Loose ashtray that keeps opening? Here is the solution!
Discussion in '1st Gen. Tacomas (1995-2004)' started by willtotheumm, Sep 2, 2010.
  1. Sep 2, 2010 at 3:25 PM
    willtotheumm
    willtotheumm [OP] Yo Taco!
    Will
    Santa Maria, CA
    03 Lunar Mist DC TRD Offroad PreRunner V6
    K&N intake. That is all. For now...
    I got tired of the ashtray on my 03 constantly opening. Whether it was quick acceleration, or speed bumps, that ashtray always slid open. I tried the tape technique and didn't like it. Decided to try to find an alternative thats simple, and free!
    EXCLAIMER: I am not liable for any undesired breaking of parts. PLEASE USE CAUTION! There isn't much going on, but nobody likes a part snapping or anything. That'll just make more work to do!
    What you need:
    20 minutes of time (less if you know the first steps)
    1 Phillips screwdriver
    1 Flathead screwdriver
    Okay to start...
    This is the work area:
    Remove the ashtray and pull all the knobs off the climate control. You'll need the flathead screw driver to pull the faceplate for the climate control area. BE VERY CAREFUL! Mine has chipped in the past and the screw driver tab doesn't really work anymore. I use my finger to pop it out.
    Now you have 2 screws to undo. You'll need the phillips screwdriver now. They are the circled ones. I prefer a magnetic one for the screw on the left. I've dropped it too many times.
    Pull the shrouding off (a few tabs) and tilt it forward. You'll see 3 connectors attached to it.
    Disconnect those 3. The light for the ash tray needed a gentle wiggle and tug. Don't pull too hard or else you might pull the wire from the socket.
    Gently turn the shroud and lift up around the shifter. On the bottom you'll find the following...
    Undo the 2 phillips screws and the metal part slides out. Once you have it out you'll have this.
    Now those plastic parts slide out. What you need to do is find the tab holding each one on, and GENTLY push down on it. I used the flathead screwdriver.
    The plastic part will slide out towards the front of the metal assembly. Again, be gentle. The plastic parts can be brittle. Once you get the part slid out, you'll find this on the back.
    If your ashtray is ridiculously loose like mine, the metal spring will fall right out. Make sure to catch it with you hand. Simply squeeze the spring gently to give it more bend.
    Place it back in the plastic and reverse all the steps! Go out and test drive your Taco to see if it slides out. I have no problems with mine whatsoever now!
  2. Sep 2, 2010 at 3:29 PM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 S/C SAS TRD
    WATRD.com
    SWEET! I keep mine filled with change, so it's ALWAYS sliding out on me. I am going to give this a shot.
  3. Sep 2, 2010 at 3:30 PM
    willtotheumm
    Will
    Santa Maria, CA
    Thats what sparked mine too. Now I actually have to pull on it to open it. :D
  4. Sep 2, 2010 at 3:37 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    You can take it out without taking the whole dash apart like that! Just get a short screwdriver and take the 2 screws out from the bottom!
    1997tacomav6 likes this.
  5. Sep 2, 2010 at 3:46 PM
    willtotheumm
    Will
    Santa Maria, CA
    I tried doing that but the screws holding the metal part on were so tight I couldn't get any leverage. But yes, that will work :D
    Bonewilly likes this.
  6. Sep 2, 2010 at 8:52 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    if you have a 1/4 drive ratchet and a 6/7/8 mm (i forget which one) you can put a screw bit in the socket and use the ratchet as a screw driver ;)
  7. Sep 2, 2010 at 9:19 PM
    willtotheumm
    Will
    Santa Maria, CA
    Haha true. I jumped the gun and tore it all apart. It wasn't the first time so it was pretty easy :)
  8. Sep 3, 2010 at 5:20 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    the most simple way to keep your ashtray from sliding open is to remove the metal track that it slides in ...take that metal piece and bend it to where the sides squeeze the sides of the ashtray tight when you insert it back in the metal bracket.
    it took me about 5 min to do...and my tray doesnt move at all unless i pull or push it with my hand.
    here's the pic of the metal bracket you want to slightly bend...
