PrezidentRedz' 2000 Tacoma 4x4
02 Suddenly started pouring oil.
Old 07-12-2008, 05:26 PM   #1
parrishga is on a distinguished road
parrishga's Tacoma Gallery
Unhappy 02 Suddenly started pouring oil.
My wife was driving my 02 Tacoma, when she said it made a loud thud noise and started shaking like it had a flat tire. She pulled over saw oil very steadily dripping under the passenger side of the engine. By the time i got there 10 min. later, the puddle was about 12 in in diameter. i checked the oil level on the dip stick and it was still showing a normal level. I will have it towed to a mechanic Monday, but I am scared to death it has thrown a rod or something. It only has about 105,000 miles and I have religiously changed the oil. Any ideas what might have happened?
Old 07-12-2008, 05:38 PM   #2
Mom says I'm special!
humanoid is a name known to allhumanoid is a name known to allhumanoid is a name known to allhumanoid is a name known to allhumanoid is a name known to allhumanoid is a name known to all
humanoid's Avatar
humanoid's Tacoma Gallery
Can you see where the oil is/was leaking from?
__________________
Old 07-12-2008, 06:56 PM   #3
Western Aliance: Fix it Division
chris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond reputechris4x4 has a reputation beyond repute
chris4x4's Avatar
chris4x4's Tacoma Gallery
Sonds like it could have been something hit the tranny? Good luck. I hope this ends well.
__________________
The simplest solutions are often the most clever..............they are also usually wrong.
Old 07-12-2008, 06:57 PM   #4
concrete jedi is a glorious beacon of lightconcrete jedi is a glorious beacon of lightconcrete jedi is a glorious beacon of lightconcrete jedi is a glorious beacon of lightconcrete jedi is a glorious beacon of lightconcrete jedi is a glorious beacon of light
concrete jedi's Avatar
Army: Shit deflector
concrete jedi's Tacoma Gallery
Losing that much oil is never a "good" thing, where is your oil filter ?
Old 07-12-2008, 07:35 PM   #5
The oil filter is still intact and shows no signs of oil loss in that area. l could not tell exactly where it was coming from because it had sprayed everywhere on the passenger side of the engine below the manifold.
Old 07-12-2008, 07:40 PM   #6
humanoid's Avatar
Do you have a 4cyl or a 6?
__________________
Old 07-12-2008, 08:00 PM   #7
Western Alliance: NorCal
Ridgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant futureRidgerunner has a brilliant future
Ridgerunner's Avatar
Ridgerunner's Tacoma Gallery
How's the steering?
__________________
Another fine sig by Piercedtiger!!
Old 07-12-2008, 10:05 PM   #8
This is a 6 cyl. and the steering hasn't been effected.
Old 07-13-2008, 07:51 AM   #9
Well... if it "sprayed" that means it's under pressure, I would check the EGR valve if your model has one. If not think where pressure would be, heads, valve covers, oil pan, etc. Be sure to check the fan, it could be blowing the oil from some place and make it look worse.
Old 07-13-2008, 07:58 AM   #10
chris4x4's Avatar
Im thinking its the tranny. If the engine oil level is good, and that much oil leaked under the engine, It would have showed a loss on the stick. Hows the tranny pan look.?
__________________
Display Modes
started shopping for Gen1 2.7 4X4 thinkingman 1st Gen. Tacomas 2 04-14-2008 06:49 PM
I started using synthetic oil missileman125fw 2nd Gen. Tacomas 16 04-02-2008 07:20 AM
Just getting started. thenrie New Members 9 02-12-2008 04:03 PM
Slowly getting started nd 2nd Gen. Tacomas 10 07-27-2007 08:21 AM
Let's get this Forum started!! mazutoytaco 1st Gen. Tacomas 9 10-18-2006 07:48 PM
Copyright © 2009 Tacoma Forum
