The Supracharged King Ranch Bundle of Merriment Build
Discussion in '1st Gen. Builds (1995-2004)' started by TashcomerTexas, Nov 4, 2014.
  1. Nov 4, 2014 at 6:26 PM
    TashcomerTexas
    TashcomerTexas [OP] My truck is a whiner
    2003 TRD DC King Ranch Edition
    Welcome to the Show!
    This is my dd: 2003 DC TRD SR5 ABC 123 (King Ranch Edition)
    10/9/2016:
    2016: Introducing the expo load out!
    6/7/2015:
    11/4/2014:
    Interior:
    Premium katzkin leather kit w/ door skins
    Wheelskinz leather steering wheel cover
    Basic Michelin all weather floor mats
    Pioneer single din radio w/ equalizer, USB, and auxiliary ports
    20% front tint, 5% rear tint
    Ultragauge plus
    Arb air compressor (garage)
    Exterior:
    OME 3" lift kit- 883s front/rear nitro shocks w/ AAL
    Color matched front grille
    Old FJ land cruiser style emblem
    Plastiderped stock rear
    CVT Mt. Shasta RTT
    All Pro expedition rack custom height
    Armor/Protection:
    Viper alarm w/ 2 way remote
    Relentless Predator plate bumper
    TRD fender flares
    BAMF rock sliders w/ kickout
    Lighting:
    Retrofitted D2s w/ dual halos
    42" LED bar roof mounted
    TacoManinHD light bar roof mounts
    Powertrain/Drivetrain:
    3.4 5VZ-FE
    1st gen TRD grey supercharger
    URD 7th injector kit
    TRD E-locker
    TRD Catback Exhaust
    Rear SS brake line
    TRD radiator cap
    NGK spark plug wires (garage)
    TRD headers (garage)
    Wheels/Tires:
    OEM Hummer H3 Tactical Edition wheels
    285/75/16 Goodyear MT/R Kevlars
    Synergy 1.5" wheel spacers
    Replaced parts:
    Starter @ 182,xxx
    A/c compressor @ 183,xxx
    Supercharger fully rebuilt and installed @ 194,100
    URD 7th injector kit installed @ 194,100
    Fuel filter @ 201,xxx
    Radiator @ 201,580
    Tow package fan clutch upgrade @ 201,580
    Future Mods/Plans:
    Top = Highest priority
    Total chaos UCAs
    A340F transmission
    Rear tire swing out bumper
    Here's some stock pics, as it progressed (165k miles)
    Stocker doing work on the trails, pre lift.
    Then came the lift, still had the ol' MS2s on 265/75s
    The derp bug hit me; Don't derp things you intend on color matching!
    One of my favorite mods, the H3s :D
    And of course the synergy spacers beforehand
    This is my truck vs a wandering shopping cart LOL
    That thing was empty going downhill and picked up some gnarly speed
    Got her pdr-ed (Paintless Dent Removal) a week later. And another $180 later...good as new
    The most comfiest and luxurious mod to date. "Traded in" the interior for a king ranch edition :rolleyes:
    Interior shot, w/ wheelskin install
    Low beams
    Roof light bar
    Guess I fell out of chronological order up to here, forgot the trip to Houston to meet up with Jon (Bluepearlshark) to get my s/c!
    Got around to fixing the light bar vibration noise with some edge trim. A 1 minute job.
    Got a Viper alarm installed and loving the 2 way remote! No remote start.
    Hitting the trails again.
    Supercharger install!
    Some miscellaneous shots:
    Replacing the old weatherstripping a while back
    Sliders have saved my ass from 2 trees, and a few boulders
    Blue skies
    Avid yak hauler
    We G
    From a distance she's a big fucker
    To date been spotted a confirmed 3 times
    FishnTx, Biscuits, Poncate and 18 others like this.
  2. Nov 4, 2014 at 6:33 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    OP is a dick.
    I'm your bae.
