outside air temp sensor/reader
Discussion in '1st Gen. Tacomas (1995-2004)' started by vantaco, Nov 23, 2010.
  1. Nov 23, 2010 at 8:26 PM
    vantaco
    vantaco [OP] Well-Known Member
    02 Taco Xtracab TRD Step Side
    just curious if there is a mod to add an exterior air temperature sensor and reader...ie using a mirror or something else from another toyota model
    any info would be great
    thanks
  2. Nov 23, 2010 at 8:50 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    FWIW I was able to add in an XGauge code to my ScanGauge II that reads the air intake temps. Pretty cool actually. When I'm rolling down the road the readout on the SGII seems to be consistantly 5* higher than outside temps.
    I do have the deck plate mod with the cover off.
  3. Nov 24, 2010 at 5:50 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    That is the same thing that I do. My ultragauge shows my intake temp and since I have the deckplate mod, I know that the temp is gonna be close to what it is outside.
  4. Nov 24, 2010 at 7:34 AM
    Simon's Mom
    Simon's Mom Wag More Bark Less
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I added a $10 wireless accurite from WalMart.
    Painted it with Testors Black Model paint.
    Put the wireless sensor tucked up /velcro'd up by the spare.
    Gives inside and outside temps.
    Added a little light setup for night time.
  5. Nov 24, 2010 at 7:58 AM
    vantaco
    ok..i'm not getting a SC do that's out...and i'd like to keep it oem if possible
    do tundras have the outside temp displays?
  6. Nov 24, 2010 at 9:51 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    What dept at Wal-mart is that temp gauge in ?
  7. Nov 24, 2010 at 10:01 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
  8. Nov 24, 2010 at 4:56 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    My WalMart had the Accurites near the hardware with all the weather stations, fancy outside thermometers etc. I think Mark got his in the auto section, but he could tell you for sure. My light came from Walmart too in auto.
