Ebrake Help
Old 08-04-2010, 01:41 PM   #1
A Tall Midget is on a distinguished road
A Tall Midget's Avatar
A Tall Midget's Tacoma Gallery
Ebrake Help
Hey guys I have recently had some issues with my E brake sensor. When i accelerate (because its a horizontal pull one) it will move backwards slightly which sets the e brake light off and is seriously bugging me.
any ideas?
Old 08-04-2010, 01:50 PM   #2
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
Check to see if this lever is "frozen" on both drums. If it is, you pull the rubber boot back, drive the pin out, and clean the corrosion of the clevis. I had the exact thing happen to my 98.
Old 08-04-2010, 01:53 PM   #3
I will definitely go try this
results will follow
Old 08-04-2010, 02:04 PM   #4
I looked under and i can wiggle them around so i dont think their frozen, i think it just has to do with the ebrake slightly moving off the sensor...
Old 08-04-2010, 02:19 PM   #5
Manlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shed
Manlaan's Avatar
Manlaan's Tacoma Gallery
Are you positive that it is the lever and not low brake fluid?
Double check your brake fluid levels, as that will also cause your parking light to come on. If it is low, you need to check your brake thickness, as thats one of the ways that is used as a worn out indicator. If you are low and the pads are fine, make sure you aren't leaking fluid somewhere.
If your fluid levels are fine, there is a spring you can try lubricating under the drivers side. http://www.tacomaworld.com/forum/1st...t-problem.html has pics and some other options for you.
Old 08-04-2010, 05:39 PM   #6
I checked and made sure it wasnt the brake fluid. I believe it may need to be slightly tightened or something. and i wd40'd the spring and havent had a chance to drive it yet
Old 05-29-2012, 10:23 PM   #7
vantaco is just really nicevantaco is just really nicevantaco is just really nicevantaco is just really nice
vantaco's Tacoma Gallery
just bringing this back up as i have the same issue and pretty much a non existent ebrake
my truck as some rust underneath, and just tonight i was trying to poke around and check stuff out....well the two mechanisms at the rear brakes don't budge at all even with the ebrake disengaged
so if i pull the rubber boot back there's a pin i can pop out and i can remove the whole pivot arm for the ebrake and clean it up?
Old 05-30-2012, 05:44 AM   #8
:POOPCORN:
98tacoma27's Avatar
Marines:
Yes
Old 05-30-2012, 08:39 PM   #11
adjusting it does nothing when it's frozen
tip: pm sent
Old 06-01-2012, 05:22 PM   #12
ok so i took a better look, how do i get the dust caps off??
ABS and ebrake dash lights on????? pauled71 2nd Gen. Tacomas 6 12-19-2011 02:49 PM
Ebrake mod thread TurboGT 2nd Gen. Builds 0 09-29-2010 02:29 PM
Moving Ebrake... TurboGT Audio & Video 0 09-29-2010 02:28 PM
ebrake issues with lift mixaro Suspension 1 10-08-2009 06:39 PM
Relay for Pionner ebrake bypass mberky07 Audio & Video 7 06-19-2009 07:12 PM
