285/75/16 on 2.5" lift and an AAL?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Phuket, Jan 7, 2011.
  1. Jan 7, 2011 at 8:02 PM
    Phuket
    Phuket [OP] Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    I have an 03 dc TRD 4x4 and i plan on lifting it with billy 5100's on all corners as well as an AAL in the rear, I wanna know if 285's will fit without any rubbing? Can you post pics of your rig with this setup or a similar one? all info is greatly appreciated!
  2. Jan 7, 2011 at 8:07 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    No they will rub pretty well
  3. Jan 7, 2011 at 8:21 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Here is my old setup. 285/70/17. Bilsteins were set at 2.5" with a 1.5" AAL. They didn't rub much after I trimmed but near the end they were rubbing a lot. I switched back to 265 ATs.
  4. Jan 7, 2011 at 8:23 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    DAMN that is one clean nice looking truck! :thumbsup:
  5. Jan 7, 2011 at 8:25 PM
    YellowDog01
    04 4x4
    Thanks. As much as I loved the way it looked, I ended up hating my Mud Terrains. I hated the sound of the rubbing and just got a headache from the constant noise of the tires.
  6. Jan 7, 2011 at 8:27 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Here was mine with 285's.....at the time had 2.75" front lift with 2" AAL out back. No rubbing except at full lock on frame. Not bad rubbing tho. My CV's weren't gonna last long though with that much lift.
  7. Jan 7, 2011 at 8:28 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    Nice truck! how much did you have to trim?
  8. Jan 7, 2011 at 8:29 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    How do your billys ride set at 2.5?
  9. Jan 7, 2011 at 8:32 PM
    NegroTundra
    Land of Enchantment
    No trimming...only rubbed on the frame and only at full wheel lock. But, glad I went to 265's for my purposes...but I will admit I kinda miss the look.:D
  10. Jan 7, 2011 at 8:35 PM
    YellowDog01
    04 4x4
    Better than stock for sure.
    I now have Bilsteins set at 0" with OME 881 coils. I recommend this setup, I like it a lot. Better than Bilsteins with stock coils.
  11. Jan 7, 2011 at 8:36 PM
    YellowDog01
    04 4x4
    X2, I did the same thing you did. Went from 285s to 265s. But I like the way it drives now. I see we have the same suspension too!
  12. Jan 7, 2011 at 8:37 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    I have 5100s with Eibach coils and AAL out back and 33x12.5's and I just rubbed up front on the fender until I cut a lot off.
  13. Jan 7, 2011 at 8:45 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    Nice ride!!:D but what was the tire size? 285/?/?
  14. Jan 7, 2011 at 8:50 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Thats the setup I was thinking about going with, well the whole OME setup from wheelers off road. I was thinking of either that kit or coilovers either kings of icon. I want to get a full 3 or close to it. I know with your setup they have the trim packer kit for OME coils.
  15. Jan 7, 2011 at 8:59 PM
    NegroTundra
    Land of Enchantment
    285/75/16
  16. Jan 7, 2011 at 11:50 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Just put 285's on mine. Lil rubbing at fenders during articulation, not bad at all. Pinch weld mod fixed most. I have no frame rubbing, maybe cuz my wheels have 4" bs not 4.5" like most. I have like 2.25" lift, maybe settled to 2" and I'm glad I stepped up from 265s. Just my 2 cents.
  17. Jan 8, 2011 at 11:10 AM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    Thanks! you got a nice lookin rig!:D but it sounds like im gonna have to trim if i want 285/75/16 to fit? Can you post a picture down the side of your truck.... i'd like to know how much your tires stick out. thanks!
  18. Jan 9, 2011 at 12:13 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Ya I will get one for ya soon. They don't stick to far at all the rims are only 4" bs so that's only a 1/2" per side. The 285's are a lil wider also though. I did just a lil trimming with a dremal then based the pinch weld over flat with a BFH, painted it and that's all. Google tacoma pinch weld mod. Think it was customtacos that had a good lil right up. TTORA has one too, or a link or something. Very easy. My tires rub just a hair at full articulation on the fender flares. Not enough to worry, I will trim a touch more one day. On the road no rub after pinch weld mod.
  19. Jan 9, 2011 at 12:19 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    Ya Mudders do hum, and the larger pigs will make a lil bit louder rubbing sound when they do rub. But its not the tires that cause u to rub more in the end, it seems to me that it would be the coils are worn or sagging. Did u put stock coils on the billies....some ome coils or such would have helped.
  20. Jan 9, 2011 at 12:38 AM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    what lift do the 881 coils give with billies at 0?
