P0171 CEL Code
Old 10-30-2011, 06:03 PM   #1
Self Proclaimed first gen expert :doh:
Greensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shedGreensystemsgo is one of the sharper tools in the shed
Greensystemsgo's Avatar
Greensystemsgo's Tacoma Gallery
P0171 CEL Code
Normally at half a tank im at 150 miles, now though at half a tank I was at 80, and at 1/3rd left, im at 130.
The CEL came on during hard acceleration up a hill. Sense this issue happened three weeks ago i discovered that my most rear exhaust hanger had come undone. Possible that the cat sensor wires snapped and is screwing my fuel efficiency?
Autozone tells me Fuel mixture system lean bank 1.
Ive had this issue on bank 2, and it turned out to be the coil, they're all stock, at 182k miles now.
Truck is still powerful, but at idle has a light chug, and during hard acceleration shudders a bit.
Causes Low fuel pressure, (pump/filter/blockage? I'd imagine id have a loss of power?)
Faulty MAF/VAF sensor (its stock and clean)
Cylinder misfire condition (this doesnt say a whole lot, coil?
Faulty HO2/AF sensor (is this the cat sensor?)
Large vacuum leak (ill spray starter/brake fluid, but doubt its this. i have all newish hoses.)
Also, this info is from autozone, when my parents had a cel on their 98 GMC, the dealer told them it happend a certain number of miles ago, which they calculated to a hill, it was a misfire and happened once and that was it. so the dealer reset the computer and theyve had no problems sense. Can a toyota dealer tell me anything more? Sure would be nice, autozones info seems.... universal and leaving some to be desired.
Old 10-30-2011, 06:58 PM   #2
Stealth Custom Series™
SCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shedSCSPerformance is one of the sharper tools in the shed
SCSPerformance's Avatar
SCSPerformance's Tacoma Gallery
it's running lean so the computer is compensating the lean by dumping a lot of fuel thus your poor gas mileage. i know you said your maf is clean, but did you actually clean it or did it just look clean? do the usual tune up parts as well. it could be the a/f ratio sensor which is common to go out on these toyotas. you have a good list going so just start with the cheapest and easiest things first.
Old 10-30-2011, 08:15 PM   #3
I'll eat all your food.
UndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shedUndefinedTaco is one of the sharper tools in the shed
UndefinedTaco's Avatar
UndefinedTaco's Tacoma Gallery
It could be your upstream O2 sensor, but doubt it.
PO171 is a common code for misfire, it's most likely a misfire.
I'd bet it's something far as spark. Coils, wires, or plugs.
You can try and resetting computer..pull NEG terminal on battery for 15-30 minutes.
Then put it back on..then start it, pull EFI 15A fuse under hood..it'll kill the truck. Then put fuse back in. Re-start it..let it idle, then drive. See if code comes back.
Old 10-30-2011, 08:19 PM   #4
E-Fabber
Anthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shedAnthony250 is one of the sharper tools in the shed
Anthony250's Avatar
Anthony250's Tacoma Gallery
Hes right it is most likely the Upstream O2 sensor, i have the same light just came on,and I know every thing is good but i have not replaced that 02 sensor.
Old 02-11-2012, 10:36 AM   #5
And still the fight continues!
Old 02-11-2012, 10:40 AM   #6
G scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shedG scott04 is one of the sharper tools in the shed
G scott04's Tacoma Gallery
I must know how you resolve this I think I have the same problem, Im at like a 100 miles at half a tank.
Old 02-11-2012, 11:15 AM   #7
It is not the coil. Maaaaaaybe wires. I'm thinking the o2 sensor on cat, or maf. I should do seafoam through gas tank to clean injectors and other stuff.
Old 02-11-2012, 11:30 AM   #8
lil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant futurelil J has a brilliant future
lil J's Avatar
lil J's Tacoma Gallery
Change out your mass air flow sensor, cleaning doesn't work as good as replacing. I had the same problem, except for the exhaust bracket. After I changed the MAF truck was running like new. On the first gen. the MAF is a common problem, don't know what year you got but the sensor is relatively cheap.
