TKGN1 '98 build
Discussion in '1st Gen. Builds (1995-2004)' started by TKGN1, Mar 1, 2010.
  1. Jun 24, 2010 at 6:47 PM
    #101
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    Oh damn, look out!
  2. Jun 27, 2010 at 12:08 PM
    #102
    TKGN1
    TKGN1 [OP] Well-Known Member
    Todd
    College Station, TX
    '01 DC TRD 4wd
    SAS on links, SC, flat bed
    Update on how the Goodyear MTRs did:
    They kicked AZZ!! I could not be happier with these tires, handled the terrain (mostly loose dirt, steep hill climbs, little mud) excellent, highway driving is good with little noise.
    They are pricey but are very worthy as a hard hitting trail tire.
  3. Jun 27, 2010 at 12:13 PM
    #103
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    so did we get any pics i wish i would have gotten one of you about to flop that was a hairy spot man!
  4. Jun 30, 2010 at 7:56 AM
    #104
    TKGN1
    Todd
    College Station, TX
    '01 DC TRD 4wd
    Here is one from BVORR, pretty good angle, but not as bad as the one you saw, I think the rear was about two feet off the ground!
  5. Jun 30, 2010 at 5:01 PM
    #105
    SamSter0077
    Katy, TX
    They Rocked! Light weight truck with lots of Power.. you make a highway tire look super. :D
  6. Jul 7, 2010 at 5:55 PM
    #106
    TGurau
    TGurau Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    How's the s/c treating you?
  7. Jul 8, 2010 at 5:29 AM
    #107
    TKGN1
    Todd
    College Station, TX
    '01 DC TRD 4wd
    I still get a smile whenever I mash the go pedal, definatly woke the 3.4 up! So far I've put around 1,500 miles worth of driving with the S/C and absolutely no problems (this is on the original 215,000 mile motor/trans). Max boost is right around 6.2 lbs, I only run 93 octane and there have not been any issues with detonation even with summer temps in the high 90*s low 100*s. The only complaint I have about the S/C is the slight "rattle" it has at idle, typical of a S/C and I have gotten use to it, but its the only complaint I have.
  8. Jul 9, 2010 at 5:41 AM
    #108
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    That's awesome beyond words bro! Hey, if you ever come across another s/c, let me know! Thanks man!
  9. Aug 23, 2010 at 8:26 AM
    #109
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    How's your truck holding up man? I'm still really interested in supercharging my truck but I don't have the means yet. I just hear lots of bad things about s/c's and I want to hear from someone that actually has one before I put one on.
  10. Aug 23, 2010 at 8:36 AM
    #110
    SamSter0077
    Katy, TX
    We went wheeling together this past weekend, the SC is doing great. He made it up a hill that I couldn't.. all pedal. There is a video of it, and you can hear the Engine hitting the Rev limiter.. can't post it from work though..
    look for it in this thread.. http://tacomaoffroad.com/threads/113-BVORR-in-August?p=11686&viewfull=1#post11686
  11. Mar 14, 2011 at 9:03 AM
    #111
    c005jjc
    c005jjc Statistics are boring…until you become one!
    John
    East Tennessee
    01 Prerunner DoubleCab SR5
    Axle wrap mod, Fumoto oil drain valve, Tinted windows
    How is the oil filter relocation kit working out? I am thinking of doing this real soon and was wondering if you have had any regrets since doing the mod? I have saw other posts where guys have taken them off due to leaks or a hose rupturing but they were the cheap rubber hoses. I think this will be a real improvement when changing the oil filter compared to stock...I get tired of cleaning up the oil. Also, what kind of sealant did you use when putting the fittings together?
  12. Oct 23, 2016 at 10:53 AM
    #112
    adrenal321
    adrenal321 Member
    Edgar
    Los Angeles County
    95.5 Tacoma 4x4
    None all stock
    hi everyone, i just got a used first gen trd supercharger as well. Considering i dont know much
    about the supercharger what should i do to inspect. it spins ok maybe just a little play when you
    turn the pulley. How do you know if bearings are good or bad or even if you need a rebuild.
