normal operating temperature
Discussion in '1st Gen. Tacomas (1995-2004)' started by dustinclm, Feb 27, 2011.
  1. Feb 27, 2011 at 2:45 PM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    just curious so i thought i'd ask, on my 2001 1st gen the thermostat doesnt have any numbers, i was just wondering what the optimal temperature range would be? the temp needle is usually a hair above half way which is about the 700rpm marker...i dont think anything is wrong but just wanted to know a number since i just flushed the radiator system today which really needed it
  2. Feb 27, 2011 at 9:00 PM
    Simon's Mom
    Simon's Mom Wag More Bark Less
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    when I had my scangauge, I would watch the water temp ## go up and settle around 175-185 degrees. That would show on the analog gauge the needle at the half way mark.
    In the summer sometimes, it would spike to around 190-192.
    In the winter, the needle wouldn't even start moving until the truck reach around 125. Not sure if this helps or not.
  3. Feb 27, 2011 at 9:06 PM
    ibengineer
    ibengineer Well-Known Member
    California
    00 Tacoma TRD 4x4
    Dirt Logic 2.5" Coilovers, Camburg UCA's, Icon 3 Leaf add-a-pack, billy 5100's in the rear, Custom front Plate bumper, XRC 8500 lb winch, lots of little mods
    this is exactly where mine sits. Its funny because it gets there so fast and stays there no matter what the temp is outside (from 30 degrees to 110).
  4. Feb 27, 2011 at 9:07 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    mine gets to 190-200 water temp within 2 miles
  5. Feb 27, 2011 at 9:36 PM
    dustinclm
    Thibodaux, La
    yeah mine will get to its usual spot pretty quick and stay there no matter the temp outside and no matter how hard ive pushed the truck it never got any hotter but i was just wondering the number it usually stays around. thanks gys
  6. Feb 27, 2011 at 9:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Mine behaves pretty much as your does, with the analog needle riding slightly above half way and not fluctuatng very much.
    According to my scangauge, normal water temps range at 198 to 202*F regardless of load or use.
  7. Feb 27, 2011 at 11:10 PM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    I think there was a thread about this a while back...
    anyway general consensus is a hair above the halfway mark is what most taco owners see...
    as far as exact temp...I guess these scangauge guys are more dialed in! (can't wait till I can get mine!)
  8. Feb 27, 2011 at 11:11 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    191-197 here
  9. Feb 28, 2011 at 8:34 PM
    pt law
    pt law Well-Known Member
    Steve
    Concord, NH
    04 xtracab 4x4 TRD
    I do not have the actual temp but here is what mine looks like at running temp. It goes there and never moves.
  10. Feb 28, 2011 at 8:41 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    a little hot. I'd guess around 215* or so.
    4drtaco03 likes this.
  11. Feb 28, 2011 at 9:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, a little higher than mine too. Probably OK for northern climes but might pose a problem when wheelin on a 100* day.
  12. Mar 1, 2011 at 3:38 PM
    pt law
    Steve
    Concord, NH
    04 xtracab 4x4 TRD
    I do not mean to hijack the thread, but can someone recommend where to start if this is running a little hot (see pic in above thread). I checked my radiator fluid (it is the toyota factory long life pink stuff that you change at 100K and my truck has 85K) and it is not eating fluid. I also checked my hoses and radiator and cannot find any leaks. The top hose does feel quite hot coming out of the block but the bottom hose is cold. Faulty temp gauge? Radiator clog so get a cleaning or new radiator? Change the fluid out?
    Second, the top of the radiator feels quite hot along the entire top plastic surface from left where the hose comes in to the right side where the cap is. Is that normal?
    Thanks for the help.
  13. Mar 1, 2011 at 4:00 PM
    dustinclm
    Thibodaux, La
    this is where my guage sits and has always been since i have had the truck. it has never been higher than this or much, if any, lower and i havent had any over heating problems and i have run this thing pretty hard mud riding on the farm so id safely say this is normal.
    i flushed my radiator system over the weekend and the needle is still right there
  14. Mar 1, 2011 at 4:18 PM
    pt law
    Steve
    Concord, NH
    04 xtracab 4x4 TRD
    The first pic is from another thread on this site. So I am getting people saying that it should like the first pic below and others saying it looks like my pic, the second pic below. What is normal?
    [​IMG][/QUOTE]
  15. Mar 1, 2011 at 5:31 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    My 2RZ runs 188-190 usually. In winter (well San Diegos winter) I run 184-186 without the fans on.
  16. Mar 1, 2011 at 5:48 PM
    dustinclm
    Thibodaux, La
    ill try and remember to get a picture of mine tomorrow
  17. Mar 2, 2011 at 1:37 PM
    dustinclm
    Thibodaux, La
    this is where im at all day, 30* outside, 100* outside, pulling my boat or mud ridding...
  18. Mar 2, 2011 at 2:48 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    This has been my temp since I bought my truck.
  19. Mar 2, 2011 at 2:56 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I'd say around 180f*, I lived in texas and in the summer we'd take the thermostat out of the block cuz it wouldn't do any good in that heat any way.Although if you run like that you'll never get warm in the winter unless you put it back in.
  20. Mar 2, 2011 at 3:19 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    My 3.4L sits steady at 194-195 regardless of outside temps or engine load.