  9. Sep 12, 2010 at 4:59 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Thanks for the thread willtotheumm. The info was very helpful. No more annoying self opening ashtray.:)
  10. Sep 14, 2010 at 9:43 PM
    willtotheumm
    Will
    Santa Maria, CA
    Welcome man! I got tired of it constantly opening too. I just spent the weekend camping and not once did it pop open. :D
  11. Sep 15, 2010 at 1:14 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Ima have to do this. Mine ALWAYS comes open. Thanks!
  12. Sep 15, 2010 at 7:19 AM
    3fitty
    3fitty Well-Known Member
    Lambone
    Gulf Coast
    01 Prerunner
    Bilstein 5100 front, 5125 rear and Skyjacker AAL. Manaflow Catback exhaust. aFe Pro-Dry air filter.
    x2. I did it without taking the whole dash apart. I couldn't pull the light off thought so I did it still halfway connected in the dash :D
    Ashtray is no longer as loose as a $5 whore :eek:
  13. Sep 15, 2010 at 5:13 PM
    Chris D.
    Chris D. Well-Known Member
    Eagan, Minnesota
    2002 Tacoma RZN150 turbo
    2RZ-FE Turbo Intercooled, standalone........... Exactly 150% more power to the wheels than stock at the wheels. Supra transmission, 4 linked rear, QA1 coilovers all around, S-Runner rear sway bar, Corbeau bucket seats, forged 5 spoke 17x9 wheels, Wilwood 12.19" 4 piston brakes, Ford 9" rear end (early bronco) 31 spline, full floater, big bearing, 3.50 gears, trac-lock. fully functioning air conditioning and cruise control....
    This is good info, when I launch at about 3K rpm and the locker does its thang,
    the ash try is always one step behind.. ;)
  14. Dec 19, 2010 at 9:51 AM
    PL408
    PL408 Member
    Joseph
    Martinez CA
    4X TACO
    FabTech lift K&N/deckplate mod
    Yes! the answer I have been looking for THANKS!
  15. Dec 19, 2010 at 9:55 AM
    JohnnyGato
    JohnnyGato God of Thunder ...and Rock N' Roll!
    Jason
    Vegas Island
    04 TRD SR5 V6 4x4 Off Road
    Limo tint, Sirius/XM radio, Wet Okole's, Weathertech's, Rhino Lining, blacked out badges, shorty antenna, painted speaker (tweeter) covers, blue LED running lights, Icon 3" lift, Pro Comp 17" 7005's, 33" (285/70/17) Good Year MT/R's with kevlar.
    This was the first thing I ever posted about. I tried the tape thing, only I used duct tape instead of electrical tape and it worked like a charm! Now the ash tray NEVER opens unless I want it to.
  16. Dec 19, 2010 at 10:26 AM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    Great, mine is a change holder as well, and "ALLWAYS" slides out after a few minutes. I think I will fix it today.
    THANKS.....!!!! :D
  17. Dec 19, 2010 at 10:31 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    Nice writeup I don't smoke and I got tired of it opening when wheelin so I just did this.
    I works well unless your in 1st gear.
  18. Dec 19, 2010 at 10:47 AM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    The lazy mans version, but just as effective is to but scotch tape on the tracks.....works like a dream for me.
  19. Feb 5, 2015 at 9:01 AM
    MD11Fr8Dog
    MD11Fr8Dog Well-Known Member
    Sean
    NC
    Double Cab
    Snorkle, sliders, OME suspension, CBI Bushmaster rear bumper/swing out tirre carrier, Addicted Off Road tubed front bumper
    1 stubby Phillips screwdriver to get out the 2 screws, and 5 mins of my time. DONE!l
    shankyjones likes this.
  20. Feb 5, 2015 at 9:08 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Whoa, this write-up is just a little overcomplicated. You should be able to pinch the ashtray and pull it out. Just pinch the door and the metal track, it will compress and you can slide it out. Then you can take apart the ash tray mechanism to redo the spring. It's two steps. LOL.