Old 02-11-2012, 12:01 PM   #9
lil J's Avatar
If you do decide to change out the MAF disconnect the battery while before you start so you computer will reset.
Old 02-11-2012, 12:13 PM   #10
Did you get a new one or a rem? saw one with a core charge at autozone
Old 02-11-2012, 03:02 PM   #11
lil J's Avatar
got the one with core charge at autozone
Old 03-26-2014, 06:46 PM   #12
Archer550 is on a distinguished road
Canadian Army:
Archer550's Tacoma Gallery
Zombie i know, but did you (op or others with symptoms) ever figure this one out?
I got the same thing going on now in my 2004 tacoma
Old 03-26-2014, 06:52 PM   #13
oldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shedoldblue1968chevy is one of the sharper tools in the shed
oldblue1968chevy's Avatar
Air Force: Maintainer
oldblue1968chevy's Tacoma Gallery
Im at 100 miles @ 1/2 talk no CEL light...
Granted alot of my driving is short low mileage trips...but didnt seem ALOT better when i drove to seattle (5 hrs)
Old 03-26-2014, 07:09 PM   #14
Canadian Army:
I had this issue on a recent 700km road trip (1400 km total) and noticed on the way out around 10 MPG as well as the cel came on when i romped it on the highway...
Took it to a dealer (was 700 km from my tools and scanner )
They replaced pcv valve (aparently it had failed), replaced air filter, and cleaned maf. Truck ran okay for the first tank and then boom back to 10 mpg cel on. Next fill up cel back off and somewhere around 14 mpg? The intermitent nature of the porblem is the worst part, ordering a scangauge 2 to monitor faults and A/F real time.
Gonna do a tune up tomorow as i just noticed the plug wires are from 2004 and i have heard that misfires can cause a lean reading.
Old 03-26-2014, 07:15 PM   #15
Replace wires and plugs. Then refer to FSM for coil testing.
Mine was coils. I ordered all new denso parts from RockAuto.
Old 03-26-2014, 07:18 PM   #16
wannabetrd has much to be proud ofwannabetrd has much to be proud ofwannabetrd has much to be proud ofwannabetrd has much to be proud ofwannabetrd has much to be proud ofwannabetrd has much to be proud ofwannabetrd has much to be proud ofwannabetrd has much to be proud ofwannabetrd has much to be proud of
wannabetrd's Avatar
wannabetrd's Tacoma Gallery
P0171
Check all your vacuum lines
Old 03-26-2014, 07:27 PM   #17
Canadian Army:
Will do. Is NGK stuff okay? (for wires and plugs) Its all I can get locally. The local parts store wants nearly $80 for ngk plug wires...
Considering OEM from conicelli partznet is $55 that seems a little steep.
Id rather not wait the 1-2 weeks it would take to get stuff from rock or conicelli.
Old 03-26-2014, 07:50 PM   #18
Shipping is like 3 or 4 days. And you know it'll be OEM quality cause denso makes Toyotas parts.
NGK I have zero experience.
Old 03-26-2014, 07:51 PM   #19
Nvm, I see your from ca. Check dealer.
Old 03-26-2014, 08:33 PM   #20
Canadian Army:
I fear the dealer prices, i will check tomorow but the parts i bought to do my waterpump and timing belt from conicelli, (around 400) was upwards of 1200 locally.
Code P0171 Flaadog Technical Chat 10 10-28-2011 05:58 AM
CEL CODE P0171 harley09 Technical Chat 28 10-13-2010 11:38 AM
P0171 Code shaniac 1st Gen. Tacomas 9 08-18-2010 09:19 PM
code p0171 trailinTaco 1st Gen. Tacomas 1 06-23-2009 08:23 PM
CEL code P0171 now a low idle...exhause leak? raise the cat? 98tacogrande 4 Cylinder 9 06-01-2009 09:31 PM
