2004 Tacoma OBD port and scanner ??
Old 01-24-2011, 08:03 AM   #1
HikerLT [OP] HikerLT is offline
HikerLT is on a distinguished road
HikerLT's Tacoma Gallery
2004 Tacoma 4x4 regular cab
41k miles, just had the check engine light come on, and stay on, this weekend. Its was fairly cold, maybe around 12 degress F, not too cold. When I release the gas cap, there was pressure behind it...it wasn't loose.
Questions:
1) where is the OBD port located?
2) Is there a special adapter required to connect to a Toyota OBD port ? ( my reason - went to borrow a OBD scanner from a co-worker, and when I said that it was for a Toyota he said that Toyota requires an adapter for his scanner to fit)
3) I see thatthe method of resetting the maintenence light on 2005 and up will not work here ( holdng the odometer button)....So is the only way to reset the light to do it either by reset thru a scanner tool, or by removing the ( Positive or ground) connection to the Battery for 15 minutes ?
4) Should I reset the light before getting a scan code reading, to see if it comes back on ?
5) Any danger in driving the truck like this, with the light on ? Nothing feels or runs different...??
Thanks for any tips and advice.
Old 01-24-2011, 09:45 AM   #2
EnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shedEnolaGaia is one of the sharper tools in the shed
EnolaGaia's Tacoma Gallery
The OBDII connector (DLC3 connector) is under the dash near the center console. Look in the vicinity of the parking brake.
No special adapter necessary for the port.
Yes - the only way to reset the check engine light (which is not the same thing as a maintenance reminder light) is to clear the code(s) or disconnect power for a few minutes.
If there are no noticeable symptoms, I'd suggest resetting the CEL once to see if the warning light comes back on. It is possible for transient conditions to trigger a CEL.
PLX DM-100 OBD II Scanner Questions SManZ Performance and Tuning 2 03-11-2013 11:46 PM
OBD II bluetooth scanner?? MMazz365 Product Reviews 6 01-13-2012 08:24 AM
OBDII port scanner..iPhone/iTouch App! Taco Gunner 2nd Gen. Tacomas 7 08-12-2010 02:52 PM
OBDII port scanner boser65 2nd Gen. Tacomas 27 06-21-2008 02:24 PM
OBD 2 Scanner castiron63 1st Gen. Tacomas 2 11-22-2007 07:02 AM
