starter rebuild
Old 01-15-2011, 11:11 PM   #1
98Tacoma [OP] 98Tacoma is offline
98Tacoma is on a distinguished road
98Tacoma's Avatar
98Tacoma's Tacoma Gallery
starter rebuild
i have a 1998 tacoma 3.4 v6 and i believe my starter is going out. sometimes all i get when i trun the key is one click takes some times 5-6 of turning the key it finally cranks. has anyone rebuilt there starter. if so do yall have a write up with pictures.lol i know that you have to replace the plunger and the contacts is there anything else. i know i can get a starter for 100 bucks but probly not as good as the oem starter
Old 01-15-2011, 11:19 PM   #2
98Tacoma's Avatar
Originally Posted by h2oplaydamian View Post
what are your volts when you try to start ?
im not real sure ill have to put the meter on it tomorrow
Old 01-15-2011, 11:37 PM   #3
bite me
humanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shedhumanoid is one of the sharper tools in the shed
humanoid's Avatar
humanoid's Tacoma Gallery
You mean a DIY with pics like this?
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 01-15-2011, 11:39 PM   #4
98Tacoma's Avatar
yes sir. thank you
Old 01-15-2011, 11:40 PM   #5
98Tacoma's Avatar
i just found this to. i guess the 200 4runner would have the same starter or close to it. i guess all i need to change are the contacts. and just clean up the plunger
http://www.yotatech.com/f2/3rd-gen-3...-heavy-105098/
Old 01-16-2011, 11:21 AM   #6
98Tacoma's Avatar
if i go to a starter rebuild shop could i just match up contacts and reuse the bolts and just clean the plunger if its in good shape
and put everything back rogether.
Old 01-16-2011, 08:37 PM   #8
In over my head...
james has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant futurejames has a brilliant future
james's Avatar
Army: P.O.L.
james's Tacoma Gallery
I had the exact same symptoms, and asked the exact same question: Thanks to the kind folks that posted to my link, I saved gobbs of money. Here's the link:
http://www.tacomaworld.com/forum/tec...ml#post2288177
Old 01-16-2011, 09:24 PM   #9
98Tacoma's Avatar
thanks man. yea i think im going to go to a shop that rebuild starters and buy 2 contacts from them so that i can keep the factory starter
Old 01-17-2011, 09:47 PM   #10
98Tacoma's Avatar
well i got in the truck today and it started on the first crank everytime. then tonight it started up but started making aloud screathing noise i cut the truck off and it sounded like th starter was still running then tried to start it again and it started up fine. what could have made that noise even after the truck was running?
How To: Rebuild the Tacoma Starter Motor ItalynStylion Technical Chat 12 01-28-2015 07:48 AM
HOW TO: Remove/Install a starter/fix a clicking starter (2.7 liter 3RZ-FE engine) trdracing5 1st Gen. Tacomas 40 01-21-2015 06:16 PM
Rebuild hillinsan Toyota Trucks & SUVs 5 12-11-2011 08:49 PM
Which starter contacts to buy to rebuild starter 87xjmike 1st Gen. Tacomas 3 11-14-2011 02:06 PM
4.0 L Starter Rebuild / Brush Kit Question jackal419 2nd Gen. Tacomas 9 08-30-2009 06:38 PM
