HOW TO: Change Your Spark Plugs and Wires (2.7 liter 3RZ-FE engine)
Old 02-01-2013, 11:31 AM   #21
trdracing5 [OP] trdracing5 is offline
trdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shedtrdracing5 is one of the sharper tools in the shed
trdracing5's Avatar
trdracing5's Tacoma Gallery
Originally Posted by ohcray View Post
I'm probably the only noob reading this, but I have an '04 2.7L with 200K miles on it and will be replacing the plugs and wires soon. But where are the two things mentioned above located? I wish there was an exploded view of the engine and tranny somewhere with everything labeled...
OP-Great instructions, by the way!
Glad it was able to help you.
BTW you do not have a rotor you have a coil pack so you dont have to worry about the rotor!
<Image of Coil Pack>
Old 07-26-2013, 03:46 AM   #22
Ellisd51 is on a distinguished road
Ellisd51's Tacoma Gallery
Firing order
Great post, but you gave the lower right location on the distributor to both the number two and the number three plug wires and my cap is numbered but not in the same manner as your instructions. If distributor rotates clockwise I have number one in the top right, below that there's number 2, lower left is number 4 (not 3) then number 3 at upper left. Which makes me think something's wrong here and I confirmed and labeled my routing before disassembling or reading your post. Can you give me a hollar back with your decision on which is the correct way? Please, and much abliged for all the otherwise seemingly helpful info.
Old 07-30-2013, 09:48 PM   #23
cj.ainsworth77 is on a distinguished road
cj.ainsworth77's Avatar
cj.ainsworth77's Tacoma Gallery
I had to pull the intake tube out of the way...pain in the ass to get those two nuts off the bottom of it...especially when the exhaust manifold is still hot
Old 08-17-2013, 07:14 AM   #24
member-in-training
tibblits920 is on a distinguished road
tibblits920's Avatar
tibblits920's Tacoma Gallery
Thanks for the write up OP. Very helpful for noobs like me 😎
Old 08-31-2013, 12:01 AM   #25
99TacoNC
raginmd is on a distinguished road
raginmd's Avatar
raginmd's Tacoma Gallery
just got the CEL code for a cylinder 2 misfire. will be doing this tomorrow. rep for you sir!
Old 10-16-2013, 06:27 AM   #26
havenoclu is on a distinguished road
havenoclu's Avatar
havenoclu's Tacoma Gallery
Great write up, thanks!!
Old 01-24-2014, 10:52 AM   #27
tacosoup89 is on a distinguished road
Firefighter: Wildland Firefighter
tacosoup89's Tacoma Gallery
Im a noob too and I have question about my 2003 2.7 and why does this year model does not have the traditional plug wires like what is pictured above. Mine has individual ignition coils on each cylinder but no plug wires. These plug wires look as if they are tied into a wiring harness??
Old 02-23-2014, 01:59 PM   #28
mech160 is on a distinguished road
mech160's Tacoma Gallery
tacosoup89 your truck's ignition is controlled by a computer, TDI -Toyota Direct Ignition, a distributor-less ignition system. Since you have no distributor, you are not going to have; cap, rotor, and spark plug wires. You are just going to have electrical wiring, from the computer, going to each ignition coil that sits on top of each spark plug.
Old 08-22-2014, 11:17 AM   #29
NCforMe is on a distinguished road
NCforMe's Tacoma Gallery
Could someone spread some knowledge on me? Is there a different time period between changing the spark plug wires on older 1st gens, than the coil packs on the newer ones? I'm not really sure what the benefit is of having to replace 4 packs at $60-80 EACH, vs. $60 for an entire wire set.
It's also confusing that when I search for "spark plug wires" for my 2004 2.7l at a Advanced Auto Parts website, the return shows the same wires I had on my 1999.
Also, does anybody replace the connecting wires of the coil packs?
Thanks!!
