Quick zerk greasing question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Jun 15, 2011.
  1. Jun 16, 2011 at 12:06 PM
    #21
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    if you got a auto dont even touch the fluid. atf last a good long time anyway. if its still red you aint dead lol in other words if its still red nothing is wrong. but the other stuff should probably get changed like the diffs and transfer case.
  2. Jun 16, 2011 at 12:07 PM
    #22
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    This. That truck is a pickup...our tacomas dont have greaseable ball joints.
  3. Jun 16, 2011 at 12:11 PM
    #23
    davestaco
    David
    Schofield Barracks
    x2....trust me i looked haha
  4. Jun 16, 2011 at 12:21 PM
    #24
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    cool.... cuz im sick of lubing nips....
  5. Jun 16, 2011 at 12:27 PM
    #25
    davestaco
    David
    Schofield Barracks
    thats not what she said:eek:
  6. Jun 16, 2011 at 12:32 PM
    #26
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    good info:thumbsup: i did not know all that
  7. Jun 16, 2011 at 12:46 PM
    #27
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Just wanted to post and say way to take care of your truck. On a side note this thread played out real smooth with good info and conversations. Nice.
  8. Jun 16, 2011 at 12:51 PM
    #28
    scocar
    scocar hypotenoper
    That's how we roll in 1st gen.;)
  9. Jun 16, 2011 at 12:54 PM
    #29
    OffroadToy
    Then why would Toyota recommend changing it at 60,000 (when towing) or 100,000 for normal use? I wonder if they'd cover you with the extended warrenty if you didn't get it done and something happened.
  10. Jun 16, 2011 at 5:16 PM
    #30
    x2468
    Just a little report i drove the truck for the first time since greasing it. It shifts a lot smoother now! Also, I used to get what felt like a lag and then jerk in the drive line when going from coasting to on the gas and that seems to have disappeared. Very happy about this since it always bothered me.
  11. Jun 16, 2011 at 7:02 PM
    #31
    t0mills
    t0mills Well-Known Member
    TRD, Gray Wire Mod, 3" Suspension lift, 3" Body Lift, 285/75 AT2s
    As for greasing your ball joints...........
    I have a "needle" that attaches to the end of my grease gun. It's small, and extremely sharp. This allows me to grease the ball joints/tie rod ends/cv axles by simply stabbing the needle through the rubber boot, and pumping in some grease.
    The hole that it leaves is tiny, and doesn't allow any grease to escape.
    Seems to work well for me, and I picked the needle up at a local O'reilly store for less than $5.
  12. Jun 16, 2011 at 8:53 PM
    #32
    davestaco
    David
    Schofield Barracks
    hmmm i didnt even know that was possible
  13. Jun 16, 2011 at 11:01 PM
    #33
    x2468
    Ya, I saw people talking about that in the threads I searched. I need to pick one of those up. But I've been.wondering. how does the old grease already in the boot escape to make room for the new grease?
    What else can u grease with the needle?????.
  14. Jun 17, 2011 at 10:34 AM
    #34
    davestaco
    David
    Schofield Barracks
    you could probably grease what ever the needle can get into....but if you should or not is a different story lol
  15. Jun 18, 2011 at 10:44 AM
    #35
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    what grease are you guys using for the zerks?
  16. Jun 18, 2011 at 12:01 PM
    #36
    davestaco
    David
    Schofield Barracks
    i used blue grease cause thats what i had laying around the farm.
  17. Jun 18, 2011 at 11:31 PM
    #37
    x2468
    A lot of people say Lucas.red n tacky #2. I think it cost me 5 bucks. Grease gun was 20 and and the hose was 6.
  18. Jun 18, 2011 at 11:44 PM
    #38
    x2468
    Still curious as to how the old grease in the cv boots would come out when pumping them with a needle.
  19. Jun 19, 2011 at 4:36 PM
    #39
    t0mills
    The old grease shouldn't come out of the boot. Also, please note that the ONLY time I add any grease to my CV boots, is if I've lost some out.
    I had a clamp come loose on me, and after replacing the clamp, I added some grease with the needle. That's about the only time I would add grease to the CV boots.
  20. Jun 28, 2011 at 9:26 AM
    #40
    x2468
    Ah. Thanks for clarifying. I was about to try greasing it
