reh5108's 4 Banging SHITBOX tUrBo 4x4 Build
Discussion in '1st Gen. Builds (1995-2004)' started by Reh5108, Mar 12, 2014.
  1. Mar 12, 2014 at 1:22 PM
    Reh5108
    Reh5108 [OP] Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    How she currently sits 3/29/2017
    I bought this truck in Feb of 2013. Bought it with 145,xxx miles on it. It is a 2.7 5 speed with 4.30 gears. I ABSOLUTELY LOVE THIS TRUCK!!! LOL. It is my first 4x4 and I don't know how I ever lived without that. My main purpose for buying a truck was hauling kayaks and for hunting.
    Here's how she looked when I bought her...well minus the mud lol
    I have never really done any mechanical service on any vehicle but plan on doing all maintenance and whatever else I decide to do to her myself. This forum is extremely helpful and I'm sure what I can't figure out on my own you guys will be here to help :D
    My first mod was an aftermarket head unit. I can't stand fm radio so I wanted to be able to listen to Slacker radio from my phone. I went with the JVC KDR730BT In Dash CD Receiver and am very happy with it. The bluetooth sync is very nice. (I hate wires). It also came with a mic that I wired up and put on the A arm. Works well there and haven't had any complaints about noise in the year its been there. When I had the dash apart I decided to route a charging cable through the vent to hide most of the wire. I debated on whether to plug it into the head unit or the auxillary port. I went with the aux port since it charges much faster. Added a tetrax mount for my phone over the airbag indicator. Works great! Holds my beast of a Note 2 just fine.
    About a month after I had the truck this happened.
    Going to work and was hit by a backhoe.:mad: My empoyer covered everything and even had some other minor scratches repaired :)
    Decided I wanted to try out black wheels and not having a whole lot of money decided to plasti dip them.
    With the left over plasti dip I decided to cover the chrome.
    Bought a hitch and during installation I realized my leaf spring was cracked.
    Ordered some new leaf springs. This would be my first real repair on the truck and I'd say it went fairly well. All of the u bolts need some heat to break loose and I cut one of the shackle pins not realizing it was actually fixed to the plate. I thought it was just another bolt I could replace. Ended up just drilling the old pin out and putting a bolt in its place. I think in the future I might get a 1" shackle lift so this will work for the time being.
    Saw a picture of one of these emblems online and decided to make my own. I pulled the antlers in a little closer than the one I had seen and had a coworker cut it out with the plasma cutter. I was very impressed by his precision on just the raw cut. I did file and grind to get everything as symmetrical as I could then sprayed it with clear coat.
    Taking me places I would never go without 4x4:D
    hNlywVOt28KPLFycedrcV4spbBFyBYx5FsGx46tr_c9c6087eb432accffdba83a88f1d605fed977b5d.jpg
    Got an old push bar from work that came off a vehicle we no longer had. I'm still not sure if I like it 100% or not but its staying until I get a plate bumper.
    Bought a topper to be able to lock all my hunting gear up in.
    Drove 2 hours to DC area to pick up the cap and along the way I picked up an ungodly amount of salt. :eek:
    Installed some LED strip lights in the bed and also decided I want to do some camping out of it so I built a platform. I plan on putting carpet in eventually but for now this is it.
    p4tKf1ym7TWFsekggppQb3wwyuzHbIPa1NmDFG23_03cba4e1ddaae70e9aa44836f66eb51fa2bbbbac.jpg
    With the remaining lights I decided to use them under the hood. They give out plenty of light.
    I don't have any pictures but I did the fog light mod as well. Here is one of the output of the fogs though.
    Not the best but still able to drive with just them.
    3-20-14
    Lifted!:bananadance:
    Installed an OME lift with an AAL in the rear. I went with the 881 springs and couldn't be happier with the ride. Wasn't too difficult to install. Worst part was breaking all the nuts loose. I had to use heat on just about everyone of them. I'm glad I did this myself, learned a lot about the truck and saved a couple buck!
    Measurements were taken from center of hub to fender.
