weight of aftermarket bumpers vs. stock
Discussion in '1st Gen. Tacomas (1995-2004)' started by trailmaker, Oct 15, 2010.
  1. Oct 15, 2010 at 7:34 PM
    trailmaker
    trailmaker [OP] Well-Known Member
    northern ca
    4wd reg cab
    My tacoma has had some weight gain recently with Line-x and headache rack so I was wondering if I could offset that gain a bit. Are any aftermarket bumpers lighter that stock?
  2. Oct 15, 2010 at 7:39 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    ARB about 175lbs
    Shrockworks about 140lbs
    Allpro about 110
    Aluminess about 60lbs, which is what I have.
    All great bumpers, but they are heavier than stock. Unless you are looking for a "prerunner" style bumper.
  3. Oct 15, 2010 at 7:40 PM
    trailmaker
    northern ca
    4wd reg cab
    Thanks. Good to know.
  4. Oct 15, 2010 at 7:59 PM
    1welder
    1welder Well-Known Member
    tony grace
    edgewood, tx.
    98' ext. cab
    toytec coilovers, bil 5100's, dakar leafs, e-locker rear,aussie front, 4x innovations sliders,cooper stt's 32x11.5x15, max 4 marathon seat covers,
    My front bumper only weighed 25 pounds. I don't think you will find anything lighter then that.
  5. Oct 16, 2010 at 1:31 AM
    trailmaker
    northern ca
    4wd reg cab
    The stock bumper right? Not the Smitty
  6. Oct 16, 2010 at 7:21 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    With a winch...
    When I installed mine without a winch (twice) I could just pick it up off the ground myself no problem.
  7. Oct 16, 2010 at 7:52 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    the front bumper doesn't have much to it. a 6'x4"x1/8 sheet of metal and some plastic.
  8. Oct 17, 2010 at 9:02 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    You're not gonna get a lighter bumper than the tinfoil stock one... You'd be better off beefing up the suspension
  9. Oct 17, 2010 at 9:13 PM
    TRICOMA
    Tri
    Carlsbad, CA
    I mean the 2nd gen ones. I didn't realize i was posting in the first gen.
    Here is part of the Email straight from ARB USA.
    Tri,
    The 2010 Toyota Tacoma bumpers weight is 175lbs. In the links below are the specs for the 9.5xp Warn Winch and ARB parts applications for the Tacoma.
  10. Oct 17, 2010 at 9:16 PM
    TRICOMA
    Tri
    Carlsbad, CA
    Also a winch weights about 80lbs...no way the ARB is less than 100 lbs.
    Those numbers I posted are straight from the companies. Again when I was looking for my 2nd gen. I think 1st gen would not be that far off.
  11. Oct 17, 2010 at 9:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Just mounted a Relentless Fab plate bumper. With winch (synthetic rope) the total weight was 164 lbs. The toal weight of all the stock pieces removed was 32 lbs. Net gain was 132 lbs.
    You can add about 20 lbs to that total if a steel winch cable is used.
  12. Oct 18, 2010 at 12:29 PM
    RattleTractor
    Harry
    VT
    '04 Unicorn Tacoma
    This link says the "empty" ARB weighs 78 lbs:
    http://www.expeditionswest.com/equipment/tacoma/arb_bumper.html
  13. Oct 18, 2010 at 12:35 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Man I love this bumper.. :drool:
  14. Oct 18, 2010 at 4:03 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ^ x2 i know eh holy shit do those boys ever do some good work
  15. Oct 18, 2010 at 7:39 PM
    trailmaker
    northern ca
    4wd reg cab
    Thanks for the info. That bumper looks great. So great in fact that now I'm trying to rationalize a 132lb weight gain.
  16. Oct 18, 2010 at 8:16 PM
    MowTaco
    Kansas
  17. Oct 20, 2014 at 9:35 PM
    Brandmind
    Brandmind New Member
    Brandon
    Utah
    2002 tacoma
    None yet
    Where can I get that winch bumper that you have on yours
  18. Oct 20, 2014 at 9:50 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
  19. Oct 20, 2014 at 10:26 PM
    Digiratus
    Roaming the PNW
    The RedHead
    At the time, the 2 guys from Relentless Fab (Tim and Eric) were partners. So technically, this is a Relentless bumper. But soon after this, Tim and Eric parted ways and Tim went on to build and sell this design as an Elite Offroad bumper.
    Right now, you can't buy this bumper unless you find someone willing to part with theirs. Elite is no longer making them.
    Eric (Relentless Fab) is still selling bumpers, though his design is not the same as this one.
  20. Jun 7, 2016 at 11:42 AM
    alexmb1
    alexmb1 Member
    Virginia
    2010 TRD Sport Double Cab
    Exterior: Fab Fours Rear Bumper N-Fab Nerf Bars Front: Bilstein 5100 (1st setting) Headstrong Off-Road Coil Rear: Headstrong Off-Road Leaf Pack Bilstein 5100 (Ext. Length) Tires: 265/70/17 Falken WildPeak AT3W Interior Pioneer FH-X820BS Image Dynamics x4 (TacoTunes)
    i am looking to add the IronBull rear bumper to my 2010 TRD Sport. I am concerned that the additional 100lbs (without winch) will really put some wear and tear on my truck. Any suggested mods to counter? i am expecting "suspension" as a response but was hoping someone out there can provide some more detail on exactly what they did. For instance, more leaves in the rear, stiffer shock, etc. have i answered my own question or can i actually get away with leaving the TRD sport suspension as is?
