Stock airbox
Discussion in '1st Gen. Tacomas (1995-2004)' started by xxiong12, Oct 23, 2010.
  1. Oct 23, 2010 at 1:11 PM
    xxiong12
    xxiong12 [OP] Member
    Hi everyone. I was just wondering if a stock 2.4 intake assembly fit on my 2.7. Because I am looking to buy one for my 2.7. Thanks
  2. Oct 23, 2010 at 4:06 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I'm pretty sure they're the same. Do you currently have one you could take a picture of? Or is yours completely gone?
  3. Oct 24, 2010 at 5:36 PM
    xxiong12
    Mine is completely gone.
  4. Oct 24, 2010 at 5:42 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I dont think the 2.4 and 2.7 are interchangable. The whole intake unit routes to the throttle body which looks to be more on top on the block with the 2.4 rather than the 2.7 engine has the throttle body more to a side.
    so essentially what im trying to say is that the 2.4 looks like the piping goes parallel with the ground and the 2.7 looks like it goes more vertical to the throttle body
    [​IMG] 2.7 2tr-fe
    [​IMG] 2.4 3rz-fe
  5. Oct 25, 2010 at 2:58 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Im pretty sure the OP was wandering about the 3rz (2.7l) for the first gen. And the first gen 2rz (2.4l) ;)
  6. Oct 25, 2010 at 9:32 PM
    MowTaco
    Kansas
    Me too. From what I've seen, the boxes are the same. The 2.7 you have there says VVT-I on it, which is only on the 2nd gens.
  7. Oct 26, 2010 at 7:33 PM
    xxiong12
    So should I get the 2.4 to replace my 2.7?
  8. Oct 26, 2010 at 7:41 PM
    MowTaco
    Kansas
    How about this... Ill put up a pic of my 2.4. Someone else put up a pic of their 2.7 airbox (please :wink:) Then we'll compare.
  9. Oct 26, 2010 at 7:44 PM
    MowTaco
    Kansas
    Here it is... pre deck plate even
  10. Oct 27, 2010 at 3:35 PM
    scriber007
    scriber007 Well-Known Member
    Should be the same on the 1st generation. I use the have the 2.4 2000 model, replaced the intake system with k&n air intake, and then sold the truck. Then I bought a 2.7 2004 2wd truck to upgrade the intake system, realized I should have kept the k&n from previous truck. It is completely identical.
