Mounting Inverter in-cab
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cdavis, Oct 25, 2010.
  1. Feb 26, 2011 at 1:32 PM
    #21
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Where did you get the plug and how did you mount it to your console?
  2. Feb 26, 2011 at 1:45 PM
    #22
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    i do believe i will be stealing htis idea :D mine is under the passenger seat hardwired and i hate having to run wires through the whole cab, this would be so much cleaner!
  3. Feb 27, 2011 at 12:34 AM
    #23
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    The plugs come from the actual inverter itself. I just took them out, extended the wires and relocated them. I cut holes the same size as the plugs in the dash using a dremel.
    The cig lighter was from kragen or something.
    Thanks!
  4. Aug 15, 2013 at 10:34 AM
    #24
    cynicalrider
    cynicalrider #NFG
    Jersey
    01 SR5 TRD 4x4, '23 Bronco Wildtrak, 2017 HSQV FE350
    Drop bracket lift and booger welds
    Subbing for my hardwire install.
  5. Aug 15, 2013 at 10:50 AM
    #25
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I'm about 3/4 of the way through installing my inverter.
    I installed my 800 watt cobra inverter under the passenger seat. I ran 8 gauge wires from the battery, through a 100 amp fuse, through an existing grommet in the fire wall. They enter the cab to the left of the pedals. The wires go above the pedals then head toward the rear of the cab by the shifters. I installed a switch under the stereo. The wires come out under the center console and go under the seat.
    Rather than taking apart the inverter and voiding the warranty I'm extending the wires to a pair of something like these:
    http://www.amazon.com/Amico-Panel-M...8&qid=1376588863&sr=8-3&keywords=panel+outlet
    I'm extending the USB with this:
    http://www.amazon.com/Clarion-CCAUS...d=1376588939&sr=8-19&keywords=usb+panel+mount
    I figure this way if I want to move the inverter to another vehicle it won't be a hassle