    Biscuits, ChadsPride and MTopp like this.
  3. Nov 4, 2014 at 6:34 PM
    T4RFTMFW
    Also WOOOOHOOOOOO build thread time! :cheers: :drunk:
    I like the H3 wheels.
    MarX, ChadsPride and MTopp like this.
  4. Nov 4, 2014 at 6:58 PM
    TashcomerTexas
    Supercharger rebuild
    Back in July (2016) I finally got to fully rebuilding the supercharger myself, after many trials and errors I got it done and had the satisfaction of completion.
    Here I opened up the nose cone to the smell of rotten bananas and gym sweat
    My first manner of fucking up was exploding a bearing. I forgot to keep the spring under the bearing when pressing it out which left the inner bore attached to the nose shaft.
    Here I get the intake piece off and you can see the state in which the needle bearings are in. A 10mm wrench needs to be grinded and modified in order to reach a nut in the back of the s/c. This is the only way to detach the housing and access the needle bearings.
    Pressing the needle bearings in and out was a breeze thankfully, not much to it.
    I made sure every inch of surface for new gasket was scraped clean and was very careful in keeping the rotors pristine.
    Working on the nose cone became a different story; you must keep a socket on each end of the shaft when swapping in the new bearings. The bearing that goes in the front of the nose cone, where the pulley is installed, must be kept pushed in as you are pressing from the back so that it does not fall back out as you push the shaft with the new rear bearing in.
    Here comes fuck up #2 as I didn't take note of how deep the socket was in order to clear the cone shaft as it was being pushed in (giggity)
    Therefore surgery must be done to carefully remove the stuck socket trying not to fuck with the splines on the shaft.
    After all bearings and new nose seal installed it was all downhill from here. I promise the surface never looked so clean since it was new.
    And done!
  5. Nov 4, 2014 at 7:03 PM
    TashcomerTexas
    201,580
    Before and after
    So much room
    Green tow package fan clutch
    New radiator w/ TRD cap
  6. Nov 4, 2014 at 7:28 PM
    T4RFTMFW
    I want wan!
    ChadsPride likes this.
  7. Nov 6, 2014 at 7:34 AM
    jensenjoe
    jensenjoe Active Member
    Joe
    Bay Area
    2000 XtraCab 4x4 SR5, red
    42" LED lightbar, CB, PA system, sirens, SKL Motorworks KL-PRO1 performance chip, Viper alarm w/keyless entry, Rancho Quicklift Loaded struts, 2.5" Hell Bent Steel front spacers, RuggedLift 2" rear block spacers, Revtek 1" Diff-drop, 4' Firestik w/custom fabbed bed mount, round LED flood/fog lights, Apex 8000k Xenon HID's
    Hey whered you get the Viper alarm?? Looks awesome!
  8. Nov 6, 2014 at 9:50 AM
    T4RFTMFW
    Call me crazy, but I wanna see this thing without the chrome dick tickler up front. :cool:
  9. Nov 6, 2014 at 9:01 PM
    TashcomerTexas
    Had some rainwater in the back driver side
    Popped the plastic piece off, wasn't hard at all
    Yikes standing water. 2 days of non stop rain
    Cleaned up all this gunk
    All dry :)
    ChadsPride and 2002Tacoma4x4 like this.
  10. Nov 7, 2014 at 6:07 PM
    T4RFTMFW
    I never saw it before.
