3.4 timing belt
Discussion in '1st Gen. Tacomas (1995-2004)' started by dzlpwrd, Sep 20, 2010.
  1. Sep 20, 2010 at 6:08 AM
    dzlpwrd
    dzlpwrd [OP] toyota fan from birth
    james
    wilton maine
    1995.5 v6 4x4 sr5
    ported air box, 3 inch custom exhaust, with cat delete, tinted windows, 4 6 inch 300 watt speakers, 2 1800 watt amps,2 6x9 900 watt speakers, pioneer recievier with ipod control, 3 inch lift, color match cap, more to come...
    so my tacoma seems to have lost some of its get up n go. i also noticed that when i have i floored at take off it kind of surges. my temp gauge is running at the half way point all the time where it used to run about 1/4. i know its time for a belt replacement but have been putting it off. so sunday morning i pulled the cover back on the timing belt it looks like the waterpump is leaking a little, the belt is not tight against the top idler pulley, all the pulleys are pitted. i guess i know what my next project is.:(
  2. Sep 20, 2010 at 6:10 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Sep 25, 2010 at 2:12 PM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    i just spoke with a friend of mine who used to be a mechanic. he says it sounds like the truck has jumped timing by the way it sputters and skips when i lug the engine. after a quick search on ebay i have found a complete timing belt kit with all the pulleys, water pump, seals, gaskets, new tensioner, and thermostat, with free shipping $288. anyone ever bought parts from ebay? the ad says oem quality and list all the manufacturers of the parts. if i go with my local parts store (napa, motor supply, vip) i will be paying about $200 more.
  4. Sep 25, 2010 at 2:14 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    oem or nothing
  5. Sep 25, 2010 at 2:18 PM
    already7
    already7 Member
    Allen
    North Little Rock, AR.
    03 4x4 TRD SR5
    I have bought several parts from Ebay. None for the Taco yet, but I wouldn't be too scared to buy online from them, but I would look very carefully at their rating. I have bought wheel and tire packages from Ebay, and several other parts also. I always buy from power sellers and not individuals when it comes to high prices objects.
  6. Sep 25, 2010 at 2:39 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    How many miles do you have on it?
  7. Sep 25, 2010 at 9:19 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I feel the same!
  8. Sep 25, 2010 at 9:35 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    It's the water pump & two pulleys are what cost the most. I've seen some of those kts & some actually state the pulleys are OEM. I like vendors who list all the manufacturers of the parts in a kit, somewhat tells you they're not trying to hide anything. Great savings if you go with one of them if you are acceptable with the parts you are getting.
    I just bought an OEM timing belt last week from an online Toyota dealer. I paid $39 for it. Now that's so inexpensive that I wouldn't even bother with going with a cheaper aftermarket belt. The OEM water pump was $99 from them but you can find ebay sellers offering the OEM pump for less.
  9. Sep 26, 2010 at 6:48 AM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    the truck has 152,000 miles on it the belt was last changed at 62,000. the belt is in very good condition it shows no cracks but its time to replace it. i seem to have a small coolant leak i am guessing from the water pump as it is original. i have always felt that oem or nothing was the way to go but most of the oem parts are outsourced anyways so why not try something different and see how the quality is. if i have this right the link to the ebay site should be right below.
    http://cgi.ebay.com/ebaymotors/Toyo...ssories&fits=Model:Tacoma&hash=item1c145f160d
  10. Sep 26, 2010 at 6:56 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    That's a good deal I think im going buy one soon
  11. Sep 26, 2010 at 11:27 AM
    00tactrouble
    00tactrouble Active Member
    South Texas
    2000 Toyota tac prerun
    New Dakota A/T tires in 31x10.50-15", 2 coat Rhino Liner on the the bed, Mossy Oak package interior, 8" bazooka system pumping my jams, Platinum system plugs underneath the hood with Gates belts keeping it turning, 6" deckplate mod and amsoil is keeping this thing lubed year around.
    A buddy of mine just did the timing system rebuilt on mine a few days ago. The truck was not leaking water but, I felt with 160,000 miles might as well do it. I purchased all the items from Napa and spent $350 dollar but I know that if there is a problem I can go and give them hell, a little hard to do so thru your computer! I was not losing power at all but prev. maintance goes a long way.
    I also started using Amsoil and has worked wonders with the temp of the truck.
  12. Sep 26, 2010 at 12:07 PM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    i think it was aroud the 375 or 400 mark at my napa with my discount. i plan to do some more checking before i buy, but the price on this kit seems very fair. i have been running mobil-1 in my truck as long as i have owned it so i dont think the oil is the problem with my temp. i agree good oil is one of the best things you can do for your engine. i think the fact that mine sat in the garage for 4 years has alot to do with the problems i now have.
  13. Sep 26, 2010 at 1:41 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    So are you going to R&R the belt your self or take it to a shop?
  14. Sep 26, 2010 at 1:55 PM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    i will be doing the work myself.
  15. Sep 26, 2010 at 2:52 PM
    00tactrouble
    South Texas
    Well, I hope all goes well with your project. My buddy did get a good deal and $375 is what I spent but so glad I changed all the parts out and running everything new. I thought about Mobil 1 for sometime after reading several threads here at TW, but wanted to try something different. I like the availability of Mobil 1 over Amsoil, I can just head out to Wally world and pick up the product. Shall see how this oil plays out this year.
  16. Sep 27, 2010 at 1:32 PM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    just got off the phone with my friend that works at motor supply. he can get me the complete kit without the fan,ac,alternator belts for $295. this kit is put out by dayco he is going to call and get more info for me. i am not going to do anything for about 2 weeks. i have too much going on to start anything else right now. i will just be stuck driving my powerstroke for a couple of weeks.
  17. Sep 29, 2010 at 6:20 PM
    00tactrouble
    South Texas
    :thumbsup:
  18. Oct 15, 2010 at 8:56 AM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    i just ordered the parts today. $310 for all including new tensioner. now i have to wait for everything to come in motor supply estimates they will have it tuesday morning. now its time to go work on my old 83 toyota plow truck, i need to get it ready to goto its new home.
  19. Oct 16, 2010 at 7:08 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    I just did mine about a month back, got it from napa they ordered it from cali. I payed 220 for it, all oem bearings, pump and belt. I changed the therm, belts, hoses and anything else that looked like it was due.
  20. Oct 23, 2010 at 7:31 AM
    dzlpwrd
    james
    wilton maine
    1995.5 v6 4x4 sr5
    i got the kit for $220 with no seals or tensioner. the tensioner was $89, and the seals were another $30. so i am at about $350 now and this kit didn't come with the accessory drive belts. if i replace them i will be at about $400. the kit from ebay was $280 with everything. i am not sure i made the right purchase. i also had to return the water pump because it didn't have the extra nipple on the thermostat housing. now i think i have all the parts time to reassemble.