Old 08-22-2014, 04:25 PM   #30
ToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shedToyoTaco02 is one of the sharper tools in the shed
ToyoTaco02's Avatar
ToyoTaco02's Tacoma Gallery
I haven't heard of anyone replacing the coil packs unless they are bad.
Old 08-29-2014, 09:04 PM   #31
Tdkrum5 is on a distinguished road
Navy:
Tdkrum5's Tacoma Gallery
cylinder 2 misfire
Raginmd , what did you find out about this? My sons is now doing the same thing. We just picked up new wires for it.
Old 09-03-2014, 11:50 AM   #32
2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of2002 has much to be proud of
2002's Avatar
2002's Tacoma Gallery
What are the best OEM spark plugs to get NGK or DENSO
Old 10-23-2014, 07:27 PM   #33
ToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shedToyComa84 is one of the sharper tools in the shed
ToyComa84's Tacoma Gallery
When/what condition does one change the spark plugs and/or wires?
Old 11-29-2014, 02:46 PM   #34
jkulysses is on a distinguished road
Army: 1-41 Infantry Battalion Veteran (Straight and Stalwart)
jkulysses's Tacoma Gallery
I just changed out my plugs & wires today & was blown away by the difference they made. My truck has 48,500 miles on it but still had the original wires & plugs from 1998. Overall truck ran fine but just felt gutless & idled a little rough. It also hated to be lugged at all & the whole truck would shudder if you didn't keep the rpms up around 2k. Now all that is solved! Motor is quieter in general, idles smooth, feels peppy again & doesn't care about being lugged anymore! The whole job took me about 30 min or so maybe a little longer because my neighbors kept stopping & bugging me.
I used OEM denso plugs I picked up from the dealer for $2.22 each & bought the nice NGK wires off amazon for $40 shipped.
Old 01-04-2015, 01:10 PM   #35
CodyH. is on a distinguished road
Air Force: Aircraft weapons
CodyH.'s Tacoma Gallery
Originally Posted by trdracing5 View Post
One more thing to add..... while you are changing your plugs you might as well change your PCV valve. Its cheap and easy to replace.
Where is the PCV valve, and what exactly does it do? My truck ('99 2.7 L) seems to be running a bit rough I have noticed lately. Its not terribly rough, but I notice it when idling. I'm looking for any quick fix. I have just over 175,000 miles on it. I have never done anything to the PCV valve, but I have changed the plugs and wires about 5-6 years ago. About how many miles should you get out of a set of plugs before you change them?
One more thing...my truck does have conventional plugs and wires, but I don't think it has a cap and rotor. Does that sound right?
Old 01-24-2015, 04:58 PM   #36
Yes that sounds right. The plugs should be changed around 30k miles.
Old 01-25-2015, 06:22 PM   #37
Thanks. I will be doing the plugs and wires again in the near future. There are lots of things I wanna do to this truck, but it gets so expensive so fast! When I did the plugs/wires last time I used NGK plugs and Napa auto wires. I cant remember why I went with those wires but this time I will get Toyota wires from the dealer.
Yesterday I went to my local dealer and spent a bunch of $. Gonna flush out my cooling system and replace all hoses and thermostat and PCV valve.
HOW TO: Remove/Install a starter/fix a clicking starter (2.7 liter 3RZ-FE engine) trdracing5 1st Gen. Tacomas 40 01-21-2015 06:16 PM
Spark Plugs and Wires Afraz 1st Gen. Tacomas 23 01-14-2015 08:26 PM
How To - Change Spark Plug 1st Gen 95.5-04 2RZ-FE(2.4L)/3RZ-FE(2.7L) The Parts Whore Technical Chat 7 01-28-2012 01:58 PM
Spark plugs and wires????? klem223 1st Gen. Tacomas 1 03-11-2011 01:14 AM
2rz-fe spark plugs - best for mpg/power wosneski Technical Chat 1 06-23-2008 04:15 PM
