99 3.4L Bog/No Power HELP!
Old 04-25-2011, 08:14 AM   #1
Guyskie [OP] Guyskie is offline
Guyskie is on a distinguished road
Guyskie's Tacoma Gallery
Trying to help a fellow Tacoma owner is distress. His 99 3.4L 5spd manual completely bog's and almost and sometimes does stall when any throttle is applied. The truck is unable to drive at all. Any help/suggestions to try would be greatly appreciated! The check engine light has not been triggered either which I find odd for the truck running so poorly.
New Fuel pump installed
Checked spark plugs
Checked PCV for vacuum
disconnected catalytic conv to rule out being clogged
checked for various vacuum leaks
What else?
Old 04-25-2011, 10:28 AM   #2
Carolina Alliance: Lead, follow, or get the hell outta my way
tacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shedtacomaman06 is one of the sharper tools in the shed
tacomaman06's Avatar
tacomaman06's Tacoma Gallery
Try cleaning your maf sensor and check the butterfly in the tb to make sure its opening all the way.
Old 04-25-2011, 06:38 PM   #3
Glitterdick
scocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shedscocar is one of the sharper tools in the shed
scocar's Avatar
Location: In close proximity to an undisclosed location
scocar's Tacoma Gallery
The throttle position sensor (TPS) might be malfunctioning? Other folks have had issues with a "dead spot" in acceleration and the TPS has been the culprit. Try a quick search in the 1st gen forum for "TPS." I just saw a good one recently.
http://www.tacomaworld.com/forum/1st...ike-crazy.html
Old 04-25-2011, 07:05 PM   #4
mike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant future
Army: SFC,  19 years, 5 to go.
mike92y's Tacoma Gallery
My 97 3.4L was only getting around 17mpg. So I invested in an ultra gage. I had two trouble codes but the CEL was not on. I think the perhaps the previous owner had disconnected this to pass inspection in PA. I cleaned the MAF reset the truck with the ultra gauge and the trouble codes came back. Replace O2 bank 1 sensor 1, reset the truck and now I get 18-19 mpg in the city and no trouble codes. So you may want to hook this truck up to a thingy magangy at your local auto parts store and see what it says. Hope I helped.
Old 04-25-2011, 07:44 PM   #5
Forgot that we swapped out the TPS sensor with a new one. TPS was not the culprit either.
Old 05-02-2011, 08:01 AM   #6
Ended up being a dirty MAF. Runs like a champ now. Its amazing that two little sensing wires being dirty would cause such havoc!
Old 05-02-2011, 09:52 AM   #7
Glitterdick
scocar's Avatar
Will for the win!
Glad it was so simple. Apparently, this should be item #1 on the trouble-shooting list for these symptoms.
99 2wd 2.4l payload IDtrucks Towing 1 04-14-2011 04:12 PM
3.4l engine for 99 same for 02? Tacoma. matgrom 1st Gen. Tacomas 4 01-30-2011 01:49 PM
K&N FIPK Gen. 2 Intake system 99-04 3.4L fidencio74 Buy / Sell / Trade 1 10-18-2010 04:22 PM
3.4L Pulling Power?? Spyro 1st Gen. Tacomas 25 08-26-2010 01:17 AM
Just got a '99 2.4L w/45K SlowIdle New Members 0 06-23-2010 06:04 PM
