1998 TACO WON'T START/ CHECKED EVERYTHING
Discussion in '1st Gen. Tacomas (1995-2004)' started by smagohawks, Aug 30, 2011.
  1. Aug 30, 2011 at 11:52 PM
    smagohawks
    smagohawks [OP] Member
    Topeka,Ks
    03 Tacoma SR5,TRD 4x4
    My son's 1998 Taco won't start. It won't turn over. Not even a click. We installed a new battery, had the satrter checked as well as the alternator.
    We took the truck to a battery vendor for a free test. He said our new battery had a dead short in it. We got a refund for that battery even though the battery tested fine out of the truck. Purchased a new battery from a different vendor and installed it. We have the same problem.
    We can jump start the truck and it starts just fine. I am ready to pull my hair out trying to figure this out.
    Any help or ideas will be greatly appreciated.
    Steve Alejos
    smagohawks@cox.net
  2. Aug 31, 2011 at 7:40 AM
    jking3002
    jking3002 Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    Battery cables?
    If not those, it IS NOT a battery issue. Do you have anyway to test the alternator when the vehicle has been dead or have you been driving it someplace to get a test? This might cause it to read as working normal when in reality something is happening when the car is off/has been sitting for a few hours.
    Does it start sometimes? Or never? Sometimes starter issues are hit and miss.
  3. Aug 31, 2011 at 7:52 AM
    Demon Taco
    Demon Taco Well-Known Member
    Robert
    New Hampshire
    Gold Tacoma SR5 4X4
    how do your battery cables look.are they corroded,is the cable end green or caked with a powder.that goes for both positive and negative.its possible they have a short from the terminal to the wire.when you hook up jumper cables you have just added a new ground and more battery power to over come a bad terminal,which has simply added more resistence.start with the basics.then move to the expensive parts.
  4. Aug 31, 2011 at 9:46 AM
    YouNext
    YouNext General Calamari
    San Diego
    K&N FIPK, Gibson Exhaust, Doug Thorley Headers, URD pulley, Stoptech Cryo-treated Slotted Rotors, Deaver J59, Bilstein 5150s, Total Chaos LT (w/Spindle & Tower Gussets), Icon LT C/Os.
    obviously you didn't check everything.
    You said it doesn't crank over, not even a click. You said you can jump start the truck. How many batteries did you try? just that one?
    Aside from that I would also guess cables. A shotty connection somewhere that's not getting enough juice, but might get the boost from a jump to push through said shotty connection.
  5. Aug 31, 2011 at 9:48 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    yup sounds like a bad ground...
  6. Aug 31, 2011 at 9:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    .......or you have a blown 120A ALT or 40A AM1 fuse.
    EDIT: Scratch that. going with the cables also.
  7. Aug 31, 2011 at 10:42 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Is the battery dead when you try to start it? Check it with a volt meter. If it is some thing is staying on drawing power this maybe why it starts with a jump. Did it start when you replaced the battery first off or did it still need to be jumped?
  8. Aug 31, 2011 at 12:07 PM
    kctmet
    kctmet Well-Known Member
    Orange County, California
    02 DC V6 4x4 TRD
    Replace the ground cable.
  9. Aug 31, 2011 at 12:10 PM
    jbrandt
    jbrandt Made you look
    Justin
    El Dorado, CA (NOT El Dorado Hills)
    '04 TRD Tacoma 4x4 DC
    Kings, J59's Total Chaos UCAs Custom skids Sticker mod
    I'd imagine it's either corrosion on the cable leads, or just a bad connection.
    When you jump it, do you put both leads on the battery (of the dead truck), or the negative lead on a ground (like you're supposed to)?? you might have a bad connection on your (-) battery terminal.
    Clean all the leads real good, put some of that jelly on the terminals, and reconnect. If there's rust on the terminals, replace them (easier than trying to remove the rust).
  10. Sep 1, 2011 at 3:56 PM
    smagohawks
    Topeka,Ks
    Gentlemen,
    Thanks for all your help and ideas with this problem. I discovered that the new battery terminal we bought from the parts store was not making good contact with the positive post. Why the system showed a dead short is beyond me. The terminal we bought is solid brass with gold plating. The hole is not concentric. It is oval which made it not have good contact. I bought a Toyota terminal, put that on and it works fine.
    Again, Thank You for all the great ideas and help.
    Steve Alejos
