Mike's 5lug Long Travel rear build
Discussion in '1st Gen. Builds (1995-2004)' started by MadTaco461, Jan 27, 2011.
  1. Jan 27, 2011 at 10:32 AM
    MadTaco461
    MadTaco461 [OP] BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Well, got an early start than intended with a long travel rear since breaking my axle before new years. So currently I am stripping the whole rear down. I took off my J59's and Fox 2.0"x14" shocks. I'm planning to do this build to just do the stuff I need to make this work. I'm going to be boxing the frame, keeping the stock gas tank, running the allpro 50T pack, and king 2.5"x 16" smoothies. The bedcage is going to be very basic straight bars. Future upgrades will be hydro bumps up front and rear and a U-bolt eliminator.
    here is how she is sitting
    fully trussed axle
    before, and yes the bed cage is bent from breaking at the weld back in may 2010
  2. Jan 28, 2011 at 10:57 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  3. Jan 28, 2011 at 11:05 AM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    Sub'ed!!!! Your front is already LT'ed right? Looks like it from the pics in your sig.
  4. Jan 28, 2011 at 11:07 AM
    MadTaco461
    CA
    Kinda stock
    Up front is already a JD fab LT. It needs some upgrades once the rear is done. Hoping to keep a good balance there.
  5. Jan 28, 2011 at 11:09 AM
    mntbiker2008
    Aaron
    Cincinnati, OH
    nice! good luck with the build! I love all the LT tacos.
  6. Feb 1, 2011 at 11:43 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Nice 5 lug long travel truck! Is that a trussed 7.5 rear end? What size tires are you running @ what gears?
  7. Feb 2, 2011 at 8:48 AM
    MadTaco461
    CA
    Kinda stock
    Forgot in your PM. I really like the JD kit up front. It is strong, huge 10" shock. I have a fabtech spindle to clear 32" tires. Weakest points are those fabtech spindles and the lower ball joint. I carry an extra set for when i go out to the desert. The rear is a trussed 7.5" with 4.56. I'm doing 60 when the speedo says 70 and about 5mph off at slower speeds.
  8. Feb 2, 2011 at 10:47 AM
    mntbiker2008
    Aaron
    Cincinnati, OH
    make any head-way with the build?
  9. Feb 2, 2011 at 11:07 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Nice. I wished we could have got to Lucerne earlier that day so I could see it happen.
  10. Feb 2, 2011 at 3:24 PM
    MadTaco461
    CA
    Kinda stock
    It wasn't too impressive of a break. I stopped where you guys saw me to take a break and looked underneath and saw a broken axle. I didn't try to move so I can save my third member.
    So the build again.
    Got the hangers on and is pulling out 22" travel and is being held up at 20" in the pic. There is no drive shaft binding at any height. Right now on the list is shock position and bedcage building. Using a King 2.5"x16" hoping to get a smooth 18". Having a shock tab issue. The stock gas tank is in the way so I'm working on cutting up some shock tabs to mount behind the axle over the truss.
  11. Feb 6, 2011 at 11:02 PM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    very nice, how long are you shackles? tc 12 inchers?
  12. Feb 6, 2011 at 11:23 PM
    MadTaco461
    CA
    Kinda stock
    I used 12" engage shackles and hangers. Very similar to TC in looks.
  13. Feb 7, 2011 at 11:05 AM
    87xjmike
    Folsom
    98 5lug 2rz
    i tried googling engage toyota shackles and engage shackles and nothing came up. Are they cheaper than tc? 300 for those tc shackles seem like a rip off. I'm about to get ruff stuff to cut me some 10-12"ers but i'm open to options.
  14. Feb 8, 2011 at 8:20 AM
    Trifenix
    so cal
    99 LT 5 lug Taco
    Maybe you can try to mount the shocks outside the frame rail? and use spacers?
  15. Feb 8, 2011 at 9:39 AM
    MadTaco461
    CA
    Kinda stock
    I tested to see if 2 inch spacers work and it didn't look too safe when I'd wheel slow. My old 2.0's would fit. So I'm running the shocks inboard. I can get 16" to work over 19" of travel and building the bed cage off of this and strapping it at 18" Today is tacking the bedcage and finally start boxing the frame tomorrow.
  16. Feb 8, 2011 at 9:51 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    coming along... slowly but surely :D
    you gonna take out any leafs from the 50T?
  17. Feb 17, 2011 at 3:02 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    any progress???
  18. Feb 17, 2011 at 3:54 PM
    chaz834
    chaz834 Tacoma 4 Life.
    Chase
    Kendrick, Idaho
    2012 Sport MGM
    3'' Tuff Counrty Lift, Moromoto Mini H1 Projectors 5000K 35W, BHLM, 30'' LED Light Bar, Black TOYOTA Emblem, Excelon Touch Screen Deck, Hertz Speakers,Excelon AMP, 2 10'' JL Audio Subs, Wet Okle seat covers, Weather Tech Floor Mats.
    Sweet...
  19. Feb 18, 2011 at 10:56 AM
    MadTaco461
    CA
    Kinda stock
    It's almost alive! Just need to slap in the battery, rear electrical, weld on new spare tire tabs, more cage work to hold the resi, and bolt the brake proportioning valve to the bottom of the bed. Sorry about the wait there guys. So she sits stupid tall right now. 13" before I even touch the bump stop and about 4" of down travel before the straps kick in. I'm going to jump on it some to hope it comes down. Depends on how it rides will make me decide what other leaves I want to pull out. Right now I have the 5th leaf out.
  20. Feb 18, 2011 at 8:57 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    looks good awesome work. Im debating if i want to spend 3k plus on the my truck. if i could find a deal like you i would jump on it
