coolant leak
Old 02-12-2011, 04:04 PM   #1
PeterNM [OP] PeterNM is offline
PeterNM is on a distinguished road
PeterNM's Avatar
PeterNM's Tacoma Gallery
coolant leak
on my 97, 2.7l i have a slight coolant leak on the upper, passenger, rear engine block. a while ago i replaced the tempture sending unit that is roughly in the same location....so i checked and rechecked the sending unit and it looks dry. the coolant level in the resevor is at the full line and the level in the radiator was full not quite to the cap....it is now out of eyesight. could it be possible that when i refilled the coolant i overfilled?
Old 02-12-2011, 05:11 PM   #2
Carolina Alliance: Lead, follow, or get the hell outta my way
tacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shed
tacomaman06's Avatar
tacomaman06's Tacoma Gallery
thats very possible.
best way to check for a coolant leak...that i have found.....drive around for a while then park...and put some clean carbboard under the engine compartment. that way, you'll see if you have any leaks, and you can go from there.
Old 02-12-2011, 09:48 PM   #3
Solid Axle FTMFW!!
Supra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shed
Supra TT's Avatar
Supra TT's Tacoma Gallery
Or even a white peice of paper, shows up easier!
Old 02-12-2011, 11:14 PM   #4
BoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shedBoostingMS6 is one of the sharper tools in the shed
BoostingMS6's Tacoma Gallery
^^^ Cardboard won't blow away super easily though. Tape the paper if you're going to use it instead.
Old 02-13-2011, 10:35 AM   #5
PeterNM's Avatar
found the coolant leak, however it's not what i expected so i still need guidance....please look at the picts and tell me what am i looking at and how to i fix it.......http://www.tacomaworld.com/gallery/s...35682/cat/500][/url]www.tacomaworld.com/gallery/showphoto.php/photo/135684/cat/500][/url]
Old 02-13-2011, 11:21 AM   #6
what part is that? i cant really tell....
Old 02-13-2011, 11:34 AM   #7
PeterNM's Avatar
the fsm says it's the water valve control cable....
Old 02-13-2011, 11:36 AM   #8
maybe its the cable fitting that has gone bad. what i would do is clean it off really well and dry it up, and let truck run and see if it is coming from a hole in the cable...or from the fitting and then get what you need. im gonna bet the fitting has gone bad.
Old 02-13-2011, 11:54 AM   #9
PeterNM's Avatar
i cleaned it, let it run.....it you look at the picts above the arrow there's a small screw, i believe that's where i'm getting the leak.....i've looked in fsm and haynes and did not find a how to fix or take apart...i did try and tighten the screw but it was tight....i'm just checking to see what is now involved with replacing that part or if anybody has done this job....thanks
Old 02-13-2011, 12:18 PM   #10
SUPMO72 is on a distinguished road
SUPMO72's Avatar
SUPMO72's Tacoma Gallery
Thats the valve that regulates the coolant to the heater core. Its leaking from the saft inside the valve under the screw that you see.
Old 02-13-2011, 12:22 PM   #11
PeterNM's Avatar
makes sense....ever have to replace it??
Old 02-13-2011, 12:41 PM   #12
REALLY!!
mrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shedmrp192 is one of the sharper tools in the shed
Air Force: F-22 Crew Chief
mrp192's Tacoma Gallery
that looks like a easy remove and replace. the 2 lines and valve switch. then the mounting bolt.
Then just the coolant bleed..
Old 02-13-2011, 02:05 PM   #13
PeterNM's Avatar
yes....i'm checking on the price of the valve switch from toyota.....any advice on the coolant bleed?
Old 02-13-2011, 03:49 PM   #14
REALLY!!
take off the rad cap and run your heater on high for about 15 mins.. rev the eng every few mins to get out the air bubbles..
Old 02-13-2011, 04:11 PM   #15
PeterNM's Avatar
will do....thanks for the help.
Weird Coolant Leak sandguy77 1st Gen. Tacomas 6 02-03-2012 10:49 PM
Coolant leak EDJY 1st Gen. Tacomas 2 06-09-2011 12:48 AM
coolant leak BlazeTaco 2nd Gen. Tacomas 4 05-02-2011 01:48 PM
Anyone with coolant overflow hose leak? Frogdaddy 2nd Gen. Tacomas 9 04-19-2010 07:55 AM
Possible Coolant Leak??? dbbd1 2nd Gen. Tacomas 7 07-04-2008 08:46 PM
