Help me choose new tires and coils
Discussion in '1st Gen. Tacomas (1995-2004)' started by MacGyvR, Jun 23, 2011.
  1. Jun 23, 2011 at 10:12 AM
    MacGyvR
    MacGyvR [OP] Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    Okay, so after doing a lot of research, I've decided that I'm gonna get some billy 5100's all around. I can't for the life of me figure out what coils I should get. I'm not keen to lift it much, but wouldn't mind lifting it an inch or so. It's only 2wd on an open diff, so I'm not going to be rock crawling or mudding. I've looked into eibachs, but my understanding is they will give me a 3" lift, which I don't need or want. I also looked into OME 881's, and those look like those would force me to get the truck lifted by 1.75" to 2".
    Next topic. Tires
    My tires are frighteningly bald, but I just got paid and want to get new ones ASAP. What should I get for a prerunner that is primarily driven on the road, and might be used for occasional off roading? The tires I thought would be good for this would be Firestone Destination A/T. I have All Season tires right now and they've served me pretty well in the past. Basically, what do you guys recommend?
    Also might be important to point out I'm on 15" rims. There don't seem to be a lot of options (I'm probably just using the internet wrong, lol)
    I put a ton of effort into trying to figure this out on my own, I lurked the suspension and tire forums, but both seem to be dominated by 2nd gens that are into heavy off roading with armor. There's nothing wrong with that, but I don't have the $$$ that all these guys seem to have for suspension and tires.
  2. Jun 23, 2011 at 10:21 AM
    MacGyvR
    Tom
    Dallas, Texas
    If you can't tell, I'm really indecisive on the whole coil thing. Let me see if I can explain it better, because even I don't understand what I wrote.
    I need new coils. I'm on the stock coils after 150k, and they're shot. Through looking at them, it seems that if I buy new coils, I HAVE to lift the truck. For example, if I went with 5100's and eibachs, with the billies set to 0 the truck would be lifted 3". Is my understanding completely out of whack or what?
    I would like to stick to stock height for now, but I think a 1" lift could look good. Basically, I need advice on this.
  3. Jun 23, 2011 at 10:26 AM
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    I have been doing a lot of research on tires and I am getting some DuraTracs. If you go on tirerack.com you can see reviews for each tire and narrow down what you are looking for ( price, load range, terrain).
  4. Jun 23, 2011 at 10:39 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    yes, if you get eibach coils, you set the billy's to zero and you get 3 inches of lift. i don't know much about the ome coils, but i think they also have a predetermined amount of lift built into the coil.
    as far as tires, i'm running 31x1050r15 bfg all terrains and absolutely love 'em. they are on the heavy side, but i am extremely confident in their ability to get me in and out of any situation i put my truck in. i drive mostly on road, but do a fair amount of camping and exploring on forest service roads and dirt track and the like.
  5. Jun 23, 2011 at 10:48 AM
    MacGyvR
    Tom
    Dallas, Texas
    Thanks for the speedy reply! What caused you to go with duratracs? Also, Tirerack doesn't list duratrac as being available for my truck, I thought that was weird.
    That sounds exactly like what I do. I'll be driving to work/school for the most part, but really enjoy weekend trips out in the desert or in the forest. I've seen some bad reviews for bfg's on TW though. Common nicknames are "rugged fails" and "long fails" because they have a really thin sidewall.
    What do you guys think of these?
    Firestone Destination AT
    http://www.tirerack.com/tires/tires...autoYear=2003&autoModClar=&vehicleSearch=true
    Firestone Destination LE
    http://www.tirerack.com/tires/tires...3&autoModel=Tacoma 2wd PreExtCab&autoModClar=
  6. Jun 23, 2011 at 11:17 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    If you don't want much of a lift you can always get a new pair of OEM coils and adjust the 5100s to give you just a little lift over stock.
    The Destination A/Ts are good tires for the money. I'd also suggest some Hankook Dynapro ATMs. They're pretty cheap and are an awesome A/T tire.
    On the pricier side I'd look at Michelin LTX AT2, BFG KO, and Goodyear Duratrac.
  7. Jun 23, 2011 at 11:18 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    no, not the rugged trails... those are known to be pretty shoddy. i have the much-lauded BFG T/A KOs
  8. Jun 23, 2011 at 11:23 AM
    MacGyvR
    Tom
    Dallas, Texas
    So I looked at replacing with the OEM coils and found it'd be $201 with shipping to get them. With some reading I've found that the stock coils are pretty weak too, so I figured it'd be better to put the same amount of money towards nicer shocks. I just don't think I need a 3" lift for a truck that isn't the best for off roading.
    I'll look into the hankook's now, thanks!
  9. Jun 23, 2011 at 11:34 AM
    TurtleSVS
    TurtleSVS Member
    Michelle
    Alameda, CA
    Same boat here re: suspension. 160K miles and it's time for something new, but I don't want to lift my daily driver and towing vehicle. I do like to go play, but mostly drive on pavement.
