1st Gen Deceleration Sensor Location?
Discussion in '1st Gen. Tacomas (1995-2004)' started by clothar, Sep 21, 2011.
  1. Sep 21, 2011 at 1:56 PM
    clothar
    clothar [OP] Well-Known Member
    Vancouver
    98 V6 4WD Xtra Cab Limited
    Hey Guys,
    I've got a 98 tacoma with ABS and i've been having the ABS light coming on intermittently after about 20-30 of highway driving. I checked the ABS code using the process outlined in the manual using the jumper and so on and it says there is a problem with the deceleration sensor.
    So i go to check this mother out and i can't for the life of me find the damn thing. I'm really starting to hate the drawings of parts floating in space with nothing as a reference. So if someone could let me know where this sensor is that would be great.
    Thanks,
    Oh yeah and anyone else have the problems with the deceleration sensor?
  2. Mar 23, 2012 at 8:42 PM
    yoTaco98
    yoTaco98 Well-Known Member
    Yo
    VA
    1998 V6 Xtra-Cab Tacoma 4x4 SR5
    5100's Front and Rears, Toytec Eibach Coils, All Pro 3" Standard Leafs, BAMF BPV Bracket, ARMA Sprayed Bedliner, TGD Hunter Bull Bar, Blacked-out Headlights and Corners, Revtek 1" Diff Drop, Start Command Remote Start and Keyless Entry, Pioneer DEH-11E HU...
    Did you ever find it?
    The decel sensor that's apparently under the dash somewhere?
  3. Mar 23, 2012 at 8:59 PM
    makikid808
    makikid808 They call me unko
    Kamaki
    Kula,Maui
    98 Tacoma sr5 4x4 5VZ-FE 3.4 manual
    fabtech 6" lift, all-pro 5" rear lift springs, 17x9 ATX slot, 295/70/17 nitto trail grapplers, Borla catback exhaust system, K&N FIPK, bully nerf bars, wet okole seat covers, tints (factory tint plus 5 on back 35 on front), sounds(kenwood deck, kenwood IE speakers all around,kenwood 720W amp for mids, kenwood 1000W amp pushing orion 12" sub), LED dome map and door lights
    Mines been doing that to but it only happens once in a while. I still haven't figured out why it happens only sometimes and not all the time.
  4. Mar 25, 2012 at 8:54 AM
    clothar
    Vancouver
    Yeah i found it on a 98 tacoma it's in the same place as on a 2000 i looked at the parts location diagram for the 2000 model. From the manual that are stickies turns out the deceleration sensor is just above the pedals underneath the steering column.
    I got lucky i pulled out the sensor tested it out to make sure it was giving the correct readings. I seemed like it was so i hooked it back up and i've been trouble free for the last 5000 miles. And through the winter i've used my ABS a couple time and it works just fine.
  5. Mar 25, 2012 at 8:57 AM
    clothar
    Vancouver
    Mine came on only during longer drives didn't usually come on during city driving. All i did to fix mine was pull it out and test it then plug it back in and now it works. Hopefully, that'll work for you too.
  6. Mar 25, 2012 at 3:20 PM
    yoTaco98
    Yo
    VA
    Thanks guys.
    I downloaded the trouble shooting guides from the FSM for the sensors, actuator, and the decel sensor.
    I'm going try each one until I find the 32 & 44 issue.
  7. Jan 20, 2013 at 10:46 PM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    this just happened to me after about 45 mins of highway driving... is it possible to post up a picture of where its located? I got a 04 dc... if that makes a difference.. thanks! Dont want to take it to the dealership just yet...
  8. Jan 9, 2021 at 12:20 PM
    Wolfjesus
    Wolfjesus Member
    Colorado
    2001 Tacoma TRD
    OME 881's with nitro charger shocks and full Dakar leaf pack
    Anybody figure out where this sensor is and can share a description or picture?
  9. Jan 9, 2021 at 6:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Predator tube steps, Ranch Hand grill guard, Magnaflow CatBack exhaust, Toyota tool box & bed mat, 2LO Module by @Up2NoGood, Rearview Compass/Temp Mirror, Tune by @JustDSM.
    Looks like it's under the center bezel just to the right of the shifter, found a thread here about it.
    imageuploadedbyih8mud-forum1418510696-71_0c10749e5efb7d9f6acc777dbf0065cbff1e7e0b.jpg
  10. Jan 10, 2021 at 3:47 AM
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    Fix code 32 and the de acceleration code will go away at the same time
  11. Jan 10, 2021 at 7:36 AM
    Wolfjesus
    Wolfjesus Member
    Colorado
    2001 Tacoma TRD
