBAC-03CB-4012-BA37-F838BCEA9A68-308_538c1b98ad8c1d500d38dd38fd20ac6053e88113.jpg
    I'll take day pics tomorrow.
  17. Sep 1, 2013 at 5:11 PM
    cynicalrider
    Jersey
    The grill in the day. I apparently lost a filler piece today :(
  18. Oct 11, 2013 at 10:59 AM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    subb'd Love the build so far man keep up the awesome work and good luck with yall's wedding! :thumbsup:
  19. Nov 9, 2013 at 9:24 PM
    w00dy
    w00dy Hey Now!
    Jeff
    North of the Wall
    03 dCab tURD
    It was great meeting you Mike!
    Like a boss up those hills today!
  20. Dec 2, 2013 at 10:28 AM
    cynicalrider
    Jersey
    Thanks, it was great meeting you too! Definitely can't wait to come back to the pines with my new tires.
    Recent pics and videos from wheeling in the pines and at RC:
    6659CF63-9ABF-4AB5-85E7-666F30C2C824-295_c0b77b250634dfb0e8a54692596da41b3c3b6ce1.jpg
    99F6323C-67B7-432C-B63C-6BBAACC39A5F-295_e9a540f8745e626800685600a0d9b42a361958ed.jpg
    http://www.youtube.com/watch?v=JADq9Yk_Y68
    http://www.youtube.com/watch?v=vamOS8o2Yhc
    http://www.youtube.com/watch?v=7J4EMC1mQ7s
    1464706_10202582032614720_1266968728_n_1_66e60c20eb2f27bb70ec2094791b899e0a802d93.jpg
    http://www.youtube.com/watch?v=YuoIIe5UoyM
    http://www.youtube.com/watch?v=XpzfDd9fIaQ
    Probably won't be heading back to RC without sliders.
