4 wheel alignment on 1st gen?
Old 08-27-2010, 02:10 PM   #1
Lifted 'n Locked 4WD Prerunner
01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed01tacoprerunner is one of the sharper tools in the shed
01tacoprerunner's Avatar
01tacoprerunner's Tacoma Gallery
Send a message via Skype™ to 01tacoprerunner
Can you do a 4 wheel alignment on a 2001 Toyota Tacoma prerunner??
Old 08-27-2010, 02:45 PM   #2
Help me can you actually do it or should I only be charged for a front alignment? 2001 Tacoma preunner
Old 08-27-2010, 03:36 PM   #3
Manlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shedManlaan is one of the sharper tools in the shed
Manlaan's Avatar
Manlaan's Tacoma Gallery
There's really nothing to align in the rear. Nothing to adjust anyway. The FSM has no specs for the rear either, nor does the alignment procedure say anything about the rear. If the rear is on straight and nothing is bent, thats about it.
Old 08-27-2010, 10:18 PM   #4
bivey will become famous soon enoughbivey will become famous soon enough
bivey's Avatar
bivey's Tacoma Gallery
That's corrected can't 4 wheel align a rear wheel drive vehicle
Old 08-27-2010, 10:27 PM   #5
Metal Cutter
zero4 has much to be proud ofzero4 has much to be proud ofzero4 has much to be proud ofzero4 has much to be proud ofzero4 has much to be proud ofzero4 has much to be proud ofzero4 has much to be proud ofzero4 has much to be proud ofzero4 has much to be proud of
zero4's Avatar
zero4's Tacoma Gallery
I take my truck to the local Sears since they seem to do a pretty good job. The last time I asked for just a front wheel alignment & they said for $60 4 wheel was included anyway.
I did all the suspension work myself & I did not notice or understand what could be adjusted in the rear. The printout showed the rear toe did come out different than before it went in & they do put thos alignment mirror things on the rear wheel too.
I came to the conclusion that they do the front wheel alignment somehwat based on the alignment of the rear axle. Otherwise if your rear axle was way out of whack & they just did the front only, maybe the truck might look like it was driving down the street sideways?
Old 08-27-2010, 10:32 PM   #6
shampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud ofshampoop has much to be proud of
shampoop's Tacoma Gallery
not true. you can't align the rear suspension of a car with leaf springs in the back. there's nothing to adjust. they're just always "basically" straight unless you really fucked something up.
there may be some freak exceptions to that rule, but that's how it is with most all vehicles.
Old 08-27-2010, 10:45 PM   #7
4WD 4WD is offline
cRaZy oLdmAn
4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed
4WD's Avatar
4WD's Tacoma Gallery
I think some of those goofball looking mini vans with coil spring rear ends (Honda comes to mind) use 4 wheel alignment for "toe-in" "toe-out" .....
Old 08-27-2010, 10:53 PM   #8
Metal Cutter
zero4's Avatar
I agree, it's just vehicles with leafs. For most independent suspension rears there almost always at least toe adjustments. Well on Japanese cars anyway causes that's 90% of the lowering jobs I did at my old work.
Old 08-27-2010, 10:57 PM   #9
wo ai ni bao bei ^_^
blackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shedblackhawke88 is one of the sharper tools in the shed
blackhawke88's Avatar
blackhawke88's Tacoma Gallery
Independent rear cars can be aligned, we custom aligned my friends SC300 for camber and toe after we dropped it, it's like a 4x4 front suspension, with cv axles and control (trailing) arms.
Old 08-28-2010, 07:24 AM   #10
Yamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shedYamaha Dave is one of the sharper tools in the shed
Yamaha Dave's Avatar
Yamaha Dave's Tacoma Gallery
I just had a 4-wheel alignment done at the Toyota dealership on my 03 Prerunner.
Old 08-29-2010, 12:45 AM   #11
kumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud ofkumaWRX has much to be proud of
kumaWRX's Tacoma Gallery
They just fed you BS probably to justify their pricing. Like people have said before you cant align the rear end of solid axle with leaf springs, there isn't anything to adjust. They probably just checked it and it was in specs.
Old 08-29-2010, 08:58 PM   #12
Actually I didnt pay for it it was included in a warranty/maintenance program so they had ZERO reasons to feed me any lines because they werent making any money off me. I told them the same thing and they showed me they put the truck on the lift and used I guess lasers and other alignment contraptions that went on all four wheels while I watched. Then they showed me the numbers and how far each wheel was off on the screen.
Wheel spacers with 2nd Gen TRD wheels on 1st Gen Tacoma jrad012x 1st Gen. Tacomas 5 11-18-2014 08:18 PM
atx wheel on 1st gen 2000SIG Wheels & Tires 9 05-02-2011 09:32 AM
Alignment results - 1st Gen, 2.5" lift, Stock UCAs phidauex Suspension 0 11-16-2010 01:33 PM
1st gen alignment crazyjeys 1st Gen. Tacomas 8 07-26-2010 11:11 PM
Oh no! Not another wheel question! 2nd gen wheels on 1st gen? eltaco Wheels & Tires 3 07-19-2010 11:01 PM
