Roof Rack on a extra cab.
Old 10-15-2011, 02:39 PM   #21
wolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud ofwolfgang123 has much to be proud of
wolfgang123's Avatar
wolfgang123's Tacoma Gallery
true true
Old 10-25-2011, 06:58 PM   #23
soon... the cross bars need to be 1-1/8th inch diameter and they don't sell weird size pipe like that at Lowes. So i found some on ebay for 44 bucks with shipping they will be here Thursday and hopefully installed this weekend but it is Halloween and i am in college so thats a big maybe.
Old 11-01-2011, 05:04 PM   #24
Originally Posted by bobbyinbend View Post
Wolf how bout some pics?
mkay fellas well i finally went to mount my rack and ran into some issues i accidentally pierced the headliner in one spot(its not that bad really)!!!! and one of the fasteners broke so i need to call Yakima and get a replacement so i could only install half of my rack
It was a pretty easy install i started by assembling everything and getting everything centered and where i wanted it on my roof. then i started with a 1/8th drill bit and made my way one drill bit at a time up until i hit 3/8ths at this point the hole was barely too small but if i went the next drill but size up it would have been to large so i hit the hole with my dremel and a grinding bit.
I then touched up the marks with some paint, applied silicone to both sides of the fasteners attached the landing pads then the roof rack and DONE!!!!
Mounted up:
With the rack removed and the landing pad covers installed:
Old 11-01-2011, 05:58 PM   #25
Critta93 is on a distinguished road
Critta93's Avatar
Critta93's Tacoma Gallery
How did you get your signal lights to shine all of the time?
Old 11-03-2011, 05:07 PM   #26
bobbyinbend is on a distinguished road
bobbyinbend's Tacoma Gallery
Looks good wolf. So the fasteners only go through the sheet metal? How strong do you say that rack is?
Old 11-04-2011, 05:11 AM   #27
Look up the "turn signal mod"
Yup the fasteners where actually pretty thick, and the roof was MUCH thicker than i was expecting. so i have absolutely zero worries about strength. I am not going to ever put more than 100 up there because the basket i plan to get is only rated that far. The landing pads and fasteners where rated at 150lbs and honestly i can believe it. After install i tried to "break them" and i was shaking the whole truck and the rack didn't move a millimeter.
Old 11-04-2011, 02:56 PM   #28
Thanks so much that's exactly what I wanted to know. I'l be doing the same thing for my truck as it looks to be the most economical and aesthetically pleasing way to mount up a rack on xtra cabs. I've been searching for quite some time and this seems to be the solution. Cheers!
Old 11-05-2011, 03:48 PM   #29
so one of the fasteners broke i called yakima and they sent me a new one with 1 day shipping for 11 bucks...i think its fair so the back part of the rack should be one next weekend.
Old 07-19-2012, 06:43 AM   #31
TIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shedTIPICOTACO is one of the sharper tools in the shed
TIPICOTACO's Avatar
TIPICOTACO's Tacoma Gallery
I'm thinkin just go to their website and search the dimensions..
HERE YA GO: MEGA - 52" x 48" x 6" 35lbs
LOAD - 44" x 39" x 6.5" 25lbs
Old 07-19-2012, 10:45 AM   #32
I eat terrorism and crap freedom!
apierce7565 is on a distinguished road
apierce7565's Avatar
Army: 12B Combat Engineer 2/11 ACR 58th CEC
apierce7565's Tacoma Gallery
i have but i still can decide, the megawarrior hangs over the side just a tiny bit while the loadwarrior doesnt. im just trying to see if the megawarrior will look retarded on it or not
Xtra cab Roof rack lennys 1st Gen. Tacomas 19 07-12-2014 04:44 PM
Double Cab Roof Rack for an Access Cab? gavonder 2nd Gen. Tacomas 58 04-03-2014 08:59 PM
2nd gen looking for a roof rack basket compatible with factory roof rack? 01GREENTACO 2nd Gen. Tacomas 1 03-05-2011 08:20 PM
Access Cab Roof Rack tanktodd 2nd Gen. Tacomas 1 09-15-2009 06:18 AM
Double Cab w/ Roof Rack.. AFButters 2nd Gen. Tacomas 25 09-24-2008 06:06 AM