    Before:
    DF: 21"
    PF: 21"
    DR: 20"
    PR: 20.5"
    After:
    DF: 23.5"
    PF: 23.5"
    DR: 23"
    PR: 22.25"
    3-30-114:
    Bought some new to me wheels and tires from a member on here. They are 295/75/16's Nitto Terras sitting on Motometal 955's. She is stuffed!! Haven't had to trim a whole lot yet but haven't had it flexed hard yet either.
    First pic with them on. Hope to get some better ones soon.
    Mod list:
    Suspension:
    OME 881 coils and shocks.
    O̶M̶E̶ ̶N̶i̶t̶r̶o̶c̶h̶a̶r̶g̶e̶r̶ ̶f̶o̶r̶ ̶t̶h̶e̶ ̶r̶e̶a̶r̶ lasted 60k
    BOSS rear shocks
    Added two leaves from a stock pack to my stock pack
    T̶o̶y̶t̶e̶c̶ ̶A̶A̶L̶
    Drivetrain:
    4.88 gears
    Front Aussie locker
    Rear ARB air locker
    ADD on/off switch
    Armor:
    Demollo tube bumper
    4x Innovation sliders
    reh5108 front bumper
    reh5108 front skid plate
    Tires:
    255/85/16 Cooper ST MAXX
    2̶9̶5̶/̶7̶5̶/̶1̶6̶ ̶N̶i̶t̶t̶o̶ ̶T̶e̶r̶r̶a̶ ̶G̶r̶a̶p̶p̶l̶e̶r̶s̶
    Recovery:
    Engo E9000 with synthetic rope
    2x snatch blocks
    4x 3/4 shackles
    Recovery strap
    Hi-Lift
    Shovel
    Lighting:
    OKLEDLIGHTBARS.com 30" bar
    Reverse lights from Amazon (super cheap, work great!)
    Bed:
    L̶e̶e̶r̶ ̶c̶a̶p̶
    Under the bed rail lights
    Wildernest Cap!!!
    12V outlet
    Sleeping/storage platform
    Other:
    Hood lights
    Power outlet anytime mod
    Relocated turn signal lights to the corner lights
    Diff breather mod
    Tetrax phone mount
    Antler emblem
    Extended front and rear brake lines
    Tundra brakes and rotors
    ARB compressor for locker
    Superflow MV50 for tires
    Thanks for looking!!!:D
  2. Mar 12, 2014 at 1:23 PM
    Reh5108
    Idaho
    Pics and vids of wheeling and other places she has taken me.
    East Coast:
    Big Dogs 10-4-14 TacomaWorld Meet:
    https://www.youtube.com/watch?v=OgCzAc-6VSc&feature=youtu.be
    https://www.youtube.com/watch?v=rICmKqKH2VQ
    Loosenut almost rolling his 4 runner. https://www.youtube.com/watch?v=5DwNH20s65o&list=UUeXycICzO0KPmBbZkCa9njA
    Rausch Creek 9-27-14
    Trail 23 https://www.youtube.com/watch?v=fdgmc9eB8fE&list=UUeXycICzO0KPmBbZkCa9njA
    https://www.youtube.com/watch?v=JA4D_GmbNkI&list=UUeXycICzO0KPmBbZkCa9njA
    Doe Valley 9-7-14
    Poe Paddy State Park
    Colorado:
    Chinaman Gulch 10/24/15
    Yankee Hill 1/14/16
    Slaughterhouse Gulch 4/13/16
    Yankee Hill/Pickle Gulch 5/8/16
    Utah:
    Fins and Things 12/7/15
    Top of the World 4/26/16
    Onion Springs 4/26/16
    Dome Plateau 4/27/16
  3. Mar 17, 2014 at 6:48 AM
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Good looking pickup man! That salt looks like some nasty stuff :eek:
    Ngneer and ChadsPride like this.
  4. Mar 20, 2014 at 8:30 AM
    Reh5108
    Idaho
    Lifted!
    Before
    After
    Didn't think to really take some before and after pics so that what I got lol
    ChadsPride likes this.
  5. Mar 20, 2014 at 8:51 AM
    Reh5108
    Idaho
    Yea washed all that off the day after. My headlights barely lit up the road at night!