  11. Nov 12, 2014 at 2:44 PM
    TashcomerTexas
    Some future/upcoming maintenance, threads/sources of interest, and some mods for my own benefit:
    TRD s/c various hose sizes
    https://www.tacomaworld.com/threads/supercharger-check-list.234979/
    Tundra brake upgrade lines
    http://www.lceperformance.com/Stainless-Brake-Line-Kit-Tacom-To-Tundra-Upgrade-p/1055114.htm
    Tundra brake info https://www.tacomaworld.com/threads/yet-another-tacoma-brake-upgrade-to-tundra.362722/
    TRD header y pipe post 2001 + spring bolts/gaskets
    Water pump/timing belt kit - done
    http://m.ebay.com/itm/180729034728?_mwBanner=1&rmvSB=true&ul_ref=http%3A%2F%2Frover.ebay.com%2Frover%2F1%2F711-53200-19255-0%2F1%3Fff3%3D4%26pub%3D5574640951%26campid%3D5335841727%26customid%3Dtwo1277226%26mpre%3Dhttp%253A%252F%252Fm.ebay.com%252Fitm%252F180729034728%253F_mwBanner%253D1%26srcrot%3D711-53200-19255-0%26rvr_id%3D1128784384597
    13568-YZZ03 replaces (13568-69095) - timing belt - done
    PTR26-89950 - TRD trans cooler
    PTR26-35953 - TRD Header gasket kit and spring bolts
    PTR10-89990-18 - TRD Y-Pipe Assembly
    PTR04-35050 - TRD 160 thermostat
    53851-35061 - (x2) - Front flare pads
    61783-35071 - Rear driver flare pad
    61783-35091 - Rear passenger flare pad
    4runner seats overview
    http://www.customtacos.com/tech.old/index.php?article=168
    Power seats walkthrough
    https://www.yotatech.com/f2/power-seats-installation-207489/
    https://www.tacomaworld.com/threads/seat-swap.147930/
    A pillar custom ultragauge mount
    https://www.tacomaworld.com/threads/mod-a-pillar-ram-mount-gps-phone-holder.372250/
    Japanese Toyota "premium horns" 08522-52020
    http://toyota.jp/dop/comfortable/premiumhorn/
    http://m.ebay.com/itm/TOYOTA-genuine-parts-accessories-premium-horn-Sports-Horn-chromium-tone-Ber-/272476738715?hash=item3f70e1149b:g:hxMAAOSwA3dYRyyI&_trkparms=pageci%3A4022f65e-f731-11e6-af50-74dbd180a1c7%7Cparentrq%3A5a1742a915a0a3589684c8a8ffefc7b3%7Ciid%3A1
    Stolen idea for later
  12. Nov 12, 2014 at 3:11 PM
    T4RFTMFW
    Injector. Because $350 is easier to blow later.
  13. Nov 12, 2014 at 3:33 PM
    TashcomerTexas
    4runner multimode AWD/4WD tcase VF3AM
  14. Nov 17, 2014 at 9:44 PM
    TacomaYeti
    TacomaYeti WEST KY YOTA'S
    Reed
    Kentucky
    03 Double Cab TRD v6
    lookin slick man
    TashcomerTexas[OP] likes this.
  15. Nov 17, 2014 at 10:35 PM
    TashcomerTexas
    Edit for future post.
  16. Nov 23, 2014 at 3:15 PM
    TashcomerTexas
  17. Nov 25, 2014 at 12:58 PM
    TacomaYeti
    Reed
    Kentucky
    Lookin sick man, got a 42" curved bar in route to my house! Can't wait to put it on
  18. Dec 1, 2014 at 4:53 PM
    Speedytech7
    ゼイン
    5520 E Sprague Ave, Spokane Valley, WA 99212
    93 80 Series LC & 96 Turbo V6 Taco 4WD
    I've done a mod or two
    I'm liking the leather, did the kit come with the door panels or did you do that yourself?
    bodhi armor likes this.
  19. Dec 1, 2014 at 5:49 PM
    TashcomerTexas
    No, it came with the kit. It all ended up looking better than I thought it would. Thanks
    CowboyCaddy and ChadsPride like this.
  20. Dec 2, 2014 at 12:20 AM
    GTB129
    GTB129 Well-Known Member
    Greg
    Lower Alabama
    2003 4runner V8 4WD
    Daystar lift, 2002 Tacoma wheels, 285s, more to come.
    It's not very long yet, but I always enjoy reading through your build thread. Who did the leather for you?
