Front Driveale, CV boot leaks
Old 12-26-2010, 08:32 PM   #21
Can you skin Grizz, pilgram?
tacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shedtacomakid96 is one of the sharper tools in the shed
tacomakid96's Avatar
tacomakid96's Tacoma Gallery
Question
Originally Posted by 4WD View Post
I'd go OEM if you can afford it but some decent rebuilt ones are ok too
& you'll save a few $$$
Where did you get your from?
Old 12-26-2010, 08:44 PM   #22
4WD 4WD is offline
cRaZy oLdmAn
4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed4WD is one of the sharper tools in the shed
4WD's Avatar
4WD's Tacoma Gallery
I got them thru my friends shop, I know they weren't from Toyota but I'll find out tomorrow for ya buddy..
Old 12-26-2010, 08:52 PM   #23
Thanks alot doug, once again you pull through for me
Old 12-26-2010, 10:13 PM   #25
Modified Glamper Extraordinaire
Digiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shedDigiratus is one of the sharper tools in the shed
Digiratus's Avatar
Location: Exploring the Pacific NW including ID, MT, WYO & CO
Digiratus's Tacoma Gallery
What axle brand do you guys recommend?
It all depends on why there was a problem in the first place and whether you think its going to happen again.
Several of the auto parts houses are offering lifetime warranties on their rebuilt units, at pretty reasonable prices. Something you wont see with new OEM parts.
Old 12-26-2010, 10:15 PM   #26
I cleaned all the greese and i tore the outer boot, I have a lift so my cv's are kinda angled, so it will happen more often then a stock truck.
Old 12-26-2010, 10:44 PM   #28
So it wasn't leaking from the clamp like GOLFMAN845's axle was. His was the clamp on the inner boot. Where on the outer boot is it torn? Do you suppose the fins might have been touching there where the tear occurred?
How much lift do you have? Is it from 5100? Diff drop?
I'll have to see if the fins were touching, I have a 2.5"spacer and I do not have a diff drop and it is not a lose clamp there is a tear in between the fins
Old 12-26-2010, 11:03 PM   #30
ETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shedETaco23 is one of the sharper tools in the shed
ETaco23's Avatar
ETaco23's Tacoma Gallery
I had the same issue with my 02, just took it to my local machanic and he snugged up the clamps and it never leaked again.
Old 12-27-2010, 08:57 AM   #31
If the fins touch, even a little bit, a groove will form at the point of contact. The boot will eventually tear where there is contact. If this is the root cause, a diff drop kit may lower the axle angle enough to keep it from happening again.
I have the kit I just never installed it because I heard that you can get vibs from moving your diff. Maybe its time to install it
Old 12-27-2010, 09:13 AM   #32
Honey badger hits whatever tree he wants to hit!!
Honey badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shedHoney badger is one of the sharper tools in the shed
Honey badger's Avatar
Army: 99 Zulu
Honey badger's Tacoma Gallery
I just had the same issue with my 02 nothing was torn but the claps were not tight. Went to a friends shop used some tool to tighen them but still leaked. I also have a lift with no diff drop but will be getting one vibs or not vibs its a truck not made to ride smooth. I got him to get new shafts from Napa so far so good and not bad on price with lifetime.
Old 12-27-2010, 09:57 PM   #34
ETaco23's Avatar
^^^Verry true! I just did my lift and have the damn vibe. It sucks! diff on or off doesnt seem to help. I may just deal with it, bc Im out of warrenty. Or get the RCD kit later on... I miss my 02!
Old 12-28-2010, 09:00 AM   #35
GOLFMAN845 has a spectacular aura aboutGOLFMAN845 has a spectacular aura aboutGOLFMAN845 has a spectacular aura about
GOLFMAN845's Avatar
GOLFMAN845's Tacoma Gallery
Originally Posted by BoostingMS6 View Post
If and when you do ever replace, I suggest this route, too. You can also get some at Autozone. I got mine for $150 each, but they have lifetime warranties and you get $100 back for bringing in your old ones. So in the end, each CV half axle costs a one time fee of $50 to replace, and it doesn't take long. If its your first time tearing it all apart, it'll probably take you a while, and the cone washers may be a pain.
Well I replaced my front axle's Sunday drove it back to St. Louis last night, then came out and found this morning.
I am going to take it back apart tomorrow and put in a new Output Shaft Seal in it. Will probably do both sides, just to be safe.
Old 12-28-2010, 11:40 AM   #36
BoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shed
BoostingMS6's Tacoma Gallery
^^^ Wow. Did you get yours from Autozone?
Old 08-26-2011, 10:49 AM   #37
TIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shed
TIPICOTACO's Avatar
TIPICOTACO's Tacoma Gallery
need some advice
Well I noticed a few spots on the driveway and I'v been able to track it down to the drivers side inner CV boot. There doesnt seam to be a tear of any sort, but there is a considerable grease leak going on that appears to be coming from the inside (larger) boot seal..
I'v read that it is easier to replace the whole thing instead of just the boot but I kinda down have the time or $ to do that right now.. Are there any other options for a fix? refill grease? How long do I have til this creates a bit problem?
I'v had the truck less than a month and have no idea how long the problem has existed. Thanks!
Old 09-19-2011, 09:51 AM   #38
FrozenChozen is on a distinguished road
FrozenChozen's Tacoma Gallery
Whats up all. I had a small tear, maybe 2mm, But grease was coming out. I cleaned it off and put some Gorilla Glue on it. It was on the outer fin of the boot where there would be no contact from the other fins. Any thoughts on this Ghetto / McGuyver-esqe fix. And how much does Toyota charge to change out the boot?
Thanks in advance.
Old 09-19-2011, 10:08 AM   #39
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
Thanks in advance.
if it holds awesome! its a bit too late for me though, my drivers side boot is completely torn in 2. I need to get that replaced, just no time lately.
Old 09-19-2011, 10:28 PM   #40
Digiratus's Avatar
Thanks in advance.
Might as well replace the whole axle. A lot simpler and less time consuming than trying to replace just the boot. Axles with lifetime warranties are cheap. My buddy paid $75 at Vatozone for his.
CV boot slippage?? 06rubi Suspension 0 08-27-2011 04:09 PM
cv boot jblair 1st Gen. Tacomas 51 07-14-2011 10:56 PM
Front Dif Leaks After CV Install Mootsman 1st Gen. Tacomas 18 04-30-2011 10:07 PM
cv boot fix westport toyota 2nd Gen. Tacomas 8 02-08-2011 08:17 PM
cv boot danstacoma 2nd Gen. Tacomas 1 12-25-2010 09:43 PM