  6. Apr 25, 2014 at 3:58 PM
    Reh5108
    Idaho
    Did some wheeling last weekend and rubbed like crazy! :eek: lol
  7. May 5, 2014 at 5:24 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Looks great Ryan! :thumbsup:
  8. May 5, 2014 at 6:17 PM
    Reh5108
    Idaho
    Thanks!:D
  9. May 27, 2014 at 5:54 PM
    Reh5108
    Idaho
    Did a little beach driving over the weekend.IMG_20140525_103937_5f3b0fcb1bd1406e75c0e093cc276d067e05177c.jpg
  10. Aug 8, 2014 at 2:09 PM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    Are those 285's? They look huge!
  11. Aug 8, 2014 at 2:37 PM
    Reh5108
    Idaho
    295/75/16 and yes they do rub a wee bit lol
    Dhannah likes this.
  12. Oct 6, 2014 at 4:25 PM
    Reh5108
    Idaho
    Been awhile since I have updated this.
    Found a hell of a deal on CL for a Demello tube bumper. I plan on making a spare tire carrier for it somehow.
    Bought a set of 4x innovation slider and welded the legs on and then to my truck my self. So far my welds have held...
    https://lh4.googleusercontent.com/-.../gseHQdinAb0/w514-h685-no/20140822_122115.jpg
    In hindsight I should have cut the corners of the leg bases so I could weld the top. To prevent rust I just shove some rtv in there and hoping it seals.
    My exhaust fell apart about a week after a wheeling trip. Sounded awesome for the day of so I left it like that.
    First time out with the sliders on I banged up the stock skids pretty good. I found some blueprints online of a front skid and decided to try and make my own. Bought a piece of 3/16 plate for 60 bucks and turned it into this.
    Let Kristin try her hand at welding. Her beads look better than mine!:eek:
    U5mjHTQHw2EIeU_8KsjwmjKO3VO0QFmbzgVgE8GQ_078aab74d76fa10977086785d81a5f5fefa74aca.jpg
    Somewhere along the way I installed a cb in the ashtray spot. Made my own bracket to mount it to the tailgate latch. Don't have any picture of it right now.
    I think that is about it for now. Hoping for big things this winter. Build skids for diff, transfer case, and gas tank. Regear to 4.88's and a rear arb locker and possibly a Aussie locker up front. I'll probably buy a beater DD soon too.
    chrslefty and ChadsPride like this.
  13. Nov 30, 2014 at 12:56 PM
    Explor
    Explor Don’t take the trip ... let the trip take you
    John
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
    Really impressive Ryan !
    Nice job , .... Reach back and give yourself a pat or two !!
    I like the skid DIY and the DIY lift best ... Good job
  14. Nov 30, 2014 at 1:26 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    1st gen FTW :mudding:
    Reh5108[OP] likes this.
  15. Jan 31, 2015 at 6:47 PM
    Reh5108
    Idaho
    Hoping to start building this bumper soon! Probably not going to look exactly like that but similar.
    8752bde5600b498cec42f792f85f65f5_2017417d8d066218afae48445478bfeeb8687db9.jpg121e9c6c464cda874bdf0d2f02b84761_e64f82306366af3af7823a538cad34724a874c0f.jpg
  16. Jan 31, 2015 at 8:17 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  17. Mar 4, 2015 at 5:43 PM
    Reh5108
    Idaho
    Made some progress on the bumper! It's not perfect but I think it's going to look really good in the end.
    c83702d71e6af6fe5db2b7799b8878fc_55cf9f8178773f39851a5dc422be3c63d459e7cb.jpg7b1c879520166a1d3225df7417c59024_accd95c4c02fa49c078a38e932fcc3d3025f9718.jpg0c0be55fbe0e3411391306604d1dabfa_dfaba134050d59a84a138a7fc73efe618b669ae2.jpg
  18. Mar 4, 2015 at 8:05 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Too cool Ryan!
  19. Mar 5, 2015 at 6:38 PM
    Reh5108
    Idaho
    Tacked on the lower tube today. Hopefully tomorrow I will have that welded and the light bar brackets on.
  20. Mar 6, 2015 at 4:51 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Looks bad ass!