    Also, FWIW, I've had two sets of the BFG All Terrains and love them. It would take a lot for someone to convince me to get something else when it's time for new tires again.
  10. Jun 23, 2011 at 11:43 AM
    richsteele
    richsteele Member
    99 Reg cab 2.7L 4x4
    Dash & heater panel LEDs, stereo & speaker upgrades, 2004 side mirrors, Safe-T-Cap mid-frame section repair kits.
    What about OME 880 coils instead of the 881s?
    Per website - Average lift from this coil set on an extra cab v6 Tacoma is 1.25-1.5".
  11. Jun 23, 2011 at 11:54 AM
    MacGyvR
    Tom
    Dallas, Texas
    I was just looking at that and trying to figure out what the difference (if any) is between the 880's and the 881's in terms of ride quality.
  12. Jun 23, 2011 at 12:11 PM
    richsteele
    richsteele Member
    99 Reg cab 2.7L 4x4
    Found this on another different vendor's website (Cruiser Outfitters).
    [SIZE=-1]Front Coil Specifications:[/SIZE]
    • [SIZE=-1]OME 880 - Free Height: 365 mm Spring Rate: 88 N/mm [/SIZE]
    • [SIZE=-1]OME 881 - Free Height: 375 mm Spring Rate: 88 N/mm [/SIZE]
    • [SIZE=-1]OME 882 - Free Height: 395 mm Spring Rate: 88 N/mm [/SIZE]
    All 3 have the same spring rate, they are just different heights depending on how much lift you want and how much weight you are carrying in the front (bumper, winch, etc.).
  13. Jun 23, 2011 at 12:21 PM
    MacGyvR
    Tom
    Dallas, Texas
    Awesome! I think I'll go with the 880's then. That's pretty much exactly what I was looking for.:D
    It now occurs to me that if I lift the front, I need to do something with the back, otherwise it could look pretty goofy. Having done no research on this yet, can I just do the AAL thing and get 1.25" - 1.50" off it? I'm going to look into this now, but I figured I'd ask anyway.
  14. Jun 23, 2011 at 12:23 PM
    JaSkynyrd
    JaSkynyrd Ron F. Swanson
    Chattanooga, TN
    2001 XtraCab 4x4 V6 SR5
    I second the OME 880s to go on your Bilsteins.
    As far as tires go, the tire that creates a hardness in my pants is the BFG A/T TA KOs. I had them on my 4x4 dakota and loved loved loved them. But that was when oil was cheap and I got 31x10.5s mounted and balanced for a little over $500. Shit, they're prolly over a thousand bucks now. I plan on getting your original choice, Firestone Destination A/Ts. All the reviews I've read say they are a good tire on and off road. and the price is right. My dad's supplier said he can get 4 265/75/16s mounted and balanced for 640 after tax. That means I will be wearing that tire when my mismatched set wears out.
  15. Jun 23, 2011 at 12:24 PM
    LBCdan
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
  16. Jun 23, 2011 at 12:25 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    OME 880 seem to fit the bill for what you are looking for.
    Both the tires you linked too are sized 225/75r15. That's a pretty small tire (~28''). You should have an easier time finding tires in the 235/75r15 size, and it will look better if you are lifting the truck a little.
    The largest size you can fit without issues is 265/75, but naturally the larger you go the more power you lose. Your odo and spedometer will also read slower than you are actually going.
  17. Jun 23, 2011 at 12:26 PM
    Norton
    Norton Senior Member
    Steve
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x2. I ran the same tires on my '92 Toyota Pickup for about 10 years and LOVED them. I found them to be great for inclement weather, good for the occasional off-road use, and they wear very well (over 50K miles on each of the sets I ran).
    x2. I'm very happy with my 881s, but I wanted a bit more lift than you're looking for. The 880s should give you exactly what you want. I'm also happy with Bilstein 5100s all the way around, but you might also consider OME Nitrochargers. (Some folks prefer the ride they give when paired with OME springs.)
    An AAL will work if your leafs aren't flat/frowning. If they're shot, a new leaf pack is the way to go. Wheelers offers a number of options, including a 4-leaf pack (for stock height) and a 5-leaf pack (for a little lift).
  18. Jun 23, 2011 at 12:35 PM
    MacGyvR
    Tom
    Dallas, Texas
    I'll look into the nitrochargers. I'm really strapped for cash (starving college student), so I'm just looking to fix her up a bit. The ride quality is pretty bad now, so I think anything would be an improvement.
    I'm not sure what shape my leafs are in. Here are some pictures I took in my other thread though.
  19. Jun 23, 2011 at 12:38 PM
    MacGyvR
    Tom
    Dallas, Texas
    Yeah, I plugged in the trucks information and that's what it matched it to. I'm still learning about tires, so I'll look into what those numbers actually mean. What size would you recommend for a 1.25" lift?
  20. Jun 23, 2011 at 12:43 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    For looks I would go with a 31'' tire (31x10.5r15)which is roughly the same as 265/75r15. For slightly better fuel economy, a 30'' tire would work.
    from the online tire size calculator
